Question about Panasonic AG-DVC10 Mini DV Digital Camcorder
Disassembly motherboard camera - Panasonic AG-DVC10 Mini DV Digital Camcorder
ASUS K52F Motherboard removal
NO
OH, I'm JUST KIDDIN'!
1) http://www.insidemylaptop.com/disassemble-asus-k-series-notebook/
2) http://ncandelier.free.fr/dem/ASUS_K52.pdf
Buy, and wear an ESD wrist strap, or use your motherboard for a Frisbee. ("Wow! Look at that THING Go!")
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up!
Make drawings, and notes as you disassemble.
Use a digital camera, or video camera, or at least a phone camera, and GOOD lighting.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
You don't need a Soldering Station.
A low wattage soldering iron (25 Watt?), Rosin Core solder, rosin paste flux, paste flux brush, Desoldering Braid. (Solder Wick)
[I will use Desoldering Braid over a Solder Su-cker tool, ANYDAY.
(Desoldering Tool) ]
http://www.laptoprepair101.com/laptop/2008/10/28/fortify-damaged-power-jack-connection-in-laptop/
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 13, 2013 | ASUS Computers & Internet
Fuji lifebook
Fujitsu Lifebook S7020?
This S7010 series notebook disassembly guide should be what you need,
http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/48-fujitsu-siemens-s7010-disassembly
Plus I feel this may help,
http://jackrepair.blogspot.com/2006/06/repairing-fujitsu-s2020-ac-jack.html
,and looking at disassembly of other laptops may help also,
http://www.irisvista.com/tech/
(Scroll down)
After you have disassembled countless laptops as I have, you note that there is a simple specific pattern, for all laptops.
My wish is that in the other guides you may pick up on some techniques used, and tools.
(I have seen offers for a S7020 motherboard on Ebay. Know nothing of the sellers, nor reliability of the parts)
A) Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
For this reason you should buy an ESD wrist strap, if you do not already have one.
Average cost is around $3 to $6. Connect the alligator clip to a good ground source.
(I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
I realize not everyone has these laying around. { I feel no need for an Anti-Static Mat}
If the table you are working on has metal legs, connect to an unpainted surface, of one of the legs.
Barring this, place a large metal serving tray, or metal knickknack {Unpainted} on the table, connect to it )
B) Use a multi-compartment container for the various screws you will remove.
If a multi-compartment container is not available, substitute with a clean egg carton.
label each egg holder.
Do NOT mix them up!
C) Make a record as you disassemble. Make notes, drawings, and use a digital camera, or video camera, if available. (Use good lighting)
It's nice to have a record to refer back to in case you are interrupted.
For additional questions post in a Comment.
Regards,
joecoolvette
Jan 22, 2012 | Computers & Internet
How to disassemble a digital camera?
Woody...why do you want to disassemble your camera? This is not recommended unless you have experience working with small parts, have the proper tools, and don't care if it doesn't work after you put it back together. There are videos on YouTube showing various repairs requiring disassembly of a camera you can watch and help you decide wether you want to attempt it yourself.
Oct 15, 2011 | Kodak EASYSHARE Z1485 IS Digital Camera
I have a chinesse blackberry, suddenly when i try to use my camera ...this message appears: "CAMCODER MODULE NOT READY" I need your help please, im from Lima, peru
Hallo! You better go to a service. If u have the abilities, disassemble VERY CAREFUL your phone and try to reconnect the camera. Usually, if it is dropped down, the camera is getting out of its connector on the motherboard. Cheers!
May 12, 2011 | Cell Phones
I have an HP DV6700 Laptop Computer. The internal powersupply prong is loose...How can I fix it?
The laptop needs to be disassembled down to the motherboard, the power plug is not soldered to the motherboard, it is actually a satellite card attached to the motherboard via a small cable. The entire assembly can be purchased on Ebay for under 30 bucks. Below is an example of the listing. I will include a link to an illustrated disassembly guide.
Ebay: http://cgi.ebay.com/HP-DV6000-V6000-DC-Jack-USB-Board-DAOAT8TB8F2-/260636627698?pt=LH_DefaultDomain_0
DV6000 disassembly: http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
Aug 11, 2010 | Computers & Internet
I can not shut my camera off. Every time I do after a one second delay it turns back on. The only way I can shut it down is to take the battery out. This happens in all settings
i think this is a faul of the power button. if the power button remains pushed the camera turns on alone. of the power button. i dont know your specific caera. but its possible to find a faulty camera on ebay but the camera does not have your same problem. you can pull out the power circuit and substitute with your. the care circuit are some a puzzle alle pieces are distintly power circuit lens circuit motherboard flash circuit. open faultu camera that you buy so you can see exactly how you nust do to disassemble the circuit, and later instal the circuit on your camera. its important to protect the circuit from static eletricity. and it s important that you pull out the batterie befor to disassemble.
sorry for my bad english
Aug 05, 2010 | Sony Cyber-Shot DSC-V3 Digital Camera
My laptop acer aspire 5740 is not recognizing its inbuilt webcam when i install driver it asks to plug in the webcam.how will i plugin the inbuilt webcam!!!!!!!!!!!!!. i even formatted it and reinstalled...
The problem may be with the camera itself. It is asmall device that sits behind the screen bezel and is attached to the motherboard using a long flat cable. There are times that the cable itself maybe bad, or the plug on either end. It could be that the plug has come dislodged from the motherboard or the camera itself. To check to see if the cable or camera is bad, you will have to disassemble the laptop to get to both the mounting area behind the lcd bezel and the keyboard and palmrest to sccess the cable on the motherboard. The cable itself may need replacement. I have purchased several of these on Ebay with success.
Jul 23, 2010 | Acer Aspire 5315 Notebook
How do i separate the top part from the bottom part of my laptop. I want to buy another motherboard, but I'm not sure I can do this stuff myself
I don't think you can, maybe you can separate it but how you sure that when you buy a new motherboard is working. Or maybe you can buy the exact design of motherboard is how you back back in. Even user manuals are not put to know how to disassemble the laptop. Only Certified Technician can do that my friend.
Just bring to your nearest HP Computer Center to let them provide all of it, at least you have warranty whatever problems occur again.
Hope this tip might help you.
Sep 23, 2009 | HP Pavilion dv1000 Notebook
Black images
I think the shutter broken.
Your problem is same me.
And now i need some disassembly procedure for replace it by my self.
The technician send, you can disassembly it from front of camera not from back to CMOS.
I only have disassembly procedure from back.
Are you have any disassembly guide from front of camera?
Aug 08, 2008 | Canon Digital Rebel / EOS-300D Digital...
Panasonic AG-DVC10 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
