Question about Ovens
I am having problems with my Bosch Built-under Oven HBN13N50B. I have had to replace the plastic coupling behind the control knob for the bottom oven as it had broken and the knob just turned around continuously. Having done this - with the oven cover still off - I tested and the knob, the coupling and the metal connection (I believe the thermostat - with wires to the back of the oven) all turn fine. But neither the oven, oven light or the red temperature light come on. The top oven / grill with control knobs on the opposite side and the clock all work fine so electricity is definitely getting through to the oven. Any ideas what else this could be?
3 Suggested Answers
  • 250 Answers
SOURCE: Stoves 720 EF Electric Double Oven Model No
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Posted on Nov 27, 2010
SOURCE: bosch hbn 13n5.1b bottom oven temperature control knob not working
Yes they can be and if your savey they have universal oven switches that do the same thing only much cheaper than OEM parts.
Posted on Apr 07, 2012
Bosch oven cooling fan behind top oven not switching off after using main fan oven
stat problem stat that controls fan function is not openning telling control oven is still hot How Does An Electric Range Oven Work Appliance Repair
Jan 29, 2017 | Bosch Ovens
Control panel is hot
Best dissertation writing services helps the students to complete their dissertation in professional way. It makes them get high grades in their dissertation presentation.
http://essaywriting-servicereviews.com/Forum-Dissertation-Writing-Services-Reviews-UK
Aug 01, 2015 | Bosch 500 Series 30" Built-in Double...
Having problems removing Bosch built in double oven.
Usually the screws keeping the wall oven in its space are through the sides of the oven. With doors open look on both sides for screws that go into the cabinets
Feb 02, 2015 | Bosch Ovens
Bosch hbn 13n5.1b bottom oven temperature control knob not working
Apr 07, 2012 | Bosch Ovens
Neff u1661n2gb/05. main oven not working and shorts out electric when try to switch on. top oven works no problem
I had a problem similar. The bottom oven stopped working and the left hand set of controls and clock died. I had three figure quotes for repair. I took the main control unit out from behind the switches, its a pain to do. I took pictures of where the wires went to save confusion later. I removed the main switch unit from the control unit by gently pushing back the inbuilt plastic clips. dont loose the small white connector piece on the end of the switch shaft. I gently pulled the switch knobs from the front then the knob extensions through the same holes. once the unit was out I turned it upside down I could see where two solder tracks on the circuit board had burnt out. I gently cleaned them up and bridged the gap with two short tinned pieces of single core wire I had stripped. I used a soldering gun as it gets really hot really fast and wouldnt damage the components underneath. the only fiddly bit when putting it back together was locating the bottom edge of the control unit in the little gulley, I had to bend the edge of the gulley down to make it easier. Once it was all back together it worked. Half an hour and I saved £300! Now I have to fix the hinges on the bottom oven door as it doesnt shut properly at the top. Any ideas anyone?
Nov 16, 2010 | Neff U1661 Double circotherm super...
Bosh double oven. Temp is 100 degrees cooler on top oven, any ideas? both on bake mode
The fact that top oven is 100degrees less than bottom is no relation between the two; they are controlled by independent stat controls and if the only way you know if the temp is correct, is to set a temp (such as 350 degrees) and put a thermometer in that oven to see if the thermometer is with in 25degrees of the control settting. You need to do this for the bottom oven as well to see if it is aslo within 25degrees of the setting. then you make adjustments for each unit independently. If the controls are mechanical (knob), then the adjustment is within the control (usually by removing knob and serching for a small screw). If the controls are electroonic, then you need to search the circuit board to see if there is adjstments mounted on the board. Goodluck,Macgivor
Jan 31, 2010 | Bosch HBN 455 Stainless Steel Electric...
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Ovens Logo
53 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
