Question about Crosley 0187SST Turntable
Where do I find a replacement belt for cr249 - Crosley 0187SST Turntable
  • Crosley Master
  • 5,190 Answers
You need to measure the diameter and thickness of the belt in mm. Please make a note of how the belt fits before removing it. You can search for the belt by putting the measurements into Google they don't have to be spot on!
Posted on May 19, 2013
I replaced my needle on my Crosley CR249. Now, there is a lot of static. Any idea what to check next!
The diamond tip on the needle is most probably been damaged. Check the tip for any significant visual issues with a magnifying glass.
Nov 11, 2016 | Crosley Audio Players & Recorders
Crosley cr249
are you using a standard microphone jack? like a 1/8" if so this is most likely the problem. also what program are you using. i recommend audacity.
Jun 19, 2008 | Crosley 0187SST Turntable
CR249 sounds noisy
I don't think it's the cartridge, but if you want to replace it to see if it does correct the problem, by all means do. If it doesn't you just have a spare.
Intermittent faults are hard to solve. Some are caused by bad soldering. Most are caused by a faulty semi-conductor - transistor or IC, which sometimes overheats. If the noise starts up after playing the unit for a while, a hot part could be the cause. If the noise is in both channels then the cause is something common to both channels, perhaps the power supply. However some IC's have both channels going into them, so one of them could cause the problem.
A overheating part is easy to find for when the unit is switched off, you can touch the parts inside. This will reveal that a part will be still hot to the touch (don't burn yourself). Some parts will get hot, but anything that's really hot and meant to be will have an heat sink on them. Any part very hot (with no heat sink) to the touch will be faulty no-doubt.
Mar 11, 2014 | Crosley CR249TA Turntable
Platter on my CR249 is distorted, not level
Is it made of plastic, it is probably warped. Put it on an flat table to check; both sides. If that's not the issue, it could be a spindle bearing bad or loose. For more information, or should you have any further questions, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you.
Sep 07, 2013 | Vestax PDX-2000MKII PRO Turntable
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
CROSLEY CR249 KEEPSAKE AUX TURNTABLE STOPPED SPINNING
if it's belt driven, then your belt has fell off.
Jul 07, 2012 | Crosley 0187SST Turntable
My cr249 model record player is turning on, but not spinning. it's been working fine until today, what do i do?
The chances are that the drive belt has either broken or come off the pulleys on the underside of the turntable platter and the motor.
You will need to access the underneath of the turntable to do this.
How you do so varies from one model to another - some you can just lift the top plate off the wooden base, others you will have to turn the whole thing upside down and unscrew the bottom.
With some turntables you lift off the rubber mat from the platter to expose a couple of little holes through which you can access the drive system.
If the belt has not actually broken you should be able to put it back onto the pulleys. However, the fact that it has come off indicates that the belt has stretched and you should replace it. There are plenty of suppliers on the internet (Amazon is usually worth a try) where replacements can be found
Feb 01, 2011 | Crosley 0187SST Turntable
New crosley CR249-GR "wow and flutter"
I see your message isn't new anymore but Crosley does have a website with warranty and support info:
Crosley Radio
Jul 14, 2009 | Crosley CR248 Turntable
Crosley 0187SST Turntable Logo
133 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
