Question about Dehumidifiers
Usa zip code - Dehumidifiers
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
See here.
Posted on Apr 19, 2013
I have attached a hose and set to "CO" for continuous. The bucket still fills up. What else do I need to do?
You will need to unclog the internal drain tubing to the hose connection. To accomplish this, do the following:
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connection hole & tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose to the unit, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose end for water flow. It may take 10 to 15 minutes for it to start flowing. So be patient.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helped you to solve the problem and thanks for choosing FixYa.
Sep 13, 2011 | Frigidaire Dehumidifiers
My dehumidifier is leaking from the bottom. Was working fine. Bucket is only collecting about an inch of water. any suggestions
The problem is due to clogged tubing inside the unit. To solve the problem, do the following:
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
I hope I was able to help you solve the problem. Thanks for choosing FixYa.
Aug 19, 2011 | DeLonghi DE500P Dehumidifier
For 3 yrs. the condensate drained from the unit just fine out of the drain hose . Recently it has been filling the bucket by condensating just above the bucket , and dripping into the bucket , which...
The hose may not be blocked, Ed. But the unit's hose connection and tubing may be.To solve the problem do the following:
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connection & tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose for water flow.
I hope this helped you solve the problem. Thanks for choosing FixYa.
Aug 03, 2011 | Dayton 1DGX4 Dehumidifier
The water will not drain into the storage tank, and insists on leaking out the back. How can I get it to drain into the tank?
The drain tube and or hole that is supposed to drain water into the bucket is clogged. To solve this problem, do the following:
First, turn the Unit OFF & Unplug it.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. NOTE: if you don't have a Zip Tie, you may use something similar, but NO wire coat hangers.
Hope this helps you and thanks for using FixYa.
Jul 25, 2011 | DeLonghi DD50P Dehumidifier
Water misses the bucket and runs out on floor.
The problem you're having is a result of a clogged drain tube.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
Jul 18, 2011 | LG LHD65EBL Dehumidifier
Water on floor after dehumidifier runs for about one half hour either directly drained to sump pump hole or bucket.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers, though.
Hope this helped you to troubleshoot & solve the problem.
Jul 11, 2011 | Dehumidifiers
Leaking..no holes in bucket... sit correctly
From what you have described, it sounds like the tubing that drains water into the bucket is clogged.
1. Turn the Master On/OFF Switch to OFF & Unplug the unit.
2. Remove the bucket from it's holder. At the top of the bucket cavity, you should see a hole or
3. Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though) that is the
appropriately sized to fit into the hole or tubing. Carefully insert the Zip Tie and continue to
push it in until you reach a bend in the tubing. You must gingerly work the Zip Tie past this bend,
until the Zip Tie either bottoms out or you run out of usable Zip Tie.
4. Slowly start pulling it back out while rotating it (twisting it). This will break up any clogs. Once
you start nearing the inserted end of the Zip Tie, be prepared for some water to follow.
Following the steps above, should solve the problem. Please let me know. Thanks.
Jul 05, 2011 | Maytag M7DH45B2A Dehumidifier
I have an LG 45Ely6, the tank was reinstalled properly but it continues to leak. Can you help?
More than likely, the water drain tubing inside the unit is clogged& the water is not going into the bucket as it should. To solve this, do the following.
1. Turn the Master ON/OFF to OFF & Unplug the unit.
2. Remove the bucket and look up inside the bucket holder. You will see a tube or a hole that drains
3. Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers though) that is
appropriately sized to fit into the hole or tubing. Carefully insert the Zip Tie, until you reach a
bend in the tubing. You will need to gingerly work it past this bend, until the Zip Tie either
bottoms out or you run out of usable Zip Tie. While rotating (twisting) the Zip Tie, slowly remove it.
As you reach the inserted end of the Zip Tie, be prepared for some water to follow.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jul 04, 2011 | LG LHD45EL Dehumidifier
Dehumidifier water is not collecting in the bucket but is falling out and is dumping on the floor
Check the collection bucket, to make sure it is installed tightly. If that checks out OK, the drain hole or tube that dumps water in to the bucket is clogged. To clear the clog, remove the bucket and look up under the top were the bucket rests. There will be a hose or a drain tube, Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers), that will fit into the hole or tube, carefully insert The Zip Tie and push it into the hole or tube. The Zip Tie will reach a bend in the tube that you need to gingerly, work it past the bend. Once the Zip Tie bottoms out or you run out of Zip Tie, slowly pull it back out, while rotating it. This will dislodge the clog. Once you have the Zip Tie almost removed, be prepared for some water to follow.
The above should solve your problem. Hope this info helped you.
May 27, 2011 | Goldstar DH304 Dehumidifier
I suspect drain hole clogged. How do I remove the front to access and to clean the coils?
Actually, you will need to remove the back panel of the unit (there are 6-screws) to access the coils.
As far as the drain hole being clogged ... Use an 28" long plastic Zip Tie, sized to fit into the drain hole. If you don't have a Zip Tie, use something similar, bur NO wire coat hangers. Push the Zip Tie into the drain hole and carefully work it in. You will reach a bend in the tubing, but you will have to gingerly work past this bend. Once the Zip Tie bottoms out or you run out of Zip Tie, slowly pull it back out, while rotating it. This will dislodge the clog. As you reach the end of the Zip Tie coming out, be prepared for some water to follow.
Hope this helped you solve both problems.
May 26, 2011 | Kenmore 54351 Dehumidifier
Dehumidifiers Logo
16 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
