Question about Spectrum Digital Spectrum, inc U-30364 NuVue 5.6" Digital Photo Frame
I have a MemoryVue 1040 Plus. I cannot get the
I have a MemoryVue 1040 Plus. I cannot get the remote to work at all. The remote has 7K02A on the back. Is there a battery already installed? If not, what size battery does it take? I have assumed the little thing on the bottom of the remote comes out for a battery, but I can't budge it to find out.
Should I be doing something special?
from,
www.rular@nexicom.net
I need a remote control for a digital picture frame ADS7000PF
You could buy another frame and use the remote for both. Amazon has used for as low as 37.50 and new for 45.
Nov 18, 2014 | Photography
I broke the glass on the digial picture frame how do I get a replacement for MemoryVue MV-800
I'm afraid that Pacific Digital went our of business some time ago, though they are still be sold by Digital Spectrum and others. You can buy a complete replacement for your frame from Adorama Camera through Amazon for under $60, which is certainly less than a repair would cost (http://www.amazon.com/Digital-Spectrum-MemoryVue-MV-800-8-Inch/dp/B000BP8AMY)
There are also nicer, more modern units from many other manufacturers for similar or slightly higher amounts.
Jan 30, 2011 | Pacific Digital MemoryVue MV-800 Digital...
Smartparts the worst ever product I purchase ! My God help me out. Please does any one knows how to check the battery of remote control and his polarity. Otherwise I will throw the dumb product to thrash...
Shrikant:
This may sound crazy, but you can use either a digital camera or camcorder to check whether the Infrared remote control is working or not.
This is because the CCD in digital cameras and camcorders -- or even camera phones -- can "see" infrared light!
Install the battery into the remote and then push them botton on the remote and point the remote control at the lens of the camera or camcorder while the camera or camcorder is turned-on. If the remote control is working properly, you will see the emitter flash on the display of the camera.
If you don't have such a camera, borrow a friend's digital camera or digital camcorder.
I hope that this helps!
Thanks for using FixYa
Jan 22, 2011 | Smart Parts Digital Picture Frame
We've lost part of the AC power adapter for our MemoryVue MV 800 digital frame -- the part that goes from the outlet to the adapter cord that attaches directly to the frame (it's a "two prong"...
I think this is a "figure of eight" power cord, a standard, widely available item. I found a hundred or so right away on Amazon by searching for "figure eight power".
Nov 03, 2010 | Pacific Digital MemoryVue MV-800 Digital...
Uploading photos
Both the thumb drive and the picture frame are USB slave devices, not USB masters. They both need to be connected to a USB master in order to transfer files.
Do you have a standard USB cable from some other device, any other device? If so, that should fit into the picture frame. If not, you'll have to buy one.
Connect the thumb drive to your computer. Create a folder on the computer and copy your photos to that folder. Then connect the picture frame to the computer and copy the photos from the folder to the frame.
If you have two or more USB ports, you can skip the folder and just copy photos from the thumb drive directly to the frame.
Jun 04, 2010 | Pacific Digital MemoryVue MV-800 Digital...
Remote control for Smart Parts 11" digital frame (SKU SP11008) doesn't work. Have changed battery, but cannot get any type of connection between remote and frame. Received as gift over a year ago, but did...
We have to check the remote control first. After that check the digital picture frame.
Follow the instructions below please;
We must be sure the remote control is working;For this control:
1. Take a digital photo of this remote control while pressing the remote control button.
2. If it is working then the picture must shows the led lamp of remote control as firing.
3. If the picture does not show that it is firing, then, you should control batteries of the remote control.
4.Check the battery and the battery polarity of the remote control.
5.If it is firing. You should control Digital Picture Frame.
6. If the battery of the digital picture frame does have enough energy or not. If battery is low then you shoud use it from the closer distance.
7. I do not think that the Digital Picture Frame is out of order.
Regards.
Apr 21, 2010 | Smart Parts Digital Picture Frame
Remote control won't work with the SmartParts Digital photo frame 15". We have changed battery. We have followed instructions on verifying that it is remitting a signal using a digitial camera - it is...
We finally asked the store about our problem. The salesperson finally just gave us a different remote control. Now it works fantastic. I find that the SmartParts Customer did not return our call nor answer our e-mail. So much for their customer service!
Feb 19, 2009 | SmartParts SP15MW (092566981886) Digital...
Not working
i can get mine to work with a 512 mb sd card but not with a 4 gb. I am thinking maybe it cant read sdhc but only regular sd. i wish i had a 2 gb to test this. The manual says max images 512. wonder if that is 512 mb or 512 count. When i put in 4 gb card it says wait and stays like that , 512 card it imeditally shows pics
Dec 26, 2008 | Pacific Digital MemoryVue MV-800 Digital...
Will not display photos
"NOT SUPPORT - RECOMMEND - 640 X 480 60HZ" You can find an update for this problem here:http://www.dsicentral.com/support/800update.html
Nov 03, 2008 | Pacific Digital MemoryVue MV-800 Digital...
Memory Frame model 810
Dis you ever get the firmware upgrade?
Aug 24, 2008 | Pacific Digital MemoryVue MV-800 Digital...
Spectrum Digital Spectrum, inc U-30364 NuVue 5.6" Digital Photo Frame Logo
164 people viewed this question
Top Spectrum Photography Experts
Tony
Are you a Spectrum Photography Expert? Answer questions, earn points and help others
