Question about Pioneer Complete Car Audio Package Dxt2266ub
How do i connect the wiring codes for my dxt2266ub stereo to my car
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pioneer Master
  • 102,366 Answers
See the wiring diagram on page 11 of this manual.
Posted on Apr 19, 2013
16 point connecter radio wire harness on 03 Sonata what are the color codes for Brown white, gray ,brown black, grayblack.
2003 Hyundai Sonata Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/White
Feb 03, 2017 | Cars & Trucks
F5TF-19B132-BA Ford Radio Pin out
The stereo pin layout can be obtained from the car dealership, also a repair manual should have the stereo wiring harness layout in it , the stereo harness adapter for installing non oem stereo, found at the local auto parts store will come with the wiring layout, wires are color coded too, sometimes the stereo harness or stereo harness adapter will have small writing on the wires itself, showing you what that wire is for, and where it should connect.
Basically it comes down to, obtaining the stereo wiring layout, read the description on the wires, and properly connect them together, then solder the wires or crimp them, I like to solder mine with soldering wire for electronics, and put shrink tubes to protect the wires, put the shrink tubes on the wires before soldering together, and ensure the shrink tube is the proper size awg wire gauge.
You will also need, aftermarket face adapter kit and antenna adapter, if installing aftermarket stereo.
Hope this helps and enjoy the stereo :)
Apr 11, 2015 | 1999 Ford Taurus
Eurovox car stereo sudden power out
If it asked for the pin code, it had spent a while without any power feed to it. Slide it out to get to the wires behind it. Check the power wires and any fuse connections to it (usually red wires) by wiggling them and see if it comes on briefly, (it will ask for code again). Wires may be damaged, pinched or corroded. To see if its wires in car or the stereo, take the stereo out of car and connect to a car battery on a table to see if its fine (it will ask for code).
Dec 15, 2013 | Jensen VM9510 Car DVD Player
Radio wiring code for 1987 mercedes benz 300. With aftermarket radio the windows switch ligths blinks and have no instrument ligths.
Hi, the aftermarket stereo does not use the illumination wire. You must tape that wire off (purple/gray). That wire is either connected to the wrong place or is touching chassis ground and causing your instrument lights to dim.
Connect the stereo's red wire to the car's black/yellow wire; and connect the stereo's yellow wire to the car's red/white wire.
1987 Mercedes 300E Car Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Black/Yellow
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Purple/Gray
Car Stereo Antenna Trigger Wire: White
Car Audio Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre Dash
Left Front Speaker Positive Wire (+): Yellow
Right Front Speaker Positive Wire (+): White
Car Audio Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Red
Right Rear Speaker Positive Wire (+): Green
Sep 13, 2011 | 1987 Mercedes-Benz 300-Class
What wire do I connect my after market stereo memory wire to? My aftermarket alpine stereo is connected to a 2006 GMC 1500
You need to get the Wire color code for your pacific stereo and for your pacific car. Your really lucky if they randomly end up to have the same color code. Each speaker has two wires that need to be connected to the car, a negative and a positive. All negative wires SHOULD be connected to only other negative corresponding wires. Not a huge deal but you sacrifice sound quality. There is a "12v + Constant", one on the stereo and one on the car that need to be connected. There is also a "12 Switch" on each end that need to be connected. The constant is continiously running power to your radio to keep the time accurate as well as keep your setting on your stereo. Some have what is called a memory wire, only one, either coming from the car or the stereo that needs to be connected to the constant connection. You also have a thicker gauage wire that is usually black on both ends, but you never know, that needs to be connected. Electricity cannot travel through thin air, it has to be physicially in contact with the ground(indirectly or directly). If your hooking up a sub or an amp I really haven't gone through the proccess, but for a simple 4 speaker and stereo system, that should be all that you need, for more cars. All Different. Some have two costant wires. DO NOT use both to only hook up stereo. You use only one with one appliance the other is for amps, and subs. If you have both of the constants from the car connected to the constant on the stereo your car will not start, and your gauages will short out until one of them is disconnected. If you are only use one, it is a good idea to use the larger gauage wire. The smaller the wire the more risk of fire(in correspondance to the watt to gauage ratio). I hope this helps. Spent all day doing it. Never found a guide. My advice is to call the manufactuers personally because none of the info I found matched up to the other sources I found.
Sep 21, 2010 | Alpine CDE-9846 CD/MP3 Car Stereo
1990 toyota corolla stereo wiring codes i just purchased a sony stereo and i took out the old radio in my 1990 toyota corolla but i cant figure out how to connect the wires i need the color code for...
what you need is to buy a wiring adapter for your car.it only cost about 15 bucks and plugs right in to your original plugs that were connected to your factory radio.the great thing about this adapter is that you dont hava to cut your original plug off just in case if you ever want to reinstall your original back.also the wires that go to your new headunit are color coded to match the exact colors that you connect to your stereo.you can't mess your connection up because all you have to do is connect each wire to the right color,tape them up,connect your stereo and you have music with all of your speakers working like they should and without any headaches.i hope this info helps.take care and good luck, manny
Jul 12, 2010 | 1990 Toyota Corolla
Changing the factory stereo need the color coded wiring diagram
you can buy,well we can,adaptor plugs to connect to the h/unit and to the wiring loom plug.normally its yellow=constant power 12v +,red=ignition feed 12v+,[some are other way round]black=earth,blue=power antennae,grey/greyblack,RF speaker,white/whiteblack,LH speaker,Purple/purple black,RR speaker andgreen/green black LR,,orange =illumination dash lights.Those are our standard colour codings,we get in New Zealand.
Jul 01, 2010 | 2001 Ford Mustang
I want to take out factory radio to install stereo
Stereo dealers have wire harness adapters for almost every make and model of car. It will come with a connector both with color coded pigtails that are usually prestripped. The package will described which wires go where and their color codes. The deck you bought should have a pigtail with color coded wires and they'll match up to the ones on the harness adapter for your car.
After connecting them all properly, you can take your deck with the attached pigtail and plug adapter and plug it directly into your car stereo plug where your old radio was connected...don't forget the anntenna lead as well... Not to difficult...email if you get stuck...
KEN
May 08, 2009 | Sony Car Audio & Video
Problem installing car stereo
THE FIAT BRAVO HAS A STANDARD ISO CONNECTION WHICH SHOULD PLUG INTO MOST AFTERMARKET STEREOS AND THEREFORE YOU WON'T NEED TO KNOW THE COLOUR CODE, IF THERE ISN'T ANY PLUG ON THE STEREO BUY AN ISO PLUG THEY'RE NOT EXPENSIVE AND CONNECT IT TO THE RADIO AND JUST PLUG IT INTO THE CAR HARNESS, YOU DON'T REALLY WANT TO CUT THE CAR'S WIRING
Dec 05, 2007 | Car Audio & Video
Pioneer Complete Car Audio Package Dxt2266ub Logo
51 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
