Question about eMachines Computers & Internet
My emachine desktop will only start in safe mode
Only starts in safe mode,
  • eMachines Master
  • 7,627 Answers
In Safe Mode, run MSCONFIG, you didn't specify the OS, for Win 7 use this: http://www.netsquirrel.com/msconfig/msconfig_win7.html In the GENERAL tab select Normal Startup, click on APPLY, OK, RESTART. Post results.
Posted on Apr 19, 2013
  • 166 Answers
SOURCE: I have a Emachine W3650 And it wont start up
Insert your windows cd and set computer to start from cd. When prompted to, hit a key to boot from CD. Let Windows start the install (relax it is not really installing anything) when it gets to the prompt, tell it you want to Repair an existing installation. Then pick the prompt that gets you the recovery console. When you get to the prompt type CHKDSK /R and let it run. Sometimes this can take an hour or more depending on the size of your drive. Do not get worried if the percentages complete go backwards, like from 70% back to 50%. Sometimes it will go back and fix files. Hopefully you will not get the error that there are unrecoverable errors. This has worked for me on about 90% of the hard drives that I received the inaccessible boot device or had a corrupt installation of windows. Sometimes you cannot recover from this unless you get really lucky. I had one instance where I did this and CHDSK recovered the files but did not name them the same as before and it renamed the Windows System file FOUND001. Luckily I had another similar computer to insert the drive in as a slave and compare file sizes to and when I renamed them the correct filenames the system started up and allowed me to retrieve my data. I ended up reloading the machine after I got my data off. This whole problem happened due to a power interruption during bootup.
Posted on Mar 12, 2009
  • 257 Answers
SOURCE: my cp will not boot up
You go to Bios mode and choose the frist boost is DVD/CD then save new setting and turn off your comp. Insert Win XP operation disk and see if it could fix the problem.
Posted on Aug 12, 2009
  • 69 Answers
SOURCE: my emachines desktop crashed,wouldn't even let me
ok try this. turn on your computer and put the disk in and turn off the computer right away and turn it back on and the recovery screen should pop up and go from there hope this helps
Posted on Sep 25, 2009
  • 400 Answers
SOURCE: My Emachine T5010 reboots on Windows loading screen.
Before windows loads press F8 on the keyboard to get an advanced menu.
choose the option that says disable automatic restart on error and see what error you get.
Also try the Safe Mode option.
That click sounds like the harddrive is failing.
Posted on Nov 02, 2009
riceski
  • 1851 Answers
SOURCE: My emachines computer will not start up. All I
Try starting the machine - -then tap DELETE - - this will put you into the DOS mode - -at the top of the opening page - change the date to the correct Time and Date.
Posted on May 06, 2010
My emachine computer doesn't start up
Start in Safe Mode then reboot. Windows 95 & 98 used to this all the time.
Oct 06, 2012 | E-Machines eMachines Desktop PC
When desktop is switched on emachine logo comes on then all we get afterwards is a small white dash in the top left corner of screen.
try to start window in safe mode right after you start push the f 8 key then select safe mode option there you may do a system restore if your running xp edition Good luck James
Dec 26, 2010 | E-Machines eMachines Desktop PC
May 05, 2010 | E-Machines eMachines Desktop PC
Can't access start menu or any of the desktop icons. can't find the restore to an earlier date program
switch off PC and start in Safe mode...to sue safe mode press F8 key before the windows screen appears after your machine boots....
once in safe mode...just shut down and restart...
Dec 09, 2009 | E-Machines eMachines Desktop PC
Nov 02, 2009 | E-Machines T5010 PC Desktop
My cp will not boot up at all. the light turns on but nothing comes up.is there away to fix this? i did try starting in safe mode which is f8 (i hope) it ask to start in safe mode,safe mode with...
Aug 12, 2009 | E-Machines eMachines Desktop PC
As i was using my emachine laptop the screen turned to rainbow colors
it may just be a software glitch.. can you start in Safe Mode? you might be able to get it going in Safe Mode with Networking. then download the latest display driver and reinstall.
Jul 18, 2009 | E-Machines eMachines Desktop PC
AFTER THE WINDOWS LOGO COMES UP AND I ENTER PASSWORD DESKTOP STARTUP DOES NOT COME UP. ONLY BLANK SCREEN
Very first thing to try is to see if it boots in safe mode. Start the computer, immediately start tapping F8. You'll eventually get a menu - pick "Start in safe mode." When Windows comes up, log in and see if it goes all the way to the desktop - it will likely look a bit strange, and will give a warning that you're running in Safe Mode.
If the desktop comes up, you've got a program or driver that's interfering. If it doesn't... Windows is quite likely borked and will need to be reinstalled.
Jun 26, 2009 | E-Machines eMachines Desktop PC
My computer only starts that's all.
start in SAFE MODE and try to restore system at earlier stage. To start in SAFE MODE use F8     at the boot time. if that does not help you reinstal windows.
Feb 03, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
89 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
