Question about Dimplex DS5603 Heater
Dimplex storage heater works intermittently
I have a Dimplex storage heater. It has an ''input'' dial..which I have set to 7-8 (for cold weather) and a ''room boost'' dial which is set to late boost. it works on/off...even though i don't fiddle with the heater. Recently a friend changed my apartment thermostat dial to ''normal'' and it helped for a while............now it has stopped working again.
Is the operation and function of the heater dependant on the atmospheric temperature?? My apartment is still cold. Or am I doing something wrong?
Cheers everyone
P.S unsure of exact type of Dimplex heater...........says CXL n on it though
2 Suggested Answers
milten1
  • 1304 Answers
SOURCE: This question has already been asked, but I am
it does not relate to the time of day it relates to the temp in the room
as you know most heaters do not run continuously, they cycle on ambiant temp.
the boost setting is actually tweeaking that cycle,
you are actually setting the vairence in the temp setting
each modle is slightly differant but
here is an example
9 late boost, might let the temp differential drop as low as 25 degrees
1 early boost might only allow a 2 degree differential
Posted on Oct 27, 2009
I have economy 7 dimplex storage heaters and last winter they just decided to stay stone cold and not come on one day. can these be repaired or do i need to replace the whole heater? thanks
I belive inside the front cover this a bimetal reset in one of the corners top right I think you have to push this back on it makes aloud click . do this with the power off , have done this but a long time ago . hope this helps
Sep 22, 2011 | Dimplex Heating & Cooling
Hi, I have recently moved into a new flat with simplex storage heaters, however the letting agent has no idea how to use them and the landlord is away. They seem to be really old models which you turn on...
Here is a link to a video that will help you understand the theory of how the Dimplex Storage Heater works. It may be a little newer than the model you have, but it does the same thing.
http://www.youtube.com/watch?v=bXrbk-cPWG0
I hope this was of help to you and tanks for choosing FixYa.
Sep 20, 2011 | Heating & Cooling
My dimplex xms718n storage heaters are not heating up properly - the bottom half is still cold in the mornings what could be causing this?
I have recently had xms718n storage heaters installed and about once a week none of them seem to come on at all. Do you know why?
Dec 09, 2010 | Dimplex Heating & Cooling
This question has already been asked, but I am still unsure .I own a flat with a Dimplex night store heater. It has two dials. One is 'Room Temp Boost' and the other is 'Input'. 'Input' is obviously the...
here is an example
Oct 27, 2009 | Dimplex DS5603 Heater
My dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Feb 01, 2009 | Dimplex Heating & Cooling
Stove quit working. Need instructions how to replace a part
I had a similar problem, am still wating fior answer, I wrote them today and am going to call, it is dimplexCompany who manufactures them, call:1-800-668-6663 ext. 358
For parts : 1-800-668-6663 ext. 360 Hope this helps.............
Dec 11, 2008 | Dimplex Compact Electric Flame Stove...
Dimplex night storer, how does it work?
Are you setting the input to maximum and the boost to late? You do not say what size the heater is in either kilowatts or kilowatt hours eg 2kW or 18kWh. These heaters will tend run out of stored heat in the evening especially in colder weather.
Jun 08, 2008 | Dimplex DS5598 Mid-Size Heater
Early / Late boost in dimplex storage heater
The output setting if turned off isn't adjusting the temperature in the room automatically if its off,and by turning the output up is like turning up the heat.By turning the output switch on you can let the heater automatically control the heat.Still you need to monitor the adjustments to your liking and then you know how hot it will be when you come back into that room.
May 26, 2008 | Dimplex DS5603 Heater
Dimplex DS5603 Heater Logo
89 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
