Question about Electrical Supplies
Orion starts up when button is pushed but shuts down when u release starter button
    New Friend:
  • 5 Answers
When you push the start button it also brings in the fuel soliniod, you should check the relay for the fuel soliniod it is not holding in after you release the start button.
Posted on Apr 20, 2013
Runs when start button pushed for several seconds then shuts down. Starts with button, but when button released, shuts down right away.
Odds are that the ignition switch or wires are giving you the grief.
Thee unit will probably be getting spark power through the starter solenoid (look for a wire there) but when the solenoid is not activated, there will be no ignition power.
Take your time and trace it down.
You'll get it.
Cheerfuls!
Aug 17, 2015 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
Led light is always on even when im driving and the remote start does not work....what do i gotta do....thanks
The LED light always on means the system is in valet. The remote starter should still work in valet so, check your hood pin switch to make sure the pin is making contact with the hood when the hood is closed.
Locate the valet swich under the dash. It's a black push button. Turn the ignition on, press and hold the button, count to five. Release the button, the light should go off. If there is a remote starter shut down installed, it should be located near the valet switch. It's a toggle switch that may still have a red boot over it. Flip the switch in the opposite setting. The remote starter should work afterwards.
Jun 28, 2011 | Car APS997A Two-Way Remote Start and...
My high beam and low beams wont work but the tiny lights right next to them and all other electrical stuff seems fine....wat could my problem be?
Some Yamahas are designed to shut off the headlight while cranking starter to conserve battery power.
I'm not sure your R1 was built that way...but other models have the same problem.......
The starter button has a set of contacts for headlight, and a set of contacts for starter circuit.....as you push in the button, the headlight contacts open first...then as you push further the starter circuit contacts close to crank the starter. If the button does not fully release after starting the headlight stays off. So try WD40 around the button edges and work the button in and out several times with key off....then recheck headlight operation with key on.
Mar 05, 2011 | 2005 Yamaha YZF-R1
How do u wire a three phase squirrel cage motor with a motor starter with a remote start/stop/inch station and warning indicator light ?
You would first run a conductor fromL1 to L1 on the motor start then run a second conductor from L2 to L2 on the moter starter, then run a third conductor from L3 to L3 on the moter starter. next run L1 and L2 to a step down transformer so you can reduce your working voltage to 120vac, then run a conductor on one of the outputs from the step down transformer to one side of the normally closed contacts on the STOP push button, from the other side of the stop button run a wire to one side of the start button, on the other side of the start push button run a wire to one side of the magnetic motor starter coil, the other side of the coil run a wire to the other empty terminal on the transformer, this will be the neutral wire. next you need to run a wire from the normally open contactor on the magnetic moter starter to one side of your push button start switch, then run one wire from the other side of the start push button switch to the other side of the normally open contacts on the magnetic moter starter, this is your start switch latch that will keep the motor running when the start push button is released.I'm not sure how you need the warning indicator light wired up, so please reply and let me know when it needs to come on and go off
Feb 04, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
Mower shuts down when brake is disengaged. Ariens 1030 rider.
you have a kill switch problem its a button that is pushed or released when the brake is pushed or released to prove this take off the starter cover and disconnect the small wire on the ignition coil the mower will start and work fine except you wont be able to shut it off , pull the spark cable off but it will tell you if its the kill switch
Nov 08, 2009 | Ariens Garden
I have an Orion TVD 2710. Need to adjust resolution.
if you have a menu button on tv shoul be able to do it there after you push the menu button then use the up or down button for selection then the volume up or down to ajust then menu to exit. Now if no menu button sometimes you can push the up down chanel button at the same time and get into the menu. Hope one of these works.
Feb 20, 2009 | Orion STV2763 27" TV
Lost codes
Try this turn on your tv manually,Then on the control remote push and hold the code search button until the indicator light stays lit,release the code search button now push and release the device button TV and next you gotta push and release the power button until the TV turns off ( you might do this per about 150 times be patience) when the tv turns off you push and release the Enter button and the code be saved.
Good luck.
May 10, 2008 | RCA Universal Remote Control
My rca control is not working I already change the batteries but nothing happens.Can you help me?
I held down the "VCR" button in the top row and while holding it down I entered the code. Then I released all buttons and pushed power and LOW AND BEHOLD it worked.
RCA- RCR450c universal remote and a Orion VCR
Dec 09, 2007 | RCA RCR450 Remote Control
Electrical Supplies Logo
55 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
