Question about Amazon Kindle Paperwhite
Kaya firmware i need a firmware for kaya tablet
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
Sep 30, 2016 | Tablets & eReaders
Download firmware for 9xn I need upgrade to 7.0
You need to go to the manufacturers support site for any firmware downloads.
Sep 26, 2016 | Tablets & eReaders
I have a HP tablet that turns on but has a big circle in the middle going around and says cyanogenmod
Your tablet's firmware has been modified with aftermarket software. (users typically do this to gain "root" access on the tablet.) If the software will not load, you will need to either load the factory firmware, or try another aftermarket firmware.
Oct 23, 2015 | HP Tablets & eReaders
Where can i download the firmware for my tablet irulu 10.1 "
Only when a brand like irulu offers an update of the firmware, you can download firmware. But I think now you ask for firmware you even can't use new firmware. I think you have bricked your tablet. But to load firmware, your tablet needs to work correct. If during an update (or while rooting) something goes wrong, you can't put in new firmware, because the tablet does not know what to do with the USB connection or with the memory card holder. Only a workshop with the correct tools can put in some firmware.
As soon as irulu has an update of the firmware they will notify registered users they can download the firmware and they also provide a manual, how to do the update. There are always warnings, if something goes wrong during an update, you can end with a bricked tablet. But if it is a regular update, they also tell you who to contact if something goes wrong.
Try to fine a certified irulu repair centre and ask them for help. (and what it will cost)
Aug 25, 2014 | Tablets & eReaders
I need to know how to Upgrade the Firmware for the Irulu 7" 4gb Mid Google Android 2.3 Touchscreen Tablet
if upgrade is available it'll be shown in setting>developer option
from there directly you can upgrade it
else cannot
Mar 05, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
Factory reset
To do a proper factory reset, you need to re-load the firmware.
The firmware and instructions for your tablet is here.
Support Firmware
Feb 21, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Supersonic 7" touch screen MID Tablet
You need to flash new firmware you can download LiveSuit and
then look for the correct firmware that is compatible with your tablet.
If you search for How to Flash Tablet there will be a video or instruction on how to do it.
Jan 15, 2014 | Supersonic 7" Touch Screen MID Tablet
Forgot password for Craig CMP741e tablet. tried to reset factory settings (holding on button with volume button) but wouldn't do anything
The only way to fix this is by restoring the firmware. There are two different firmware loads for that tablet, depending on the manufacture date. You can download the firmware for the older CM741E from the web site, but the newer firmware you can to get provided by Craig.
You will either need to make a bootable MicroSD card using Phoenixcard, or use a special software called LiveSuit to push the firmware into the tablet.
Oct 06, 2013 | Tablets & eReaders
CURTIS LT7052 TABLET
1.Go to curtis website and get the new firmware package for your device.
2.Google and download TopNotchTablets_Wopadi7_Firmware_Tools_Package because the driver needed is missing from the Curtis website file
3.get windows to NOT recognize your plugged in via USB tablet via the instructions on the curtis firmware instructions
4.point the installer to the correct driver in TopNotchTablets_Wopadi7_Firmware_Tools_Package
5.open and point the firmware application to the unzipped location of the firmware
6. when you see green in #1 then click update firmware,
Jul 18, 2012 | Tablets & eReaders
Amazon Kindle Paperwhite Logo
462 people viewed this question
Top Amazon Tablets & eReaders Experts
Lesley Cameron
Lesley Cameron
castletech
castletech
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
