What is c0920 error code on Imagistics copier?
The has c0920 error code we were trying to figure out wht part is needed to fix the copier . I think it is im3520 model . Thanks for the help
  • 145 Answers
Check you trays ?
Posted on Mar 18, 2009
Imagistics all in one copier/fax/scanner im2520f. All is working except the scanner which is giving error code EA21F7.
Try restarting your printer to see if the scanner lense moves properly and not jammed next you need to download the latest driver and suite from manufacturer`s website which shall definatly solve your problem.
Sep 30, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Error code C0110 on imagistics copy machine which model number is C650
The only reference to that particular code is:
C011
Backup memory problem
Problem with thebackup memorydata.Defective backup ram.
Jan 21, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Imagistics dl270 code c0070
A error code C0070 means that the toner bottle can not find home position. Did you just install a new toner bottle??? If so, carefully remove the toner bottle and close the front door and let the copier warm up... Once it is warmed up install the toner bottle again.... If it will not clear you have more of a problem with the toner hopper... Good Luck
Jun 08, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
Imagistics Error Code C-0B77
May want to check the stapling unit and hole punch. To reset open close front door. After openclosing finisher door
Jul 03, 2009 | Office Equipment & Supplies
Error code C0820 Call for help
This code don`t exist in Minolta .C0920 is first drawer lift up motor failure.Open and close the front door or set the power switch to OFF then ON.
Mar 19, 2009 | Minolta Di3510f Bizhub Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
C0920
c0920 is the 1st paper drawer motor.
since the paper jammed the motor path, so the paper deck cannot come up, just pick up the paper n re insert the paper deck..problem solved..
Jan 19, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta CF900
this problem is relate to one of your paper cassette probably the second one....
Try this : power off your copier, pull out all the paper cassette and then open your copier when it's done wait till your copier show ready or your error code, then open your front door and close it right away....After, pull just one paper cassette in it and wait to see if your paper been brought up, if so try the 2 one and so on....You probably have a bad mechanism to bring your paper up.....With this method you'll be able to see witch one of your cassette have a problem ! With that you'll be able to make your copier working again, just to leave the defective one out of the copier.....
Thank you !
Mar 27, 2008 | Office Equipment & Supplies
662 people viewed this question
jasbo
jasbo
