Question about Drills
My charger for my cordless drill is not working i tried a new transformer by just connecting the wires but it still wont charge
  • 4 Answers
I have a charger for sale. My motor went out on my drill. No more use for the charger. Deansbarn@hotmail.com
Posted on Jun 02, 2013
  • 3 Answers
SOURCE: fixing a cordless drill battery charger
usually transistors have three legs, diodes have two arms all very confusing isn't it? resistors have two arms as well but not three legs or only two legs and no arms its all about arms and legs isn't it do not attempt this repair if you live at home
Posted on Aug 27, 2009
  • 142 Answers
SOURCE: not charging
try wiggling the battery around and see if a light flashes
also look and see if a light flashes when you plug it in
i'm about 98% sure it's the charger
Posted on Oct 20, 2009
  • 11 Answers
SOURCE: I have a JobMate cordless drill and 2 batteries.
I found the Ryobi charger fits the jobmate as well.
Posted on Apr 17, 2010
SOURCE: Coleman 21.6 volt Cordless drill charger won't charge.
MY BATTERYS WONT CHARGE BATTERYS ARE GOOD CHARGER IS BAD.I LIKE MY COLMAN CORDLESS BUT I WOULD LIKE TO GET ANOTHER CHARGER
Posted on Jun 13, 2010
puertobori
  • 7733 Answers
SOURCE: My battery charger no longer works for my
Go To http://www.cmsmallengines.net/mcculloch-c3.html
Posted on Nov 04, 2010
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
I have a model 7450-7468 cordless drill. The charging unit apparently no longer works. Where can I have it checked or buy a new charger?? Kansas City, Mo. 64113
Try www.batteryplanet.com and www.batteries.com. If neither one of these has what you're looking for, google cordless drill batteries and chargers and pick from there.
Happy surfing!!
Nov 22, 2010 | McCulloch Md7d0010 - 18v Cordless Driver...
I have a 14.4 volt cordless drill that when I try to charge the battery the red light goes from a slow to a rapid blinking after about 60 seconds. The battery does not hold a charge regardless of the...
One thing I,ve found with cordless tool batteries is that if they're completely dead, the charger won't recognize them. Try hooking a known good battery with a charge up to the problem battery, terminal for terminal, with small jumpers. Leave it hooked up for a minute, maybe a minute and a half. this should be sufficient to provide just enough charge to bring the battery up to the "threshold level" required for the charger to recognize it. Then, simply charge the battery in the normal way. If this doesn't work, you may need new batteries, or a new charger. Hope this helps you.
Aug 24, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dead DW972 Cordless Drill?
Easiest and safest: take the tool and batteries to nearest shop where they sell Dewalt. Ask the guy to let you use their batteries in your tool and vice versa, your batteries in their tool. DYI procedure:To check batteries: - if you have some multimeter, try to measure voltage and if possible also amps (but only for a fraction of the second, if battery is good, amperes shoudl jump up very quickly) - if you have no multimeter, try to find 12V bulb (check spare bulbs for your car), use wire to connect and it should light up. To check tool: open it up, take some 12V DC source, put wires on contacts inside the handle where battery connects. Pull the trigger and it should work. you can try to put wires directly to contacts on the motor. Follow cables from the switch to motor.
Juraj
May 31, 2010 | Dewalt 12V XRP Battery Pack
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
I have a 12v xrp cordless drill. in the past 6 months i have purchase 3 new batteries. none will hold a charge. what is the problem.
You may want to try a different charger base. Any way you can borrow one so you don't have to purchase first?
If for some reason the charger isn't working well, you may be getting a partial charge and only that.
You may even want to rent a cordless just to try charging your own battery on a different base.
before you buy.
Nov 03, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Aug 10, 2009 | Drills
Charger no light and wont charge
Sorry to give you my opinion, but these chargers are very delicate, I have 4 and can barely keep 2 going. My recommendation? Open it up and look for obvious shorts/loose wires, if no luck then buy another one and return the busted one as if it were the new one. You will end up with two working chargers. PS this is probably fraud...ha!
Matt Giantglobes.com
Mar 10, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Dewalty Charger 18volts
take it back to where you purchase and dont forget bring your receipt
Mar 22, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
48 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
