Question about AO Smith Pool & Spa
Can I replace a 1 HP square flange pool pump motor that has a solenoid/capacitor on the outside of it with one that doesn't?
  • 372 Answers
Yes. The one that doesn't have the capacitor on top has it inside.
Posted on Apr 20, 2013
3 Suggested Answers
danielson57
  • 108 Answers
SOURCE: water flows out the flange where the motor
dont no were you are,but did it freeze,loose,gasket trouble,is the centre housing cracked?
Posted on Dec 09, 2009
john224
  • 1378 Answers
SOURCE: I have a AO Smith Century Centurin Swimming Pool
A.O.Smith USQ1152.
Posted on Jan 18, 2010
Will emerson T63AVDDC-1656 motor replace a JANDY FLOPRO 1 HP MEDIUM HEAD SWIMMING POOL PUMP FHPM1.0 115/230v SINGLE SPEED? Thanks!
what you are looking for is a 1 hp square flange motor, and yes that one will work, as long is it the same hp as the origanal moto that came on the pump ! you might consider having the old motor rebuilt, search your area for your local pool pump motor repair guy to insure that it gets done right.
Dec 21, 2014 | Jandy Pool & Spa
New motor, will not start - only hums
voltage set right? motors come set from factory 240 v .. or you might have moved the start switch, it's at 6 0clock on the motor make sure its centered (back of the motor) shaped like a v.. looks like this.click on this
also might be a bad start or run capacitor..or a dud motor
hope this helps
jay the pool pump motor repair guy in longwood Florida
Sep 05, 2012 | AO Smith Pool Pump Motor 1HP Square Flange...
My new AO Smith motor does not have an L1 IT has L2, L3, and L4 so how do I hook the wires?
There is a schematic on the motor itself to show you exactly how to hook it up. The main thing is knowing whether it's 115 volt or 230 volt connection. Good luck any questions hit me back up.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Apr 26, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
A.O smith pool pump tripping breaker
It you either have an impeller problem or capacitor problem on the motor. I would take the capacitor off and take it to a electronic or lexical shop to have them check it. It's only about 15 to 20 dollar pics if it's just your capacitor.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS YOU.
Apr 08, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Wiring a 230v ao smith pump : L1 and L2 connection
Hi, assuming you have 4-conductor wire, use the black and red wires for L1 and L2. It doesn't matter which goes to which. If you do not have a red wire, use black and white. The green or bare wire in a 3-wire cable goes to the ground. If you have 4-conductor wire, the ground wire is the one you used for the GFCI on the breaker--usually the white wire. Please let me know if you have more questions, and thanks for using FixYa.
Aug 08, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
A. O. Smith 1 1/2 hp. motor Type SP. Humms then
You have a failing start/run capacitor. Take the motor to your pool supply place for repair.
Aug 03, 2010 | A.O. Smith Pool Pump Motor Square Flange...
I need a rebilding kit for a.osmith motor mod c48k2pa105 1 hp 115/230
There are no rebuilding kits per say. Rebuilding a motor entails stripping it down and replacing what's bad. whole inside should be cleaned of debris, dust, rust etc. Almost always bearing are replaced. Armature, rotor and stator are cleaned, motor windings tested, start/run caps tested and replaced as necessary. Thermal overload, contactor, relay, centrifugal switch, etc, tested and replaced if needed. You can order bearings and capacitors from several places online, other parts can be harder to find. I local pump repair shop may sell you parts as well.
Jul 14, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
PUMP TRIPS BREAKER, BUT SHAFT ROTATES FREELY
Probably not. Take the capacitor off and inspect it for physical damage and if it looks ok take it to an electric motor shop for testing. Assuming it is ok your motor will probably need work or replacement.
Jul 12, 2009 | AO Smith Pool Pump Motor 1HP Square Flange...
Pool & Spa Logo
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
