Question about Smith Corona Wordsmith 200 Typewriter
Print Wheel Drive Gear is out of Positoin
The print wheel is typing incorrect characters. How do I get the print wheel drive gear back in correct position? Thanks.
  • 69 Answers
Normaly this would not be a user adjustment, possibly the grub screw hold the wheel hub to the motor has come loose, very small allen key needed, you make be able to shift it back to right place. Usualy this is done with special alignment jig
Posted on Sep 22, 2007
It stuck and make a buzz noise wrong character
Your ribbon may be stuck check it out, buy the way I bestow the sacred order of thee nomenclatcher Maximus for bestowing the information that is actually need in great detail, you would not beleive how non- descript some people are ie My typewriter doesn't work right? After a good public flogging I may get some information out of them, well done! Bret PS, It's rare but you may have popped a drive gear with power off, and unplugged try and move the print carriage (gently) back and forth it should move with about a Pound of resistance and not catch or sound crunchy, fluid motion will tell, good luck.
Mar 06, 2015 | Brother GX6750 Daisy wheel electronic...
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
Typing the wrong letters
First try opening and closing the top cover. If that does not reset the print wheel to the correct characters, check and make sure the correction tape is not interfering with the wheel as it spins. If that is not the case remove the print wheel and make sure non of the spokes are bent. If they are you can try bending them back to the right position or you may have to replace it.
Jan 17, 2012 | Brother GX-6750 Typewriter
Whem keys are typed incorrect display of characters. how do i correct it?
REMOVE & RE-INSTALL THE DAISY WHEEL, MAKING SURE THE HOMING PIN IS IN THE HOLE NEAR THE HUB OF THE WHEEL. IF IT STILL DOESN'T PRINT THE RIGHT CHARACTERS, THE PRINTWHEEL MOTOR OR MAIN BOARD COULD BE BAD. TOSS IT AND BUY ANOTHER MACHINE
Aug 18, 2010 | Brother SX-4000 Typewriter
Incorrect character printing.
On the L. side of the keyboard is a slide switch labeled 15, 12, 10 and PS it is probably in the PS position. If it isn't then slide iy up snd down a few times they do get dirty.
DickyO
Mar 26, 2010 | Nakajima AE-830 Typewriter
Printer labels do not advance when print is hit
CAUSE: my guess would be a stripped gear or a lack of prssure on the "pinch wheel" which would cause a loss of traction on the paper feeder.
SOLUTION: 1- change the stripped gear (if it's stripped)
2- add a layer of adhesive tape on the loose pinch wheel (if it's loose)
both solutions require to open case (to access loose wheel or stripped gear). To determin what the probleme is, try to run a print and try to move or pull gently on the lable ribon while in function. Two possible outcomes are that the gear will only "hook" in some areas if it's stripped. If it's loose the paper will only move while pulling on it.
Jul 24, 2009 | Brady ID PAL Thermal Label Printer
Possessed typwriter
Assuming that you have the correct print wheel fitted and that the typewriter is on standard key board setting then I would look at anything that might be interfering with the rotation of the print wheel. First, remove the print wheel and check that none of the character arms are distorted,then look at how the correction tape is fitted. If this tape is not fitted correctly it could be interfering with the rotation of the print wheel.
Nov 02, 2007 | Brother SX-4000 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Types incorrect characters
Have you checked the keyboard switch inside on the right. The US setting is the selection to the rear.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 15, 2007 | Brother ML-100 Typewriter
Types wrong Characters
Does it always type the same wrong letter ie a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
Jul 04, 2007 | Smith Corona Wordsmith 200 Typewriter
Smith Corona Wordsmith 200 Typewriter Logo
212 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Steve Allison
Steve Allison
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
