Question about Aiwa Tablets & eReaders
AW920 tablet will not power on
I press the on/off button and it tablet will not power back on even after being fully recharged.
2 Suggested Answers
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
My son's tablet is less than 4 months old and it keeps shutting off even when fully charged. It is a 9 inch nextbook and was purchased at Walmart.
Hold the volume UP botton down when it is OFF, then while holding that button down press and hold the power on button and keep both pressed for about 10 seconds. Then release.
Feb 23, 2017 | Nextbook Tablets & eReaders
Tablet will not turn on even fully charged and I just bought it for christmas
I had something similar happen with mine, and after searching online for the solution, I discovered that holding down the power button while pressing down on the volume bar at the same time somehow trips everything back into operational mode. It may not work the first time, it didn't with mine, but just keep pressing both at the same time and sooner or later you will have a screen appear and be able to use your tablet once again. Hold both down and press repeatedly.
Jan 11, 2016 | Tagital Tm 9" Android 4.0 Tablet PC...
7" Tablet. How do I hard reset my tablet ?
Start with the tablet fully powered off (not just in standby). To force the tablet to a fully off state, hold the power button pressed for until it powers down. This can take 10 to 20 seconds.
Hold the volume up button pressed (some devices may use the volume down button), and then press and hold the power button, until a small menu appears. Release the power button and then the volume button.
Use the volume up/down buttons to select the required menu entry, and then tap the power button to action the selection.
Apr 04, 2015 | Tablets & eReaders
Tablet got frozen on go screen so I pressed reset now it won't do anything not even turn on
What tablet brand is it? Need to configure reset duration on hold buttons
Feb 02, 2015 | Tablets & eReaders
How do i factory reset my digiland tablet
here is a step by step I found :)
1) Power off the tablet. 2) Press and hold the Volume-Down and Power button simultaneously. 3) It displayed a menu in Korean/Chinese (?). 4) Scroll down (using the Volume-Down button) to the SIXTH menu choice. 5) Press the Power button to select. This will start the factory reset process
Sep 13, 2014 | Tablets & eReaders
Wont come on
Happened to me. My solution was to fully charge, then hold down power button for like one minute or more continuously. It causes some kind of restart. Last resource, Press Vol Down and hold, then depress power button and hold. This causes it to go back to reset mode. Good Luck.
Mar 04, 2014 | Samsung Galaxy Tab 2 Nd Generation 7 8gb...
Tablet was recharged and now though it opens, it is not accessing the access page (password). What to do?
hi,
press and hold the Power button until it completely goes off and then power it back on and see if that helps
thanks
Oct 19, 2013 | Acer 64GB 8.1" Iconia W3 Tablet
My Nextbook 7 won't turn on
Every tablet has a button sequence, the reason being for a fresh restart. Either you unplugged it before full recharge, or didn't use proper charging adapter or cable.
There is a solution to avoiding this but first get tablet started by:
Hold power button and volume up button for eight seconds, release and hold power button again, tablet should turn on.
If not, do the opposite hold power button, volume down for eight seconds, then power button. You need to do this with proper adapter and charger you tablet came with plugged in. You may also need to do this more than once.
Once your tablet has started up, the way to avoid this is to swipe right on screen until you see settings app, should be round looking similar to a sprocket, or clock gear.
Open settings / display / sleep. I set mine for 30 mins.
Now you no longer need to power off you tablet manually, thus skipping the button sequence process.After unplugging from charge adapter you will still need to press power button to start.
Hope this helps I have yet to have this problem again, and remember to always let your tablet fully charge before disconnecting.
Jan 11, 2012 | Tablets & eReaders
My samsung galaxy tablet won't turn on. Please help.
  • my tablet did the same thing, all you have to do is make sure it is fully off, then you hold the power button for a short period of time, then you hold the volume button at the same time either up or down, (depending on which tablet you have) and wait until the android logo comes up. Then there are options, you are to choose ''wipe data factory reset button'' (you choose your options using the volume up/down button) wait maybe 30 seconds and then more options come up you choose ''reboot'' wait another 30 seconds, then turn it on it should work but if it doesn't work, take it back (if you still have the warrantee) and you could get a new one or the professional's fix it anyway hope this helps everyone. ;)
Jan 20, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
37 people viewed this question
Top Aiwa Tablets & eReaders Experts
Are you an Aiwa Tablet and eReader Expert? Answer questions, earn points and help others
