Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
It won't spin out everytime and unlocks by self while running
I have a similar model HE doing the same thing. I just had a friend to look at it and when he pulled out the machine there was nut on the floor that apparently belonged to the screw that was holding the pulley in place for the belt. The belt was totally off. He put the belt back on, but it is still not spinning. So I think you shoukd check that. I've only had my washer for 1 year and 3 months.
Posted on Apr 20, 2013
My kenmore ad 80 series washing machine won't spin
The lid switch is probably out. Bypass it and see if she magically comes to life. Their are 3 wires to the lid switch 2 of which are live wires. Jumper them 2 live wires and see if she runs in spin.
My home video: Washer won't spin It's a doozy
Jul 20, 2012 | Kenmore Washing Machines
How do you clear code P0440 after you change gas cap
if the gas cap was the problem it will clear it self in a week or two .Or you could take to the auto parts store and they will do it for free .You need need a reader or scaner to clear it I also have a 96 chevy and get this code from time to time it means that there is a small leak someware in the EVAP system or some times it sets off falsey . This system runs 8 differant self tests everytime you start the vehicle . But P0440 isn't a code to worry to much about it won't damage your vehicle in any way
Apr 18, 2012 | 1996 Pontiac Sunfire
My philps Dvd player won't work correctly
From the description the pladder motor is bad, " disc spins on" or it is missing the 5 volts that drives the motor. The laser pickup that pops up and down appears to be working fine.
Apr 13, 2012 | Philips PET741 Portable DVD Player
Ge gas oven ran self clean door won't unlock door locked flashing lock motor running continuously
if your motor is running continuously, the door is locking and unlocking. catch it when unlocked, and unplug the range. then disconnect the power wires from the lock motor. this will allow you to use the oven while you get a new lock assembly and replace the one you have. should be fine after that.
Feb 04, 2012 | GE 25 in. GSC3200GWW Free-standing...
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Oven door won't open after self cleaning cycle
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Aug 13, 2011 | Viking 27" Professional Select Built-in...
The oven door won't unlock even though self-cleaning has been cancelled
heatman101
Aug 10, 2011 | Frigidaire FEB27T5D Electric Double Oven
My MegaStorage Sony CDP-CX250 won't play any CD. The carousal turns to loading position, the cd is loaded, but nothing more happens. It can't spin at all. The CD is then unloaded again. The...
I would check the drive is not blown, as that is what sounds like has happened
take a 5v dc feed and run two wires to the motor to see if it spins up ,if it doesnt spin replace the motor , if it does spin then the problem lies else where in the circuitry
Jun 25, 2011 | Sony CDP-CX250 CD Player
Forgot the parental code how do we reset
Hello
Just unlock its Parential contol and reset the TV. NB: You must have its original remote control handset to proceed. If you haven't it with you, just boroww it from somone you know, who have the same model number of Tv; just to unlock it. After unlock, you can use universal remote or so.Proceedings are:
Most GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
Jun 02, 2011 | GE GTD120 System
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
May 31, 2011 | 2006 Pontiac G6
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
