Question about ASUS P4PE-X Motherboard
P4pe-x mother video issus
It boots up but dosnt show any video output, ive tryed every video card i got from pci to the vga
  • 112 Answers
SOURCE: No Video Output
Do you get any picture at all?
Can you press the F1 key or DELETE key and bring up the Setup menu? Can you see it?
If you can't see the above, it sounds like someone was not grounded to the computer case when they installed the new motherboard. Static electricy is the #1 killer to all electronics. If this is the case, you will have to buy an aftermarket video card and install it to see anything.
The VGA monitor will work with any video cards on the market.
If the motherboard said that it uses an AGP video card. That is the only one it will use. Make sure the card matches the motherboard or it will not work. All video cards are marked on the outside top of the box and your motherboard is maked by the AGP slot. Make sure you get the right speed format also. 8X will only work with a 8X.
I hope this helps and I will check back later to see how you made out.
Posted on Apr 02, 2008
Paul319581
  • 101 Answers
SOURCE: Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
Posted on May 30, 2008
map9966
  • 2351 Answers
You mentioned you placed "another" PCI-E card into PCIEX16_2 slot.
You need to remove the video card from the PCIEX16_1 slot first & try the second video card in PCIEX16_1 slot. Page 2-4 in manual.
Boot the system & see if you have video. If yes than the other PCI-E video card has an issue.
Just adding a second card will not boot.
You do want to replace the video in slot 1. This way you do not need to make any changes in you're bios or add the additional power (Which is required to run both at the same time). (Kind of hard to get into the bios when there is no video display).
Luck!
Mike
Posted on Jul 06, 2008
nickstorm
  • 93 Answers
SOURCE: I WANT TO FIX A PCI VGA CARD IN MY SYSTEM P5GD2-TMX/SUSING JUMBER
Hi again. As I mentioned in my other note to you, when installing a video card in a PCIe slot, you will need to tell the system (via Setup) which video to use. It will be somewhere in the various screens of BIOS settings for the motherboard. ASUS isn't really supporting this motherboard any longer, so the documentation I'd need to give you specific instructions is no longer available. Still, it is there in Setup (accessed at boot, by pressing the key prompted on your very first screen), you just need to look for it.
Once you've told the system which video to use, boot into Windows, and install the video drivers that came with the card.
Cheers
Posted on Nov 13, 2008
ghouliass
  • 105 Answers
SOURCE: video on an asus A8V-E deluxe motherboard
When you rightclick on MY COMPUTER then choose MANAGE, in the device manager, do you have another display controller appearing? if so, then you only have to install the drivers you've got with your new card, then in DISPLAY from the control panel, you will have to go to the SETTINGS tab and lightly move the second diplay then it will ask you if you want to activate it.
if there is no other display controller in the DEVICE MANAGER you should try to reboot and access the bios in witch you will found an option for selecting the first display controller to be used. so, choose PCI, and save, then reboot.
Posted on Nov 24, 2008
After installing new ATI HD4670 video card on my Gateway zx6810 I boot system hear no beeps computer powers on but screen is black
Hello
Is this new video card the only video source on the PC (i.e. there is no other VGA connections on the PC)?
Without knowing the make and model of the PC, I will list the most common issue when replacing the video card in a PC.
1. Connect the monitor to each available VGA connection and boot the computer - to see if any VGA output is working
2. When you find a working VGA output, go into BIOS and change the VIDEO settings to either allow BOTH the onboard and add in video OR allow the add in video only. Save the changes and turn the computer off.
3. Move the video cable to the add in video card, turn the computer on and see if the BIOS is using the new Video card
Nov 03, 2013 | Sapphire ATI RADEON HD 4670, (1 GB) PCI...
I have bfg 9800gt it wont boot .. just puts monitor to sleep ... am2 biostar mother 450 watt power supply 3gb ram triple 3.0 amd cpu
ive had a similar problem before. in the BIOS there somewhere, there is an option to make your computer use the ON BOARD VGA, or to use the PCXI. which ever one is selected is the one that the computer will use. if you can change this option in the BIOS, you might be able to use your video card.
Jun 28, 2012 | BFG Technologies GeForce 9800 GT, (1 GB)...
Im trying to install my ATI Radeon 9250 265mb graphics card and I have installed the Catalyst control center but when i turn off my computer and unplug my machine and put in the graphic card (PCI) And boot...
There may be a setting in your BIOS for your video output.
If you were originally using the onboard VGA video output, there may be an option in the BIOS to switch to PCI output.
Jul 11, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
I am using mercury 845gvml motherboard but having a problem in vga drivers
To set up vga you have to set the bios setting to the vga platform which you are using like intgated to on board ,pci to pci card and pci-E to pci express card .
Then boot pc and right click on my computer - manage-device manager-display adapter -and see any yellow mark in it .
if their is any mark then update the driver by keeping mother board cd in cd/dvd rom .
delete any non completable driver in it or you can use control panel to do this work .
if you are unable to boot in system then on boot screen press f8 to boot in vga mode or safe mode .and do all work recommended
Dec 07, 2009 | MSI 845GVM-L (MS-6714-040) Motherboard
H Slimline New Graphic Card-No new DCI output-Yes old VGA output
you are missing nothing actually the graphic card over rides the onboard graphics and you have to use the graphic cards output ,only one hardware at a time for pci devices
May 08, 2009 | Computers & Internet
PCI cards don't function
as been have ssen in picture and specs of your mainboard you have a integratd vga vard and a agp slot. so solution may be this
with old integrated vga open bios program go to disply and choose pci input first. this enable you to boot from pci slot with a new vga save setting switch of computer put on new pci vga and try.
if no option to activate pci init first , sorry you can not boot any vga from pci , but only from agp slot.
Apr 05, 2009 | AMD Athlon , 750 MHz Processor
Question about dual video output on ATI Radeon 9250 256mb PCI.
just look at your video card if it has at least a vga port and an s-video/composite or another vga port then yes you can do multiple display, if it has the s-video you can get an inexpensive s-video to composite adapter for those older tv's
Dec 14, 2008 | ATI RADEON 9250, (256 MB) PCI Graphic...
Elitegroup k7som problems
check the memory card if the memory card is faulty the system would show no vga if u checked it the problem lies with ur mother board
Dec 02, 2007 | EliteGroup K7SOM Motherboard
ASUS P4PE-X Motherboard Logo
136 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
