Question about Sewing Machines
Broken spool pin on my Toyota Quilt 50 Quiltmaster where can I get another
5 Suggested Answers
SOURCE: our toyota Rs2000 quiltmaster 50 is not picking
1.is the needle bent or blunt
2.is there a 2 to 3 inch tail on the bobbin that it can be picked up
3.is there lint or thread fragments in the bobbin aea
Posted on Jul 31, 2010
SOURCE: toyota quiltmaster 50 rs2000 sewing machine pedel and power lead
try sewvacdoctor.com
Posted on Feb 01, 2012
  • 5159 Answers
SOURCE: cant embroider on toyota quiltmaster 50
The Quiltmaster 50 can only do free-hand embroidery. Use the darning foot. Set the machine for a satin stitch with a stitch length of 0 and lower the feed dogs. Manually move the hoop to stitch your design. (Trace the design on the fabric and place on a stabilizer if needed. Center the design in an embroidery hoop and move the hoop under the needle. In my limited experience, all fabrics need stabilizers. Some require multiple sheets of stabilizer.)
Personally, I have trouble moving any fabric under the pressure foot. This is mostly a matter of practice. You have to make a lot of scrap piece trials.
This site has the manual for the Quiltmaster 50 (European version): http://www.home-sewing.com/WebRoot/Store/Shops/homesewing/4AAF/95FA/5ED9/1505/56BA/4D44/240A/754B/QUILT50_0020_EFNI_0020__0020_679111-CEA10.pdf . See page 37 (49 of the PDF).
I hope this helps.
(who actually cheats: I either use an embroidery sewing machine or I use a late 1960s Singer Sewing machine with its Monogramming accessory. This has pre-programmed designs on little discs. That's why I don't practice free-hand stitching.)
Posted on Jun 16, 2012
  • 1564 Answers
SOURCE: how to replace spool pin on model 5160 singer sewing machine
Drill and tap out the broken bit. Put new one in.
Posted on Sep 03, 2012
How to successfully use monofilament thread on Janome Horizon 7700
Generally, it is better to use monofilament in the top, not in the bobbin. There is also a problem with tension so our instructor had us tape a paper clip vertically about midway between the spool pin and the first thread guide on the top of our machine, set the spool behind the machine in a small cup and ran the monofilament through the paper clip and threaded as normal.
May 12, 2017 | Janome Sewing Machines
The thread keeps coming off the take up lever on my Quilt 50 Toyota Quiltmaster while sewing.
take a piece of tape and put the tape of the take up lever or take a pair of pliers and close the take up lever just enough so the thread will not come off. I had the same thing happen on one of my sewing machines.
Nov 26, 2013 | Toyota Sewing Machines
Cant embroider on toyota quiltmaster 50
I hope this helps.
Jun 15, 2012 | Sewing Machines
Stitch too tight on top, too loose on bottom
This is a problem with thread tension. The needle thread is too tight and the bobbin thread is too loose. I don't have one of these machines, but there should be either screws or knobs to adjust. Look at your manual. Here's a page I found on bobbin tension.
https://www.manualslib.com/manual/1022927/Toyota-Quilt-50.html?page=50
Aug 06, 2017 | Toyota Sewing Machines
Our toyota Rs2000 quiltmaster 50 is not picking the bobbin thread up how do we correct the timing
Jul 31, 2010 | Toyota SE-06 Mechanical Sewing Machine
Broken plastic part within which thread spool pin is inserted
You can search for:
Make Model parts diagram
to see what replacement parts are available.
If not, you can probably devise something to improvise. I've used plastic drinking straws as spool pins, or plastic chop sticks.
Jun 27, 2017 | Janome Sewing Machines
Toyota T50 Quiltmaster
You can get a replacement manual from www.IFixMachines.com I've got a 50% off coupon code that may still work savehalf. I don't think toyota is still in business.
Jan 13, 2009 | Toyota SE-06 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
