Question about Poulan Pro PR550N22SH 22Inch Briggs Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) ()
Need to replace spark plug wire assembly for poulan pro 550 lawn mower assembly
  • 5 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
trouble shooting tips: oil is too full
fuel jet and float are plugged
spark plug lead wire may be damaged inside and needs to be replaced.
Posted on May 02, 2009
  • 84 Answers
SOURCE: I have a Poulan Pro self propelled lawn mower. Was
i had the same problem. the coil is located under the "hood" if you may, just take that off and you should be able to get to it pretty easily,just unscrew the coil and find one on ebay for just about $29 for a 2-4 hp
Posted on Jun 24, 2009
  • 95 Answers
SOURCE: Poulan Pro 22" does not mulch!
When you mulch you can only cut 1/3 of the grass off. If the grass is 3" high you can only cut 1" off.If you are cutting more grass of than you are leaving there is no place to hide the clippings.A general rule is if you notice clippings and clumps beginning to lay set the mower up one notch at a time until the clippings are hardly noticeable.If you like a real low cut then mulching is probably not for you,you will probably want to bag the grass instead.Hope this helps.
Posted on Sep 06, 2009
Dolfoff
  • 148 Answers
SOURCE: Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Posted on Oct 05, 2009
  • 52 Answers
SOURCE: where is the oil drain plug?
It is on the bottom of the engine. Lift up the deck and look under it. Make sure there's no grass covering it up.
Posted on Apr 22, 2010
Spark plug size
Take the spark plug out of the mower and look on the side of the plug and it will tell you which plug is needed to replace it with.
Jun 21, 2014 | Poulan Pro 22" Self Propelled High Wheel...
My poulan pro 550 series is vibrating a lot when I started. And the front wheel drive is not working anymore.
you need to unplug the spark plug then turn the mower on its side sounds like you hit a rock and bent something and if you bent the crank the belt might have fallen off
Jul 01, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
What is the proper spark plug size for poulan pro 550 series
Go by the numbers on the original plug. The gap should always be set at 0.30.
May 24, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan won't start
check for spark then try carb cleaner behind the air filter
Mar 31, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a poulan pro 550 Briggs and Stratton Lawn Mower. I need to find theOil Realease Button
tilt the mower down by the handle, and underneath on the bottom of the motor you will find a drain plug. it has a 3/8 square hole in it. This is the oil drain plug.
Sep 24, 2010 | Poulan "Poulan" Push Mower
I have a Poulan PRO 550 series that I just bought 4 weeks ago. It won't start. The oil is at a good level. There is plenty of gas. Everything was checked and it still won't start. I am so disappointed. Has...
There are several possibilities for not starting. Water in the gas, Carburetor jet clogged ; Spark plug needs replacing, air filter needs replacing, or you have old gas. Or if you have hit something the flywheel key may be sheared. Hope this helps.
Good day.
Oct 16, 2009 | Poulan Pro " Pro" Self Propelled Mower
Hope this helps.
Oct 04, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro PR550N22SH 22Inch Briggs  Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) () Logo
50 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
