Check the manual for the hard drive and make sure that the jumpers on the drive are in the correct possition. if this is a replacement hdd it should be master, if an add then slave.
most drives is jumper on 1-2 for master and no jumper for slave........try it out and try to be as descriptive as possible. thnks
You need to either reinstall windows, or take the drive out and plug it into another computer. You can google NTDLR and download the file from whatever OS you are using and put that in your root directory on your laptop hard drive. Reconnect and you should be good to go.
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Applies to: Microsoft Windows NT, Windows 2000, Windows XP
SymptomsWhen you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
CauseThe error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
SolutionCheck the boot drivesFirst, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
If this does not resolve the problem, you will have to repair the NT boot loader.
Fix NTLDRThe easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
When you say the computer does not recognise the drive, are you trying to install windows when it reports no hard drive found?
