My fan randomly stopped working on my Acer 5734Z
I was just doing what i always do and it just shut off. i noticed the fan wasn't working and have tried everything to fix it but nothing...the fan was always loud and i did clean it but..it still wont turn on...
Loose conector on mother board, needs to be reset,seen this on 5800 and 5700 t models.
Posted on Apr 19, 2013
  • Dante Apr 20, 2013
    Thanks :), hopefully that is whats wrong. I stripped one of my screws and created a whole new issue trying to fix the old one >.> ..
ihwsolutions
  • 137 Answers
SOURCE: Acer Travelmate beeps 4 times & wont boot
Sounds like a RAM problem. Best bet is to purchase a stick of RAM from a store that will let you try it and return it if the problem is not solved. The beeping is a BIOS error code that signifies that something is wrong with your hardware.
If you have 2 sticks of RAM installed try removing one of them and then if the beep code happens again try to swap them out.
Posted on Sep 26, 2009
Testimonial: "Thanks, I'll give that a go! :)"
JollyRoger00
  • 59 Answers
SOURCE: Acer laptop wont start up.
You have corrupted files on your system, either from a hard drive beginning to go bad or from just a bad update, use your recovery console, either available during start up or by using the windows cd to boot your computer and have it run a recovery, you will have to re-apply some of your service packs afterwards. Another option in the recovery console is to use your system save points, if you have the recovery console installed then use it to restore your compter to a day before the update.
Posted on Sep 30, 2009
  • 11 Answers
SOURCE: My Acer Aspire One AOA150 's fan is very loud and warm
I'd suggest that you carefully pull the base of your Acer apart - taking out the screw, and keeping track of them. See if your fan is dirty - I have an Acer as well, and if it's dirty, it get loud, and HOT!
A quick cleaning does wonders!
Posted on Feb 15, 2010
  • 16 Answers
SOURCE: My parents Acer Aspire 5734z-4725
i'm no expert but there is a possibility that you have downloaded a programme that uses the web cam. if another programme is using it the easiest way to solve the problem is to disable the programme using it, what operating system are you using Eg: windows xp??
Posted on Jan 11, 2011
  • 7 Answers
SOURCE: my acer aspire 4745G shut
Using a cooler fan...
Im guessing its not a battery problem?
Go to control panel, then to Power Settings
There should be laptop specific power settings based on how long things should stay on... try and set it to one of the built-in modes to reset everything.
Posted on May 13, 2011
05 Jeep Liberty.. change the electric fan because it wasn't coming on. Fixed the problem for about 7 months. Now it over heats mostly while sitting in traffic.. Get out. move the wire harness con
could be relay but I'm thinking your lines are exposed somewhere between relay and fan and they are shoting out. Thats why it works when you move them. Youi could always electrical tape them (full length) and see if that works. Hope this helps
Oct 26, 2012 | 2005 Jeep Liberty
2002 Buick Rendezvous over heating randomly
Don't worry about the fan. I think you have a bad temp sender unit. Replace that and see if it helps the stalling also. If not, go for an engine analysis. They will check for trouble codes and check engine sensor functions.
Oct 17, 2012 | 2002 Buick Rendezvous
My fan randomly starts up then stops repeatedly
Try cleanig with a can of air. Most likely dust build up.
Computers are always processing, even without user input. Not to mention regulating heat.
Sep 29, 2012 | HEWLETT-PACKARD Computers & Internet
My Acer z5600 just shuts off while I'm doing something without any notice.I gets very hot at the top of the screen and then shuts off without warning.The screen just goes black and I can not turn
Your processor is overheating. Or the fan for the CPU is dead or the way to eject the warm air is blocked. Try to work with your laptop on a table, if the problem persists, is the fan other way you have to work everytime on the table.
Aug 06, 2012 | Acer Aspire Z5600 PC Desktop
After turning on my my acer 2300 its boots up fine but the fan only works for a few seconds then stops and then does not work at all
Normally if the fan is bad and failing the laptop will run hot (overheat) and shut down. If yours is not doing that, then you are fine. Sometimes the fans will turn on and off as needed.
Apr 01, 2012 | Acer TravelMate 2300 Notebook
How iclean my acer laptop cooling fan acer aspire 5734z
ur enternal fan may be not working chek ur cpu fan
Dec 31, 2011 | Acer Aspire One D255-2670
Acer aspire 5000 unexpected shutdowns, random, fan running.
Hello
Thank you for using FixYa.
Have you cleaned out the airvents and fan area. these build up with dust and if the unit gets too hot it will shut down unexpected
Also always use on a hard surface so the airvents are kept clear
thanks
Richard
Nov 17, 2009 | Acer Aspire 5100-3357 Notebook
Computers & Internet Logo
David Payne
David Payne
