Question about Computer, Chip, Cruise Control for Ford Mustang GT California Special Convertible
Cruise control won't work
Also speedometer is off by 7 mph
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 47 Answers
One of two things could be the speed sensor on the trans or the wheel speed sensor both cause cruise control problems
Posted on May 17, 2013
2010 Nissan Pathfinder Cruise Control issues
First I'll assume you haven't read the owners Manuel, Cruise control is not perfect on any vehicle. if coming to a hill put foot on gas to help rpm, going down hill put foot on brake to keep same speed, cruise control operates off of engine vacuum. Speed sensors can be affected by putting on smaller or bigger tires than what is on drivers door.
May 24, 2017 | 2010 Nissan Pathfinder
Tip
TROUBLESHOOTING WHY YOUR CRUISE CONTROL DOESN'T WORK
There are many things that can cause your cruise control to act up or not work at all. This article will lead you in the correct direction on finding a solution to your problem. This article is for any type of vehicle.<br /> <br /> <b>If your cruise control won't hold proper speed, </b>you need to look at the following parts. <br /> <ol> <li>Faulty Cruise Control</li> <li>Faulty Speed Sensor</li> <li>Faulty Vacuum or Vent Valve</li> <li>Faulty Stepper Motor</li> <li>Faulty Transducer</li> <li>Incorrect Cable Adjustment</li> <li>A Binding Throttle Linkage</li> <li>Leaking Vacuum Tank</li> <li>Leaking Vacuum servo diagram</li></ol> <b>If your cruise control surges, </b>check the following parts.<br /> <ol> <li>Faulty Cruise Control Module</li> <li>Faulty Speed Sensor</li> <li>Binding Throttle Linkage</li> <li>Kinked Speedometer Cable</li></ol> <b>If your cruise control cuts out on you, </b>check the following parts.<br /> <ol> <li>Faulty Transducer</li> <li>Faulty Cruise Control Module</li> <li>Short or Open Circuit in Cruise Control</li> <li>Brake or Clutch Switch Adjusted too tight</li></ol> <b>If your cruise control doesn't work at all, </b>check these parts.<br /> <ol> <li>Faulty Cruise Control Module</li> <li>Short or Open Circuit in Cruise Control</li> <li>Faulty Clutch or Brake Switch</li> <li>Leaking Vacuum Circuit</li> <li>Faulty Stepper Motor</li> <li>Faulty Speed Sensor</li> <li>Faulty Transducer</li> <li>Faulty Cruise Control Switch</li> <li>A Blown Fuse</li></ol>
on Jul 20, 2011 | Ford F-150 Cars & Trucks
2002 merc villager speedometer doesn't work, tach OK
The speedometer is electronic and controlled by a micro processor, the needle is operated by a special DC electric motor called a "stepper" motor, this little motor can cause this problem as well as the Vehicle speed sensor on the transmission (see photo below), either part can cause the problem, the cruise not working would lead me to believe the speed sensor is defective, but you should have a Check Engine light on and a fault code for the sensor, do you have either? Autozone and others do the fault code test for free, ask for an OBD2 fault test. Here is the picture of the sensor I mentioned.
Jan 29, 2012 | 2002 Mercury Villager
Envoy 2005 XL Cruise control not working
Your dealership should have seen any underlying codes. Most Cruise controls I've worked on are used on the vehicles vacuum. that is where i would start, because on a grade your engine uses more vacuum pressure thus taking from some where else.
Jan 12, 2012 | GMC Envoy Cars & Trucks
Speedometer is working but reading way off
It appears that you need to have the speedometer calibrated. Unfortunately, this is very challenging. You'll need to take it to a mechanic. Dependent on where you take your Envoy it can cost around $75+
Jan 10, 2012 | 2003 GMC Envoy
93 toyota pickup 5 speed, speedometer and odometer work intermit
There is a plastic helical gear in the transmission, where the speedometer cable attaches. Start there. Usually 2-3 bolts that hold it in, when it comes out, some fluid will escape. Check that gear for wear, and broken splines. Then follow the cable up to the cruise control module. Some cars route the speedometer cable to the cruise control transducer, then to the firewall to the instrument cluster. That transducer goes bad. Thats what happened on my 81 olds. The speedometer would bounce around at speeds less than 15 mph. I replaced that transducer and it is steady now.
Nov 30, 2011 | Cars & Trucks
'99 Beetle cruise control surge and speedometer has slight flutter.Occasionally speedometer drops to zero mph and cruise will then stop working. The "surge" is so bad that you can not drive with cruise on....
I would take a blind guess and sat the speedo sensor has an issue. 99' beetle should have an 01M auto, and the speed sensor is also the dipstick for the final differental drive. search around this area of the trans for the cable and snoop around. loose at the trans ? bad connection somewhere??
Dec 09, 2009 | 1998 Volkswagen Beetle
Speedometer Quits Working on Cruise Control
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Impala instrument cluster repair
Nov 30, 2009 | 2005 Chevrolet Impala
Speedometer reading fluctuates
IMHO, I think that the broken cable is what is causing the problems. It "confuses" the programing of the CPU or computer.
Dec 17, 2008 | 2003 Chevrolet Silverado 1500
Computer, Chip, Cruise Control for Ford Mustang GT California Special Convertible Logo
100 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
