Question about Fujitsu Siemens Magneto-optical MCC3064SS Internal Magneto-Optical Disk Drive
MCC3064SS Interne Magneto-Optical Disk Drive Driver Win7
My cd drive will not read or write cd i put in a cd and my drive will not read the disc. it will not start
Remove it from Device manager by right clicking and saying uninstall and restarting your system then it will install the driver again and noe it should work normally.
Mar 15, 2014 | Toshiba (WMD070AC) Magneto-Optical Disk...
My pc does not recognize my dvd player
Right click on the MYCOMPUTER go to manage down go to device manger then go to the dvd/cd rom and select it right click on it and say uninstall the device it will ask confirmation say yes and then it will ask for restart restart it now should be cool and working after restart it will install a new fresh driver.
Feb 10, 2014 | Toshiba (WMD070AC) Magneto-Optical Disk...
Dvd not burning
Sony made burners that required caddies a while back. And by looks of this post they also made special discs, listing for as much as $73 ea. Besides, magneto it more like tape.
Yours drive is a regular HP laptop burner. They are not compatible. You can get blank DVD's for $.50 each.
Oct 21, 2012 | Sony Disc R/W Magneto Optical 5.25 in....
My computer see the unit and this not work S561 Magneto Optical Drive not driver for download for sony company.
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Jun 07, 2011 | Sony RMO-S561 Magneto Optical Drive -...
Drive not recognising MO disk. Orange light flashing endless.
Your drive is not spinning up because of ither a read channel calibration error- or a focus servo error- assumimng your using the same media you always have been- and its not REALLY dusty.
Read Cal failure is caused by the controller and the Focus Servo Failure is caused by the optcs module-
repair cost $285 for either.
At Optical Storage Repair
osrsinc@charter.net cheapest , fastest and best.
Aug 13, 2010 | HP SureStore Optical 9100mx (C1114M)...
Why wont my computer read an optical disc?
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1369348
visit it..it may solve your problem...
Feb 05, 2010 | Toshiba (WMD070AC) Magneto-Optical Disk...
How to fix optical disc problem on my sony
... and your problem is _______________________
... and the error-messages you see are ____________________ ???
Nov 10, 2009 | Sony RMO S561 External Magneto-Optical...
C1114 cant read optical disk
I don't think the drive can be adjusted or calibrated. It's dependent on the operating system and the drivers it uses.
It could be the drive itself needs to be replaced so that it can read the format you need.
Is there a way you clean the thing?
Aug 12, 2008 | HP SureStore Optical 9100mx (C1114M)...
Fujitsu Siemens Magneto-optical MCC3064SS Internal Magneto-Optical Disk Drive Logo
83 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
