Question about Westinghouse 46" Class LED 1080p 120Hz HDTV,2.14" ultra-slim LD-4680
Looking for Westinghouse LD-4695 service menu access code
Would like to calibrate my Westinghouse LD-4695, and I'm looking for the service menu access code.
3 Suggested Answers
SOURCE: Westinghouse LCD TX47F430S
I had the same problem on my 42 inch from westinghouse and all i had to do was hit the FIT button on the menu and/or remote and the screen adjusted to fit screen. hope this helps
Posted on Jul 15, 2008
spr1949
  • 1182 Answers
SOURCE: Westinghouse LD-3240 input select menu keeps
Look for any jammed button on your remote or on the TV. Just recheck on the settings and if necessary change it to factory default settings. If you have problem still, switch off TV, switch off Power and remove plug and wait for 48 hours and retry.
Posted on Jul 29, 2012
Westinghouse LD 4695 power supply works but TV has no power
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 11, 2016 | Westinghouse Televison & Video
Cual es el codigo de acceso para canales de tv LD-2240
Codes are stored in the remote. A Westinghouse remote should be able to control your TV directly. If you are using a universal remote, you will have to perform a code search to find something that will work.
Jan 15, 2016 | Westinghouse Televison & Video
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
TC-29T400W Tv remote model number
check this out
http://www.ebay.com/itm/New-Westinghouse-RMT-11-Remote-for-LD-4695-UW-40T3PW-UW-40TC1W-UW-40T-LD-3265-TV-/231358830634?pt=US_Remote_Controls&hash=item35de0f982a
Dec 17, 2014 | Televison & Video
MY TV NOT HAVE SOUND
check settings to see if on external speakers if not bad sound board
Oct 05, 2014 | Westinghouse LD-4695 46" LED TV 1920x1080,...
Our westinghouse ld 4655vx just shut off bye itself and won't turn back on
Check and replace its main power regulator board. It is faulty. Not working.
Jan 30, 2013 | Westinghouse Televison & Video
My new Westinghouse LD-4695 LED TV changes the channel by itself, sometimes just one at a time and other times rapid both up and down? Also shows me that the speakers are off as I use my surround sys
Several issues here so to begin with remove power from the set and a box of any kind if used for several minutes and then power back to see if a reboot helps or not.
Dec 23, 2012 | Westinghouse 46" Class LED 1080p 120Hz...
Access code for westinghouse tv model LD-2240 serial 6616121307447
You're asking about its service mode code I assumes, and posts this solution. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now
Sep 14, 2012 | Televison & Video
WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
Feb 02, 2012 | Televison & Video
Code for Westinghouse LD 2480 LED TV
Look at the back of your remote... It should give you a simple fix... WORKED FOR ME!!!
Jan 18, 2012 | Westinghouse Televison & Video
Open Questions:
See all Westinghouse 46" Class LED 1080p 120Hz HDTV,2.14" Questions
Westinghouse 46" Class LED 1080p 120Hz HDTV,2.14" ultra-slim LD-4680 Logo
113 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
