Question about Delphi Fuel Injector Saturn Sc2 2002 2001 Sl2 Sw2 Car Parts Auto Fj10571
I have a 2002 saturn sc2 series replace cooling fan 3 times , replace relay and fuse but still blow fuse and fan not working could it be the connctor to the fan runs hot in traffic but fine on interst
The cooling that is in there now won't work was told that there is no juice coming out from the connctor that connects the cooling fan; I also replaced the third cooling fan fuse and cooling relay at the dealer still not working blew fuse again. need help to narrowing it down if its the cooling fan connctor I know it's electrical problem cause its blowing my fuse but what. had two ASE repair guys couldn't pin point the problem don't like spending money to have it looked at and can't noone tell me what's going on.
2 Suggested Answers
  • 689 Answers
SOURCE: 1999 gmc 2.2L sonoma, replaced crankshaft sensor twice, code p1336 still there and won't clear
If you didn,t use the code reader to delete the code after it was replaced, It will take a while for it to (Clear) Some codes will take up to 3 weeks to clear, Depending,On how many times the car was starded up end Stoped,
Posted on Nov 06, 2012
I have 2007 Suzuki XL7. I replaced radiator and fan assembly. Fans do not work. Is there a relay? If so, where is it?
Most fan and Ac relays are located in the under hood fuse and relay box. Adequately marked in owners manual or on plastic cover
Sep 03, 2016 | Suzuki XL7 Cars & Trucks
Removing gearbox
Here's your book info is below...
Most auto parts stores carry Haynes Manuals. You can order them from Haynes if needed. Or...often they are carried in your local library.
I have done Ford and Toyota clutches using these books. Clutch replacement is not hard, just time consuming...And easier if you have a lift.
Note: If like many vehicles, don't forget to replace the engine rear main seal while you have access with the fly wheel off.
You can call Haynes and ask specifically if the book covers the repair you are attempting. I have called them to get more specific wiring diagrams not always provided with the books. Very helpful in providing tech data... I have a Haynes manual for all my vehicles...makes maintenance and repair much easier than researching every I need to do something to my vehicles.
Best of luck finding the information you need...
Here's your book info.
Saturn S-series Haynes Repair Manual Online covering all 1991 thru 2002 models of Saturn SL, SL1, SL2, SC, SC1, SC2, SW1 and SW2
Part Number #E87010
Haynes Repair Manual Online for the Saturn S-series covering all 1991 thru 2002 models of Saturn SL, SL1, SL2, SC, SC1, SC2, SW1 and SW2 has clear instructions and hundreds of photographs to help you perform anything from simple maintenance to basic repairs. Whether you're a beginner or a pro, you can save big with Haynes!
Complete coverage for your 1991 thru 2002 Saturn S-series (SL, SL1, SL2, SC, SC1, SC2, SW1 or SW2):
--Routine Maintenance
--Tune-up procedures
--Engine repair
--Cooling and heating
--Air Conditioning
--Fuel and exhaust
--Emissions control
--Ignition
--Brakes
--Suspension and steering
--Electrical systems
--Wiring diagrams
Dec 11, 2013 | 1993 Saturn SW1
The cooling fan on the 02 saturn sc1 is not working and the vehicle is overheating. I changed out the fuse and relay and no luck. I noticed the wires the plug into the fan had been laying on the exhast...
did you find a reslotion to this? I have the same problem, replaced relay, fuse, fan and thermostat. it worked fine for about 30 minutes and fan quit again!
Sep 05, 2010 | 2002 Saturn S-Series
Cooling fan wont run. checked fuses and relays, replaced fan and still wont come on????
Are you getting a check engine lite? It could be the coolant temperature sensor that signals the computer to run the fan. Good Luck Darrell S
Jun 08, 2010 | 2002 Saturn S-Series
2002 saturn sc2 won't disengage out of drive
These cars have a safty measure that if a fuse in the fuse box that gets blown or removed it will lock out the tranny..check the fuse box located on the passenger side of the car next to console
Jun 03, 2010 | 2002 Saturn S-Series
How do I locate and replace the cooling fan relay(S) 2002 Saturn
The cooling fan relay should be in the under hood fuse block.Remove the cover and on the back of the cover there should be a label that shows the fuses and relays and what system they protect.Just remove the one that is for the cooing fan and install the new one.Hope this helps.Good luck.
Mar 22, 2010 | 2006 Saturn L300
My saturn l300 keeps blowing the #2 cooling fan fuse 30a
wiring may be shorting to a ground somewhere check wiring harness and connectors for a ground fault!!swampratt200!!AAAEE!!!
Jul 21, 2009 | 2002 Saturn Sl
I have a 1999 concord, the radiator cooling fan 30 amp fuse keep blowing. I replaced the relays but didn't solve problem
You either have a short in the wiring, or the fans are bad. If you unplug the fans, does the fuse still blow? If not, you need the fans replaced. If so, you have a short in the wiring somewhere.
Jun 05, 2009 | 2002 Saturn Sl
Radiator cooling fan 30 amp. fuse keep blowing
The fan may run with jumper wires but if it''s blowing the 30 Amp Maxifuse it's needs a new or used fan motor.It's pulling too many amps.I have almost never seen a fan relay concern.Only other thing you may check is the wiring down near the fan shoud I have seen the 2 wires get loose from the conduit & melt onto exhaust manifold.Hope tHis Helps
Apr 26, 2009 | 2002 Saturn Sl
Delphi Fuel Injector Saturn Sc2 2002 2001 Sl2 Sw2 Car Parts Auto Fj10571 Logo
19 people viewed this question
Top Delphi Car Audio & Video Experts
Lawrence Oravetz
Sam Bedggood
Andrew Taylor
Andrew Taylor
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
