Question about Craftsman Chipper Shredder Manual Model 247.795850
I need the diagram of the Sears Chipper throttle linkage hook up model no. 247.795850
I have a throttle linkage that I cannot put back together correctly on the engine and I need a diagram to see the way to hook it up.
2 Suggested Answers
  • 78 Answers
SOURCE: I have a 9hp Tecumseh engine on my Sears chipper
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Posted on Oct 22, 2009
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like www.arcolawn.com. You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Joe
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
5 hp b&s runs at idle but when advanced to full throttle it stays at idle. Suspect linkage problem . . . Any answers?thanks jim from lafayette louisiana
It could be the linkage, but the most likely problem is the throttle has gummed up in the idle position. Put thin oil or spray carburetor cleaner on throttle and move it back and forth to work it loose. I've seen it many times after an engine sits for awhile.
May 21, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I had to repair pull cord, in doing so I took the throttle linkage carborator linkages off to get to the pull rope housing. I need schematics to show all the throttle control springs wire hook up to get...
go to sears.com and look up the actual engine number. they have a section for lawn and garden and in there there is a link to their parts lookup and they are very detailed. but you will need a pulse tach to set the govenor back to where it was and if it spun the govenor open too far due to the govenor not being hooked up, it could have came apart inside the motor and you will need to take it to a shop. as far as setting the govenor once you get it all back together, you need to push the throtle wide open and turn the govenor shaft in the same direction then tighten it down. yeah its not hard if you have done it before but if you havent and cant understand what i just said, save your time, and engine and have a shop fix it. and i havent seen a motor in my 9+ years that you had to remove all of that to fix a recoil rope.
Feb 03, 2010 | Craftsman Rear Mount Tiller
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Throttle linkange spring connection
goe to briggs and stratton .com and put your model type and code it will bring up your diagram and that will help.
Jun 27, 2009 | Garden
Throttle doesn't work properly
try sears.com go to parts and enter your mod# from under your seat IE:358. and so on.
Look around for prompts and info for you mower from your entered mod#
May 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
May 19, 2009 | Garden
Location of governor linkage and throttle linkage
Try going to searspartsdirect.com. You can put in the engine number 143.955016 in the model search and it should give you a parts list and diagram for that engine.
Good Day.
Brian
May 02, 2009 | Troy Bilt Walk Behind...
Need Carburator Diagram from connecting linkage
go to sears website you can find any diagram u want once u put in the model number
Apr 04, 2009 | Craftsman Garden
Craftsman Chipper Shredder Manual Model 247.795850 Logo
Top Craftsman Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
Tom Chichester
ray gallant
Are you a Craftsman Heavy Machinery Expert? Answer questions, earn points and help others
