Question about Sanyo AVM-3659S 36" TV
SANYO TV Channel display #3 constantly displayed. How do I get it off. Lost remote.
  • 398 Answers
The DISPLAY button on the remote will remove the on-screen display, so you either have to order the original remote or look for a universal remote with a "display" button and hope it works.
Posted on Aug 04, 2007
SOURCE:
My Sanyo AVM-3651g 36" TV keeps showing the
On the remote that came with your TV, press the Display button, which is directly below the Volume Up button. Pressing it once displays the channel number and time, pressing it twice displays the channel number continuously, you must have accidently pressed the Display button twice. Just press it once more to remove the display.
Sep 02, 2011 | Sanyo Televison & Video
TV is displaying Channel (03) all the time. Don't
You cannot change the channel without a REMOTE.
CLICK HERE
for a replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 08, 2010 | Sanyo DS27930 27" TV
Cannot remove channel display from tv screen
Using the tv remote (or selecting TV button on cable universal remote) hit the INFO button. It remove the channel # for me. I might have a different model.
Apr 06, 2009 | Sanyo DS27800 27" TV
The channel stays lit in the upper right corner
Unfortunately, you almost always have to have the original remote control to get this display to go away. The "display" button is a specific code on that remote.
With Dish remotes, though, sometimes you can try different buttons and they will occasionally operate different functions. In TV mode, try the menu orother buttons to see if it makes a difference. My suggestion is to call a TV repair shop and see if they will allow you to borrow/buy an original remote for that TV.
Hope this helps you...
Jan 06, 2009 | Sanyo DS31590 31" TV
'03' is displaying on my screen
First try, using the remote, pushing the display button until the display is turned off (three to four depressions on the remote display botton. Second try, unplugging the tv for at least 2 minutes then plug the tv back in. This should reset the tv if you have lost the original remote with the display bottton.
Dec 30, 2008 | JVC AV-36260 TV
SANYO MODEL DS27510, CHANNEL DISPLAY IN CORNER WON'T GO AWAY.
If you can program a Comcast remote or another universal remote that has an info key, you can get rid of it. I just succeeded in programming my comcast remote thanks to Dave Taylor:
http://www.askdavetaylor.com/how_to_program_comcast_cable_remote_control.html
Once the remote is programmed, hit the "info" button and watch your frustration disappear!
Dec 05, 2008 | Sanyo DS27510 27" TV
Sanyo DS31590 channel display
I found the solution to this problem . If someone accidentally hits the recall button the display channel will show on the TV screen, To correct this problem hit the Info Button and the display channel will disapear. This works only if you have the standard cable box. I have another TV that uses a dual mode cable box, tried this procedure with analog RCA TV but it didn't work. Don't know if this procedure will work for all display problems, but it worked for me.
Jan 12, 2008 | Sanyo DS31590 31" TV
Channel display
Get an original remote and follow the instructions in the booklet that came with the set. If you have lost this, you may be out of luck. Universal remotes frequently do not cut the mustard!Sanyo, being fairly user friendly, sells replacements, as do others. Look around for one. There is probably a "Display" button or something obvious you need to press to get rid of this. Losing the original remote can be a gigantic "Gotcha!"
Sep 30, 2007 | Sanyo DS27910 27" TV
Channel display
the option is usually in the menu or controlled by "display" button on the remote
Aug 06, 2007 | Sanyo DS27800 27" TV
Sanyo AVM-3659S 36" TV Logo
533 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
