Question about Panasonic AG-4700 VCR
Tape will not load
A tape got stuck ejecting - top pressure had depressed the top of the cassette case. I corrected this but tapes will not now load.
  • Panasonic Master
  • 5,259 Answers
Assuming that it's not damaged. The carriage might be out of it's correct position to load the tapes. You need to be certain that it is set up right and not damage. This might require a service manual.
Posted on Apr 24, 2013
Testimonial: "Thank you for the suggestion. It looks clear and moves easily by hand but there is no take up. If it is significant the head is running continuously and the mains switch on the front has no effect."
  • 275 Answers
SOURCE: Tape Ejects Immediately
There are normally 2 causes. One is some obstruction in the tape path. Please open the cover of the VCR and shake and see for foriegn objects. Nothing??? Then there is one more possibility - Belts are loose.. Check the Tape Loading motor belt.Is it slack? This can happen over time.Change the belt.
Posted on Feb 07, 2007
  • 883 Answers
SOURCE: vhs tape gets chewed
Dear William,
the rubber belts and rubber capstan need cleaning/conditioning. you can attempt this with alcohol swabs and if you find rubber conditioner (in the past was easy to find in audio supply stores) apply some of this also. if this treatment does not solve, then may need new rubber belt kit. good luck.
Posted on Dec 27, 2007
  • 1779 Answers
SOURCE: How can I remove a stuck video tape from out of a VCR?
You will have to take the cover off. ( un-plug the AC cord)
Look for the loading motor at the back right side.
Rotate the motor and you will see the tray moving thru its cycle to un-load the tape, it does take quite a few turns, its slow.
Let me know if you run into a problem?
Posted on Apr 08, 2008
  • 52 Answers
SOURCE: Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Posted on Feb 09, 2009
Grubhead
  • 5259 Answers
SOURCE: Panasonic NV HD630 is showing
You have a K-Deck mechanism. F06 means the mechanism locks after unload. The cause of this is the load motor or the carriage alignment.
If you enter "Panasonic K-Deck" into google you should find service information and a guide to getting the tape out - all free!
Posted on Oct 13, 2010
How do i remove a stuck cassette tape from a 1994 chevy truck player?
Does it make noise or move when you hit the eject button? If so, slide a butter knife under the exposed edge of the tape drive adaptor about an 1/8" and hit the eject button. Just a little upward pressure should help it release. It the eject button has no effect, you may need to pull the radio out, open the cover and manually turn the eject drive assembly.
Sep 05, 2014 | 1994 Chevrolet Silverado 2500
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Will not eject cassett
try this unplug and then keep finger on eject and plug back in keeping hold of eject if not work then
UNPLUG and take top off video and you will see were the tape is stuck THERE WILL BE A RUBBER BELT ON ONE SIDE OF MECHANISM TURN COGS THAT BELT ARE ON ( USELY ANT-CLOCK ) takes time you will see parts move towards front of video ( IF NOT CHANGE THE DIRECTION TURNING ) the tape will come out when finished
THEN PLUG IN SO VIDEO CAN RESET MECHANISM
Nov 08, 2009 | Cell Phones
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Cassette ejection mechanism not working
pull the player and have it repaired, sounds like the belt is no good for the tape drive loading mechanism.
Apr 13, 2009 | 1999 Ford Taurus
SLV 940 HF
Is it having trouble either loading or ejecting the tape? If so, then something is probably awry in that mechanism. Take the top cover off and watch a load or eject operation. If tape isn't fully loaded, and tape threaded, then an error condition will result, as will be the case if it won't eject. Causes include a broken piece of the load mechanism (also called cassette carriage or carriage mechanism), broken or cracked gear. If the mechanism is gear driven, timing is critical, just being out of time one tooth will foul things up. There are often marks on the gears which must line up exactly in a particular mode as specified in manufacturer service literature. Most VCRs since the early '90s are disposeable, very prone to breakage, in contrast to early units which were made like tanks, costing $400 plus.
Aug 26, 2007 | Sony SLV-940HF VCR
Tape keeps ejecting - panasonic nvfj620
Is it only the Head cleaning cassette which keeps getting ejected, or is it happening with every tape you insert? Was the Head Cleaning Tape a little tight in the Cassette compartment? Did you have to put some pressure to push it in or did it come out with difficulty? From your symptoms, it looks like there is a gear timing problem with the cassette loading compartment gears. It could also be due to some obstruction inside. try shaking the VCR, and if you are hearing some noise, Open cover and check for foreign objects.
Apr 25, 2007 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic AG-4700 VCR Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
