Question about John Deere Garden
Wire for fuel pump came unhooked for JD355D. Need to know how it is hooked up
Tractor runs fine as long as it is full of fuel. When it gets pretty low, it dies down. My hood got messed up and I think something came unhooked. It didn't do it before the hood incident.
luv2tango
  • 36 Answers
SOURCE: 1987 Chevy Suburban 350 2wd not starting or running right
What size engine do you have in it? And, how many miles on it?? Well, I guess it really doesn't matter. At first thought it sounds like you are experienceing a fuel problem, and changing the throttlebody didn't solve your problem. I would start by looking and checking my fuel delivery system. The fact that you had to spray gas into the throttlebody tells me that fuel is not getting there. I would start with the least expensive thing to fix first. Check your gas filters. These are often , OFTEN, overlooked as a sorce of problems, and are rarely changed and often overlooked, and are the problem alot of the time. If that dosen't cure your problem check your fuel pump. Make sure it is delivering the proper pressure. I would bet your problem would be solved, but if it's not then next I would check the electrical components of your fuel system.
Posted on May 12, 2009
  • 158 Answers
SOURCE: Car starts then dies
Check Fuel Pump
Posted on May 14, 2009
countrysi248
  • 443 Answers
yea if it runs on start fluid then your not getting enough fuel .. you are likley going to have to change out that fuel pump .. you might hear it come on but it might not be pumping fluid forward .. good luck
Louie_3006
  • 79 Answers
SOURCE: 1997 Neon dies, starts after electric fuel pump relay swapped
Hello, I would assume this is your fuel pump inside your tank. I would first however do some basics like a general tuneup. For starters I would replace your spark plugs and wires, rotary cap and button and check your fuses. Run some injector cleaner through your system. You know quick simple cheap things before you get to the fuel pump inside the gas tank which can be kinda expensive. The warm up then dies can be caused by, "blownout or fouled," spark plugs. I hope this gives you a general direction in which to go. A sidenote is that coil packs do not normally run an igntion code and I for one do not like them becuase they are expensive.
Posted on May 20, 2009
  • 138 Answers
SOURCE: 8050 LOW POWER
Take a closer look there should be a fuel transfer pump located on the block usually between the primary and secondary filter. If this is not the case you are on the right track about a possible leak (air) You can try and pressurize the fuel tank ( about 20 -30 pounds ) and check for leaks. but be careful not to use to much air pressure because to much pressure will seal off the leak and it may not show
Posted on Aug 15, 2009
By pass fuel solenoid
are you sure that's not a fuel pump ? unless this thing runs on diesel , im pretty sure that's a fuel pump not a fuel shut off , and no ya cant run without a fuel pump , but I gotta ask do you know the exact cause of the fire ? if theres a possibility that it was the fuel pump overloaded , just hooking a hot wire to it could burn the entire machine down
Jul 07, 2015 | Toro TimeCutter SS5000 zero turn mower
Not getting fuel from tank to engien, checked lines thats not the problem, hooked up a electrical fuel pump and it ran fine. and yes it does have gas.
it could be the pump or the pump relay. relay is most come to go with the age but same as the pump if it has never been replaced in the past.
Jun 26, 2017 | 1990 Volkswagen Cabriolet
Saab 9-3 won't start. Has Spark but won't get gas.
why not bypass the fuel pump relay with a jumper wire / fuse and see if it will start that way
Sep 27, 2017 | Cars & Trucks
Any help with mercury outboard motor
Replace the fuel line from tank to bulb and from bulb to engine. The old type lined tube gets damaged by the ethanol content in pump fuel. Buy non ethanol fuel if you can. The lining come away from the walls of the tube and blocks the flow. You can force it with the bulb, but the fuel pump is not strong enough to open up the lining. Your problem is becoming a common occurrence. The worst stuff is the grey tube apparently.
The other obvious thing is to make sure the vent is open on the tank and working, but engines will normally run for a few minutes unless you have a metal tank.
Take a look at these images, then click on the 'All' tab to get ethanol resistant fuel line.
ethanol resistant marine fuel line Google Search
Jun 17, 2017 | Garden
My 2004 Nissan Armada was running fine and then it just died. It will start but immediately dies and acts like it isn't getting any fuel. We took the gas tank off and checked the fuel filter which looks...
Sounds like the loose relay wires disconnected your fuel pump. Try just plugging those wires back in where the plugs match the sockets and the wires are the right length. Don't stretch or pull any wires to make them reach
Aug 11, 2017 | 2004 Nissan Armada
John deere tractor x585 not getting 12 volts at fuel pump how do I check fuel pump
To check pump u remove fender deck,unhook connector, put 12 volt power to it.I have seen pumps react to a swift kick to the fuel tank,NO JOKE.You first have to check fuses,2 on control board and early x585 machines had a single red wire near control board that was only for fuel pump.Remove right side air screen and check for voltage on the relay closest to the radiator.Red wires #231/232 feed your fuel pump relay.Current flows from that relay #655 pink wire and goes to your fuel pump .Also check#215 grey wire {fuseable link}coming from starter post,they WILL burn out,it goes to #221 red wire with inline fuse and feeds rear of the 2 relays,that is your EFI relay.You have 3 fuseable links coming off starter post,check all of them.
Dec 29, 2009 | John Deere 420,1020,2010,2020,2510,2520...
2000 blazer 4.3 hard to start (fuel problem)
Do you have the fuel tester hooked the in the overgrown air valve on the fuel rail in the back of the engine? Or do you have the fuel line unhooked in the back and hooked to the pressure pump? You want the fuel pressure to be in that 60 lb range so if you are hooked into the pressure valve on the fuel rail allowing fuel to go through, then I am betting it is the fuel pressure regulator. To get to that, you have to take the throttle body off and take the plastic plenum that covers the injector packs. On the back of the mount where your six pack of injectors are sits the pressure regulator. If it is faulty then it is dumping fuel instead of holding the pressure like it should.
Get a Chilton or Clymer manual and it shows you in pretty good detail how to fix it. I've done it to my 98 S10 with the same engine.
If you unhooked the fuel line so you are losing pressure from the line back to the pump then I would say your pump is letting fuel back to the tank when it shuts off. My money is on the first possibility though.
Good luck
Mar 28, 2009 | 2000 Chevrolet Blazer
Fuel pump
get a long wires and just jump your fuel pump and it should run like a champ....
Dec 31, 2008 | 2001 GMC Yukon
Garden Logo
24 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
