Question about Kitchen Appliances - Others
Kenmore elite dishwasher, leaking from drain housing
    Problem Solver:
  • 12 Answers
What model do you have and when does it leak? During draining? Washing?
Posted on Apr 19, 2013
  • 1 more comment
  • beau_layer Apr 19, 2013
    It's a new one we just hooked up . Haven't even run a cycle. It leaks when we turn the sink on, it's like it's back feeding from the garbage disposal and running through the drain line and leaking underneath the dishwasher where the drain line hooks to a housing
    665.13963k017- model number
  • Dawn Dunn Apr 19, 2013
    It could be water running down the dishwasher drain hose and leaking from the pump or drain valve of your dishwasher. Run your dishwasher and check for leaks as it cycles. That way you can spot the leak. Also your drain hose runs to your sink drain usually via the garbage disposal. You need to make an arch in the drain hose higher than the point where it drains into the sink. This keeps sink water out of your dishwasher thats called a drain riser. Try this tip first and go from there. Keep us posted.
Why kenmore elite dishwasher will not drain?
If it is connected to a disposal remove the drain hose and check for a restricted area in the hose or disposal this is common also check the drain hose for kinks be sure to elevate the hose before the drain area. If the drain hose is clear and the drain is clear then you could have a bad drain pump in the dishwasher.Most problems are a restricted drain or hose
Jul 22, 2014 | Kenmore 24" Built-In Dishwasher with...
Kenmore elite dishwasher is leaking water from diverter
I think you are talking about the air gap on the sink. If so, the drain line to the disposal or drain is plugged or pinched .clean it out and problem solved.
Jan 05, 2014 | Kenmore 24" Built-In Dishwasher with...
Kenmore elite dishwasher leaking below washer
see this causes and use the common sense. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Sep 19, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore elite dishwasher will not drain completely
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 02, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Periodic water leaking from Kenmore Elite K701
hello Adrian. I am suspicious that the standing drain pipe behind your machine may sometimes over flow. To find out, pack some dry newspaper around the drain hose where it enters the drain line behind the machine. If that newspaper gets wet you will know that the drain is sometimes overflowing. If that is the case, snake that drain or force a garden hose down it and run hot water thru it for ten minutes. J.
Jul 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite Drawer Dishwasher leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppi
Jun 29, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Won't drain water out?
Regardless of the brand, all dishwashers operate on the same principles.. in this case you said you checked for clogs and there are none..however.. have you checked the fileter screen for the drain, the hoses to the pump, the pump itself, the exit hose off the pump, the drain hose coming from the dishawasher to your house drain and is your house drain restricting water flow? Also.. is the pump actually operating at any time? These are the funadamental items to check..any one of them can cause your dishawasher to not drain properly. Hope this helps..
Sep 21, 2008 | Kenmore 24 in. 17594 Built-in Dishwasher
Kitchen Appliances - Others Logo
218 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
