Question about Rangemaster Professional 110 (Duel Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Rangemaster dual fuel oven, side fan oven would not turn off, opened door, glowing bright red at back! Turned off at mains, now both ovens are not working.
The hob still works ok.
fridgetech
  • 473 Answers
SOURCE: Cant cook in the oven! Gas Rangemaster double oven 110
Sounds like the oven ignitor is weak and not building up enough resistance to get gas flow.  I would replace the ignitor.
Posted on Oct 16, 2007
SOURCE: Fan oven door, cooker surround and hob become burining hot when using fan oven
I have the same, but my fan is running slow too, and the oven completely turns itself off and then on in around 10 mins ?
Someone told me it was the Oven Fan Control PCB, but I have not replaced this yet. We will see soon. Good luck
Posted on Sep 09, 2008
grandadfixer
  • 99 Answers
SOURCE: Both electric ovens do not work.
Have you set clock time?
Posted on Oct 11, 2008
grandadfixer
  • 99 Answers
SOURCE: Door handles on rangemaster toledo 110 duel fuel
Yes this is easy to do.We can supply bits if required.
Posted on Oct 23, 2008
SOURCE: Rangemaster 110
Reading the user manual, it states that the flame initially comes on low, until it is "sensed" by the flame sensing device. This to me sounds suspiciously like the flame isn't being sensed and so never gets increased to the normal level.
I've not had time for a proper look at it.... but from a quick glance this morning this looked like a "flame rectifier" probe next to my burner (as we commonly use in boilers to sense if the gas burner is lit). This is just a metal probe. They send a high-ish AC voltage signal (Sine wave) from it, through the flame, to the earthed metal case. The flame acts like a diode (yes it really does work !) and simple electronics detects the change in the applied signal (rectified) due to the flame. I know from personal experience they (the probes) get coated with crud (carbon, etc) and need a good clean. I suggest you try cleaning both it and the metal area opposite it. If necessary the probes metal tip could be GENTLY rubbed with very fine Emmery cloth, etc, if badly coated.
Other than that, if it is sensing the flame, then it must be the gas control device (solenoid valve ?) that is jammed, blocked or just defective.
Simples......
Posted on May 19, 2009
The fan has stopped orking on my new world oven
I have no worked on a new world oven, but i will assume you speak of a convection oven.
Typically convection ovens have a door switch a motor and a run/start capacitor which helps the motor "turn over". I suggest, you have the oven cool, remove anything blocking the convection motor. Take your hand and spin the wheel, then while its spinning turn it on. You may have to try counter or clockwise. If you cant spin it at all, you have a bad motor, if the motor starts up with your manual assistance, the capacitor is bad. If there is not even a hum, a door switch is faulty, that or the motor has a thermal overload (usually a red button on the motor that needs resetting).
Dec 19, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Brittania SI/9TB/SS fan in main ove glows red hot
There is a fault on you oven please ring Britannia for a service call on 01253471111 option 3. They can also supply a new oven seal
May 07, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Diplomat elite (MFI)
it is dangerous there is a short do not use until its been electrically checked out. eg resistance to earth.
Mar 25, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Toledo 90 side oven fan not working.
We had the same problem about 2 months after we bought the cooker. The engineer had to change the fan motor.
Jun 01, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Oven fan noisy/broken
this noise probably means that the fan is about to stop working, this is what happened to mine. You can easily buy replacement fan off E-bay (it seems easier to find the right fan on e-bay that any of the confusing supplier sites). You then just need to remove the inside oven back and the outside electrical to replace the fan.
Sep 24, 2007 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Rangemaster Professional 110 (Duel Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
46 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
paulcarew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
