Question about Tascam Computers & Internet
Tascam us 244 software
Installation software
  • Josh James
    Josh James Mar 14, 2016
    Hi Bob Lloyd, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Tascam 244 to imac G5 via line in
This will work just fine. There may be a little hum and noise but this is to be expected from this kind of signal input. Alternatively you would need to get a specialist audio input device. I can recommend M-Audio devices
Mar 28, 2012 | Computers & Internet
I connected everything for my tascam us-122. I installed ASIO4ALL and it says everything is installed correctly yet It's not picking up anything from my mic?
hi there,
there can be a number of issues here. if its not picking up anything it may be down to your DAW software. what are you using to record? check the preferences of that software program to make sure it is accepting audio from the tascam unit and playing back through the desired output.
also for primarily windows go to the control panel and check that the audio devices are set up to use the tascam rather than the built in audio.
manuals and driver downloads can be found here...
http://tascam.com/product/us-122/downloads/
as asio4all is tempremental and dosnt work for all like it boasts.
Jan 20, 2011 | Tascam US122 Audio/MIDI Interface with...
I WANT TO INSTALL TALLY 9 AND USE IT WITH OUT INTERNET CONNECTION WILL IT BE POSSIBLE. HELP
To activate your license offline follow the steps shown: Go to Gateway of Tally ???? Press F12: Configure > Licensing > Offline > Activate The Activation Form appears ???? Enter the Serial Number in Serial field ???? Enter the Activation Key in Key field ???? Enter the Email ID in E-Mail field ???? Tally displays a message indicating that the tally_req.lic file has been successfully generated. ???? Copy tally_req.lic file available in the Tally folder to a floppy/CD ???? Paste tally_req.lic file to another computer with Internet connectivity and Tally installed. ???? Start Tally ???? Press F12: Configure > Licensing > Offline ???? Select Send External Request to send the request file to Tally Licensing Servers. The response file called tally_resp.lic is generated and saved in in the Tally folder. ???? Copy the tally_resp.lic file to a floppy or CD and paste the file into the Tally folder where the license has to be activated. ???? Start Tally ???? The Register Now screen appears, ???? Press Enter to work on Tallly
important:if this information was helpfull to you please vote for me and write a comment for me.
Sep 02, 2010 | Computers & Internet
My Tascam 244 at first attempt to play will not
This sounds like the drive belt has weakened with age. Will have to be replaced.
Feb 19, 2010 | Audio Players & Recorders
Hello i have a tascam 244 which is a four track tape recorder it is quite old i have sent it to tascam to have it fixed before but now it is not working,the metre lights come on for each track and the tape...
Since there is movement in the meters, the heads are good. Look first for any cables or connectors that are loose. There is an "output" section in these that can fail. I don't recall whether this section is an IC or discrete components though. Check the cables and connectors and update this with what you find. I'll look up this model and find the output parts.
Dan
Mar 31, 2008 | Audio Players & Recorders
Replacing capstan and flywheel belts- tascam 244
Surely you can take it to any electronics repair shop and get it replaced, also they will tell u the necessary replacemnts to be done. All the best.
Thankyou...!!!
Feb 05, 2008 | Audio Players & Recorders
Computers & Internet Logo
120 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
