Question about Belkin AC Anywhere (F5C412UK140W) Battery
Lights come on but no AC output
I have a Belkin 140W inverter. Despite the battery level meter showing 75% charge and the overload light not lit, there is no AC output (checked with a multimeter) from the inverter. The fan runs fine, but nothing plugged in works. Is there any internal fuse I can change, or a service manual available?
  • richardash19
    richardash19 Apr 21, 2013
    I found the problem. It had got damp in storage, and although dried out before trying to use it, the two pre-set resistors on the circuit board inside must have corroded slightly. When I turned both of them a little and put them back where they started (with the power off!), it worked first time, and reliably.
    Habit-Forming:
  • 159 Answers
Yes,internally there is two fuses. always arround 30 Amps. change it. there are like automotive fuses, plug in type.
Posted on Nov 06, 2014
1997 Suzuki GSX-R 750 diagnose charging system
Hi, Ashley before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
Stator ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity your stator is shorted to ground and must be replaced.
5. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test:
This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.jetav8r.com/Vision/Stator/fault_finding_by_www.electrosport.com.pdf
HOW TO CHECK YOUR CHARGING SYSTEM and CHANGING the STATOR and REGULATOR...
Suzuki 1996 GSX R750 Service Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
May 29, 2017 | Suzuki GSX-R 750 Motorcycles
Tip
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
on May 14, 2015 | Xantrex Technology Electronics - Others
Connected a 220 v light to the inverter output. Measured with multi meter across live and neutral = 275 v ac with meter on 600v ac setting. Why does it not show 220v as it should ?
Cheap inverters do not regulate very well. Was the voltage measurement taken with or without a load? The real voltage can only be measured under load. Also, most electronics can accept slightly higher voltages and 90-270VAC is not uncommon.
Feb 06, 2015 | Boating
ERROR E03 WHATS IS MEAN ON MY CONVERTER 600 WATTS ELIMINATOR
Hi, here is the error codes that I could find for you, it seems you are overloading the inverter. That means you cannot connect a kettle or other heavy load to the output. See all error codes below, hoep this helps.
Problem: The AC load will not operate, error code shows on digital
display and alarm is sounding.
Error Possible Cause Solution
E01 Low voltage shutdown because battery is discharged.
Recharge battery. Shorten cables or use heavier cables.
E02 Over-voltage shutdown because of high input voltage.
Verify the charging system is properly regulated and the battery
is 12 V nominal.
E03 The AC product(s) connected are rated at more than the
inverter's continuous power rating; overload shutdown has
occurred. Use a product with a power rating within the inverter's continuous power rating (see Table 3).
E04 The inverter has overheated due to poor ventilation.
Overheating shutdown has occurred.Turn inverter off and allow to cool for 15 minutes. Clear blocked fan or remove objects covering unit. Move the inverter to a cooler place. Reduce load if continuous
operation is required.
E05 The AC products connected have a surge power that exceeds
the Digital Inverter's surge capability or the AC products connected are short-circuited and shutdown has occurred.The products exceed the inverter's surge capability. Use a product with a starting surge power within the Digital Inverter's capability.
Nov 14, 2014 | Cameras
No output on either speakers or headphone, input meters are permanently lit up all the way to the red 0dB LEDs (i.e. overload). I have tried direct USB input and the USB LED on device lights up and...
Ive just fixed 5 of these :D (for a studio)
All had the problem with the signal clip being lit up as soon as you plug it in.
I found on every one, the component U9 had failed! (after 6 hours of probing)thought id post this up as i couldn't find a fix any other place!Checked the service manual, U9 is a:IC VOLTAGE INVERTER CHARGE PUMP UNREG TPS60403 SOT23-5
got mine from:http://int.rsdelivers.com/product/texas-instruments/tps60403dbvt/tps60403-60ma-250khz-inverter-sot23-5/5171208.aspx
soldered it in and jobs a good'n
Jul 17, 2011 | Alesis iO | 2 Sound Card
What does it mean if my dell inspiron 1501 battery shows five green lights when i press the button?
The lights next to the button on your battery is a charge level meter. All the lights on is full and each light out is a representation of the percentage of charge level. This meter is only approximate and does not reflect the battery's performance under load. The meter does not load the battery much.
I hope this helps
Steve at Olive Country Computers in Spain
Feb 16, 2011 | Dell InspironTM 1501 Notebook
Appears to not be charging but does produce 110
Anytime external AC is being applied, the unit passes that AC input through to the output, independent of inverter/charger status. If external AC power is available but the unit is not charging (i.e. the Charge light is lit, but the batteries are not charging up as they should), then there is likely a problem with the AC sensing circuit card inside the unit, with a 1/4 amp fuse and/or the AC transformer the most probably culprits. Without external AC, the inverter will function all the way down to 10V, but then will shut off, so as long as your batteries have not been totally depleted,the unit will still be able to produce 110 AC after a brief charge cycle, but it won't for long.
Sep 17, 2010 | Xantrex Technology Heart Freedom 20 12...
When I plug in my jet 3 ultra the ammeter reads 0. If I turn on the vsi controller the top led display( 3 red, 4 yellow, 3 green) are all lit. I see where that means high battery voltage. The lower led...
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
Mar 03, 2010 | Jet 3 Ultra Power Chair
Freedom 20 Inverter / Charger
1997 monoco dynasty and the invorter heart interface freedom model 20 the problem we are having is the we don't get any powere from the electric outlet and the lights don't work and there is a reading in side on wall that tells you about your electricity and it reads overload my # 817-614-7576 donna
Feb 16, 2009 | Xantrex Technology Heart Freedom 20 12...
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
Belkin AC Anywhere (F5C412UK140W) Battery Logo
420 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
