Question about HP Color Inkjet CP 1700 Ink Black Replac - 12600 Page Yield
Hp inkjet 1700 primthead locked
Printhead locked
  • HP Master
  • 783 Answers
I Suggest You To Watch Cleaning the Printhead Contacts To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On :
HP Printer Support
Posted on Jan 31, 2014
PRINTER WILL NOT PRINT
To solve this problem you need a Cleaning Solution.
I suggest you to buy the Pristine Fluid for HP on eBay
When you'll have the fluid do this!
1. Open the printer cover
2. Remove all the ink cartridges
3. Pull the lever that locks the printhead
4. Remove the printhead
5. Take the printhead vertically with the nozzles upwards
6. place some mls of the cleaning solution directly on the nozzles
this will completely unlock the nozzles
7. Gently clean the printhead and reinsert it into the printer
8. Take brand new ink cartridges (or old ones, but only if they have 50% of ink in them)
9. pull it back the lever to lock the printhead
10. reinsert the cartridges
11. Power on the printer
12. the printer will do a double cleaning cycle and make it ready to print!
Hope the best!
ADCSFXworks printing center
Oct 18, 2014 | HP Photosmart Premium C309g multifunction...
Tip
HP and Canon Ink Series Printers – Hot Water Printhead Flush
When an inkjet printer (most newer HP and Canon inkjet printer models since 2006) exhibit poor print quality, missing color(s) or image streaking, flushing the printhead with warm water for several minutes will usually resolve the issue. It is first suggested to ensure ink cartridges have plenty of ink and to perform a 'Clean Printhead' action at the printer before attempting the water flushing procedure. This procedures is applicable to individual ink tank printer models that feature a removable Printhead assembly only. HP 564 HP 920 Ink Series Printers Hot Water Printhead Flush
on Apr 01, 2015 | Office Equipment & Supplies
I replace the black ink printhead and cleaner for hp designjet 1050c and it keeps telling to reseat the printhead.
This message comes when print head is not fitted or locked properly in the socket, please remove printhead, also check for polythene conver on nozzle that should be also removed.
Dec 29, 2010 | HP DesignJet 1050c InkJet Printer
How do I clean the inkjet nozzles? The print is
You can clean the printhead on the cartridges with a qtip. Wet the qtip with water and wipe it on the cartridges printhead. Also take another clean qtip and wet it down and clean the contacts in the printer, where the cartridge printhead contects with the printer.
May 29, 2010 | HP Officejet 4315v All-In-One InkJet...
How do you change the print heads on HP DesignJet 500ps InkJet Printer
first select the ink menu on front pannelthen enter select the print head replacement then enter carrige moves towards left then stop & message appears open the door then open the door & remove the head lock & remove the printheads during this process no power off
????????????/pls reply thanks mishrajk21@rediffmail.com
Apr 27, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
Replaced HP 88 Printheads, still receive same
You either got a defective printhead or you are using generic inks, HP got real smart and added chemicals to their ink, if the printer doesn't see the right chemical makeup it will give that error and you need to flush the printhead and the pump and hoses with HP ink or the error will stay.
Jan 13, 2010 | HP Officejet Pro K550dtn InkJet Printer
IDS failure, call HP message comes up
Hope this helps you. This error is caused by either a correct or incorrect detection of air in the manifold. The steps below will clear the error condition, which should solve the problem if it is caused by an incorrect detection of air. If there really is air in the manifold, however, this procedure will not solve the problem and the printer will have to be serviced. Step 1 - Remove all printheads CAUTION: Do not touch the printhead tower. Do not remove the printhead handle. Keep printheads out of the reach of children. Figure 1: HP 14 printhead c00042423.jpg 1 - Handle 2 - Tower
  1. Make sure the unit is plugged in and the power is turned on.
  2. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  3. Wait two or three seconds, then unplug the power cord.
  4. Open the printhead latch. See the illustration below. Figure 2: Open the printhead latch c00042424.jpg
  5. Remove each problem printhead by lifting the printhead handle and pulling up. See the illustration below. Figure 3: Remove the printhead c00042425.jpg
Step 2 - Reset the internal error state NOTE: This step must be performed before the printheads are re-installed.
  1. Close the printhead chute.
  2. Close the access door.
  3. Plug the power cord back in.
  4. Turn on the power. The front panel should read No Printhead. Will damage Product. Insert [color name] [icon] printhead now . NOTE: The carriage may make a grinding noise when you turn the power on. This noise is normal.
  5. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  6. Wait two or three seconds, then unplug the power cord.
  7. Open the printhead latch.
Before re-inserting the printheads, make sure all the electrical contacts have had at least five minutes to dry. Step 3 - Insert the printheads
  1. Place each printhead in its slot in the printhead carriage. The colored shape on the top of the printhead should match the colored shape on the proper slot on the printhead carriage.
  2. Press down firmly and evenly on both the front and back of the printhead, as shown in the illustration below. Proper seating is essential to making good electrical contact.
Figure 4: Seat the printhead c00042431.jpg Step 4 - Close and check the printer
  1. Close the printhead carriage latch and make sure the loops catch the hooks. See the illustration below. Figure 5: Loops catch hooks c00042432.jpg
  2. Snap the latch into place.
  3. Plug in the power cord.
  4. Close the print carriage access door.
  5. Turn on the power.
  6. If the error clears, a message to align the printheads may appear on the HP Officejet D and HP Officejet 7100. Press Enter to align. If the error persists contact HP. Printhead replacement will not resolve this problem - the printer will have to be serviced.
Jan 08, 2009 | HP OfficeJet D135 All-In-One InkJet...
HP Inkjet CP 1700 Inop
The digital readout on the CP1700 is a problem. I have replaced mine now 4 times at a cost of $90 each time, and I'm going to have to do it again or get the new 2800. Just wonder if the 2800 is going to have the same defect.
Jul 14, 2008 | HP cp1700 Color Inkjet Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP Color Inkjet CP 1700 Ink Black Replac - 12600 Page Yield Logo
69 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
