Question about Marantz Acm1h Audyssey Microphone Onkyo, Denon, Setup Microphone
Audyssey mic for onkyo tx-sr307 - Marantz Acm1h Audyssey Microphone Onkyo, Denon, Setup Microphone
When I press standby on my onkyo txsr307 it switches off and what will it be
Hi Geoff, is it going completely off and not going in standby? Thank you Onkyo USA
Sep 25, 2016 | Onkyo TX-SR307 A/V Receiver
I have a onkyo tx-sr307 receiver, I can't remember
Download the user manual to this set. Clcik here to dowload. It has all the details.
Apr 21, 2012 | Audio Players & Recorders
Upon powering up my Onkyo TX-SR605 receiver, it enters Audyssey setup mode even though the microphone is not plugged in. Even if I plug in microphone and remove it, it still stays in Audyssey mode and I...
I have the same problem and it is not speaker wires, cables, or dumb remote codes (really, remote codes.) I'm taking mine in for repair, and not reliying on straw grasping, speculative solutions.
Jan 25, 2011 | Onkyo TX-SR605 Receiver
It appears that sometimes it takes longer for the picture to come up. A lot of times, before it does, the sound cuts in and out. The receiver says "audyssey" on it which I have never noticed before. Is...
I talked to a tech guy for onkyo and he said the delay is due to the heat produced from the unit. The hdmi connections take the brunt of the very hot running onkyo. Send it back in as it will only get worse. When you get it back make sure it has plenty of air flow.
Feb 10, 2010 | Onkyo TX-SR606 Receiver
Audyssey vs Direct switching on Onkyo SR606
Audyssey is the licensed feature this receiver uses for room and dynamic equalization. It sounds like the Audyssey process is activated. The manual says the Audyssey indicator "flashes during automatic speaker setup".
Has this unit ever worked or are you still setting it up?
Feb 09, 2010 | Onkyo TX-SR606 Receiver
Audyssey won't initialize the left rear channel speaker input during set-up
had the same problem found that the rear speakers were connected to the wrong inputs on the receiver, try changing them i think you will find that this will work
Aug 28, 2008 | Onkyo TX-SR605 Receiver
Onkyo 875 Audyssey will not detect
no solution from me but just to say i am having exactly the same problem - did you get anywhere with yours?
Jul 10, 2008 | Onkyo TX-SR875 Receiver
Marantz Acm1h Audyssey Microphone Onkyo, Denon, Setup Microphone Logo
32 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
