Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
Ice to thick - Ice-O-Matic ICEU220HA Undercounter Ice Machine
    Novelist:
    Champion:
  • Ice Expert
  • 373 Answers
Your machine should have a bridge thickness of 1/8 of an inch. you can go to the freeze timer and take some time out to shorten the freeze cycle buy sliding the switches to on and off. example if switch is set to on at 18 then you wont to turn that switch to off and turn the next lowest number switch to on until you achieve the right thickness of ice. if this dose not work then replace freeze timer.
Posted on Jul 08, 2014
How do I adjust bridge thickness on ice o matic
Adjust the Timed freeze. The freeze timer is an adjustable timer used to control the ice bridge thickness. The freeze timer is factory set but may need to be adjusted upon initial start up of the machine. When time is added to the freeze timer the length of the freeze cycle is increased, therefore the ice bridge thickness is increased. When time is removed from the timer, the freeze is shorted and the ice bridge thickness is decreased. The freeze timer can be adjusted by sliding one or more switches to either the ON or OFF position to 1/8'' ( 3mm ). If bridge is too thick remove enough time from the timer to achieve proper thickness. If bridge is to thine add enough time to timer to achieve proper thickness.
NOTE: The freeze timer on ECP models is located on the circuit board. It operates and is adjusted as described above. Now if you have had this machine for awhile and it was making the right bridge thickness and is now making thinner ice i would look at the purge valve to make sure it is not letting water seep out of the sump tray during freeze cycle this will cause the sump tray to keep filling up with water and will cause thin ice.
Sep 15, 2014 | Kitchen Appliances - Others
How to make cubes fuller
You have to adjust ice thickness sensor it hangs in front of the evaporator at the top it will be white with a 5/16 screw going through it to increase the thickness of ice turn clockwise no more than a 1/8" at a time then let it make a batch of ice. carefuller you don"t want to make the ice to thick this would cause ice to hang up on evaporator plate and could damage it.
Jul 10, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice bridge too thick
look at the evap plate to see if there is a ice thickness probe, if there is it should have a screw 5/16 going through it that you can turn in or out you wont the thickness of a penny between the evaporator and the stainless sensor turn screw 1/8 of a turn at at a time let machine make a sheet of ice and keep making adjustments until you achieve the right thickness. Now if there is not a probe then the thickness is built in the run time of the control board. you can not adjust it. you need a tec to look at it to make sure your not having a harvest problem if it is not harvesting every time them ice will be to thick.
Jan 14, 2014 | Orien 44 Lb. Built-in Under Counter Clear...
Scotsman sce275 making ice too thick
carefully adjust the ice bridge thickness screw at the top no more than 1/8 of a turn counterclockwise in between freeze cycle until desired thickness is obtained. clockwise gets thicker and counterclockwise thinner.
Apr 12, 2013 | Scotsman Ice Machine - 290lb...
SCOTSMAN MODEL #CME506WS1F
You need to descale the water circuit according to manufactures instructions. Scale build up keeps the ice from releasing during harvest cycle. If overall ice thickness is to thick, rotate the ice bridge thickness screw at the top of the platen countercloclwise about 1/8 of a turn max between freeze cycles until desired thickness obtained. If you do not know the correct descale solution alway use a nickel safe descaling solution.
Dec 03, 2012 | Scotsman Ice Maker WBin Flake Style water...
If my ice cubes are incomplete from my manitowoc ice machine and I sometimes here them falling early and hitting the bin before it dumps. Is the ice thickness set too thin or too thick? Thanks for your...
The ice thickness is too thin...
turn the screw on the ice sensor IN or clockwise about 1/8 turn at a time till you get the right thickness...give it a couple of dumps before making another adjustment after doing the first one...be careful as the sensor is very sensitive and can be knocked out of wack very easily...
heatman101
Sep 28, 2010 | Refrigerators
ICEU150 bridge thickness time delay to 1 second and the bridge thickness is still to thick
The bridge thickness on this model starts with the low pressure cut-in control that then in turn starts the timer. It sounds like you have either a bad low pressure control or one that has been tinkered with. To start with if you have a low pressure gauge that you trust what I do is take all of the time off of the timer and unplug the water pump. Then start the unit and watch the low pressure gauge to see at what pressure the harvest starts. an ICEU150 with R-404A should cut in at 44psi. Once that is set plug the water pump in again, put about 400 seconds on the timer, see how thick the ice is after 2 cycles and adjust as needed.
Jun 09, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
ICE-O-MATIC ICEU220HA2 bridge too thick. Is the time delay relay the "finnish" relay that adjusts bridge thickness? If so, I'm not getting any change in thickness with time adjustment.If the time delay...
The bridge thickness on this model starts with the low pressure cut-in control that then in turn starts the timer. To start with if you have a low pressure gauge that you trust what I do is take all of the time off of the timer and unplug the water pump. Then start the unit and watch the low pressure gauge to see at what pressure the harvest starts. an ICEU220 with R-404A should cut in at 45psi. Once that is set plug the water pump in again, put about 400 seconds on the timer, see how thick the ice is after 2 cycles and adjust as needed.
Apr 06, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice maker will not eject ice. Sometimes it works, sometimes not.
These units need to have the evaporator coil cleaned routinely. A cleaning solution can be obtain at a refrigeration outlet. Another common problem is the ice thickness is out of adjustment and the ice gets too thick and will not come loose on the defrost cycle, check the thickness.
Nov 27, 2008 | Avanti Freezer Compact Ice Maker - 12 lbs....
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
125 people viewed this question
Top Ice Kitchen Appliances - Others Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
mike cooper
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
