Question about Craftsman Garden
How to ajust front wheel alignment on a GT 6000 craftsman riding garden tractor
5 Suggested Answers
  • 79 Answers
SOURCE: Craftsman DGS 6500 garden tractor won't engage
Hi
There is a pin in the back by the hitch - make sure it is pushed in. If it is pushed in then check to see if there are any oil leaks under it.
Posted on Apr 10, 2009
  • 148 Answers
SOURCE: How to remove snow blower from Craftsman YS4500 garden tractor
Go to www.managemyhome.com to download the manual for free. Just type in the model # 944606950.
Posted on May 21, 2009
  • 110 Answers
SOURCE: craftsman riduing tractor turns over but won't
If you have spark and compression, the only thing left is fuel.
Check that fuel is being deluvered to the carb (remove fuel line to carb and make provision to catch ejected fuel. Crank engine. Fuel should be pumped from the tank and out the open line at a good rate.
If this checks out (or there is no pump fitted, but there is fuel issuing from the pipe), check the electrical connector on the bottom of the carb. There should be battery voltage on this conection for the engine to run - if not - that's the problem.
If that checks out, the cut-off solenoid (fed by the connection you just checked) is suspect.
Posted on May 09, 2010
  • 19 Answers
SOURCE: Craftsman Lawn tractor - When turning to the left
the steering rod from one wheel to the next might be bent. it bends easly ,the daves mower shop in clarksville tn. always keeps them on hand.
Posted on Jul 19, 2010
The lawn tractor hit a post and now the left front wheel is out of alignment. How can I make it aligned?
the steering tie bar (goes from left to right steering brackets and makes the wheels steer together) should be straight. if it's bent, that is your problem.
Nov 07, 2014 | Craftsman YT 4000 42" Briggs Stratton 24...
How to align front wheels on Hsqvqvarna 48
No ajustment, set at factory. Look for wear parts.
Oct 27, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Front wheel alignment
Wheels are to straigten. Best to replace.
Jun 11, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need to ajust the deak hight on a craftsman lt1000 riding mower
i think that model has a plastic cover just above the foot rest on each side and the adjustment is behind there
Apr 26, 2012 | Craftsman Garden
How do you fix the front wheel alignment on a 48 inch lawn tractor by Craftman. The wheels are turned to the outside. Theres no bent rods or anything. Whenthe wheels go one way in the frony. you mow the...
make sure tie rod between wheels is straight. if bent will cause wheels to turn outward. take tie rod loose at each wheel, straighten rod reinstall wheels should be straight.
Aug 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My Craftsman GT 6000 (20 Hp) lawn tractor has lost its front wheel. The cotter pin is worn and loose; it has fallen out of the slot and will not securely sit in place. The cotter pin is ring like, it...
The item you are referring to is called a snap ring. You can purchase a small collection of snap rings from you local hardware store or automotive dealer. These snap rings can be viewed at the bottom of this filehttp://www.rotorclip.com/cat_pdfs/de.pdf or ordered from http://www.rotorclip.com/.
These links should get you the information you need to go to the local hardware store and get your parts.
Aug 01, 2010 | Craftsman Garden
Need a manual for Craftsman GT 6000 Model 917.255980
07/21/2010
The manual for the Sears Craftsman GT6000 Garden Tractor Model Number 917.255980 is available as part number 137979 from:
http://www.searspartsdirect.com/partsdirect/
Jul 20, 2010 | Craftsman Garden
Problem for Craftsman 20 hp 42 in. Deck Lawn Tractor - ca model wheel alignment: both wheels point outwards
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
May 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My front wheels are suddenly out of alignment. I
There are plastic bushings on the front wheels that get worn over time. Pull the front wheels off and inspect them to see if they are still intact.
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
397 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
