Question about IBM Computers & Internet
W83697HF driver i need a W83697HF driver
You lose there aren't any solutions... sry
Posted on Dec 01, 2009
Ikbt-50 driver needed
You don't need a driver! This is a Bluetooth keyboard. What you need to do, is pair it with your Bluetooth device.
First, charge the keyboard. Enable Bluetooth on your device. Now, push the small black button marked "ID" on the back of the keyboard. The button needs to go in pretty far. This will generate the Bluetooth code needed to pair your Device. You need to enter the four digit numerical code generated by the keyboard. That's it! You are paired!
Oct 25, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
Manyal
EP-8K3A
Introduction
KT333 with VT8233A AGPset/266MHz FSB/3 DIMM with DDR333/1 AGP-4X/6 PCI/USB1.1/ATA-133/6CH Audio/ATX
Specification
PROCESSOR:
The Socket A compatible AMD AthlonTM XP processor 1500+ to 2700+, 600MHz to 1.4GHz AMD AthlonTM and AMD DuronTM processor up to 1.3GHz
CHIPSET:
VIA KT333 AGPset (KT333+ VT8233A)
DRAM MODULE:
184pin DDR DIMM x 3 for PC2700 Memory
DRAM Size: 64MB to 3GB
EXPANSION SLOT:
PCI x 6!A4X AGP x 1
ONBOARD I/O:
Winbond W83697HF LPC I/O integrated with FDD, Parallel, Game, Serial and IrDA v1.0 and Power-On Controllers
ONBOARD PCI / IDE:
PCI Bus IDE Port with PIO / Ultra DMA-133 x 2 (Up to 4 Devices)
I/O CONNECTOR:
PS/2 Mouse and PS/2 style Keyboard
COM1, COM2, Printer, Audio-in/out, MIC & Game Port connectors
USB:
USB connector x 4 (2 for Opt.)
BIOS:
Award Plug & Play BIOS
Built-in AC97 Digital Audio (by Realtek ALC650):
Compliant with AC97 2.2 specification
6 channel slot selectable DAC output for multi-channel applications
Supports digital SPDIF Out Function
EXTENDED FUNCTION:
Supports Hardware Monitoring Function by W83697HF
Supports exclusive KBPO (KeyBoard Power On)
Supports CPU Vcore , Clock and Multiplier setting via BIOS
Supports Memory Voltage setting via BIOS
Supports STR (Suspend To RAM) power saving Function
Supports Wake-On-LAN Function
FORM FACTOR:
305mm x 245mm x 34mm ATX Size
OS Supported:
Windows 98SE/ME/2K/XP/Server2003
Jun 05, 2011 | EPoX EP-8K3A+ Motherboard
Need a sound driver for Microsoft Windows Vista,
Need to go to vendors site (Mobo) and download drivers for it. Instal mobo one first.
May 10, 2010 | DFI AD77 Pro Motherboard
Need a sound driver for Microsoft Windows Vista, my computer: manufacturer - DFI model - AD77 Chipset - VIA KT400 (VT8377) southbridge - VIA VT8235 LPCIO - Winbond W83697HF Please help, because I dont find...
ok i had a Qick look for you and found nothing seems its all xp drivers i can see i spend 30 to 40 mins looking for you and only found xp drivers a fast and easy fix is to get a pci sound card you can get a 5.1 channel sound card pci it slots in easy too for 5 to 6 pounds on ebay hope this helps and sorry i couldint find the driver
Mar 17, 2010 | DFI AD77 Pro Motherboard
Will this graphics card work on my imedia 1401 computer
Yes, it will. However, you better know how to put it in!
Mar 19, 2009 | Computers & Internet
I need Webcam ucom driver
i need the driver fou ucom web cam
Oct 16, 2008 | Intel Easy PC Camera Webcam
Dear sir I WANT MOTHERBOARD DRIVERS.
http://support.asus.com/download/download.aspx?SLanguage=en-us
go there and then select from the drop down menus
Motherboard
then
Socket 775
then
P5S800-VM
Then download everything you need good luck!!
Aug 07, 2008 | ASUS P5S800-VM Motherboard
Drivers
I loss the drivers of HP LaserJet 1020 printer. I need now. Please help me.
Jul 16, 2008 | HP LaserJet 1020 Printer
Trying 2 figure out what type of memory 2 use?
that looks like an Albatron MoBo but I cant get onto the albatron website to confirm this
Feature
AMD Athlon™/Athlon™XP/Duron™Processor
Socket 462 with FSB 200/266MHz
2 DDR266/200 Memory Sockets
6channel AC 97 Audio
2 ATA133 Channels, up to 4 ATA 133 IDE Devices
6 USB 2.0/1.1 Ports (4 ports by optional cable)
Integrated 3D Graphics Engine
Processor
Socket 462 AMD Athlon™/Athlon™XP/Duron™Processor
FSB / Transport
200/266MHz
Chipset
North Bridge: VIA KM266 ( VT8375 )
South Bridge: VIA VT8235
I/O Chip : Winbond W83697HF
Memory
2 * DDR sockets
DDR266/DDR200 unbuffered ECC/none-ECC DDR SDRAM up to 2GB
Expansion Slots
1 x AGP 4X slot (1.5V Only)
3 x PCI slots (PCI 2.2 compliant)
1 x CNR slot (AMR Type)
IDE / SATA Connectors
2 ATA133 channels, up to 4 ATA 133 IDE devices
Onboard I/O Connectors
1 x Floppy Connector
2 x USB 2.0/1.1 header (4 ports USB cable optional)
1 x CD_IN header
1 x COM (serial) port header (Optional COM cable)
1 x S/PDIF in/out header (S/PDIF in/out cable optional)
1 x CPU fan header with fan rotation detection function
1x System fan headers with fan rotation detection function
2 x 5 pin system panel header (Intel spec)
1 x Front audio header (Intel spec)
1 x IrDA header
1 x Case Open detection header
1 x Wake on LAN
I/O via Back Panel
PS/2 keyboard/mouse, 2 x USB(2.0/1.1),1xVGA ,1 x Com(serial), 1 x Parallel, 1x Game/Line-in/Line-out/MIC
Power
20-pin ATX power connector
BIOS Feature
2Mb Flash EEPROM
Award BIOS with ACPI, DMI2.0, PnP, WfM2.0, Green Suspend to RAM (S3), Suspend to Disk (S4) Wake on keyboard, Wake on LAN/RTC Timer
Hardware Monitoring
2 FAN sensors, CPU/System voltages and temperature monitoring.
Special Feature
Certifications
FCC, CE, BSMI,WHQL
Form Factor
Micro-ATX (218mm x 244mm)
Jul 11, 2008 | Intel Motherboard
Computers & Internet Logo
1,004 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
