Question about Mitsubishi VS-50705 50" Rear Projection Television
Picture is not bright - Mitsubishi VS-50705 50" Rear Projection Television
  • Mitsubishi Master
  • 3,459 Answers
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solutiPicture is not bright - 47a7bc4.pngimg src="http://i.fixya.net/uploads/images/47a7bc4.png" alt="47a7bc4.png" class="h_mi" />CONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, Picture is not bright - 7c190d8.jpgr>BEFORE
Set after fluid change. Notice how bright the colors are now. EverthingPicture is not bright - a798d23.jpgp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Posted on Apr 19, 2013
Pictures are too bright
My cemera outdoor picture come out bright/white on Canon PowerShot A470 but indoor picture and video picture comes out good. So kindly give me this proble suggession.
Nov 18, 2012 | Canon PowerShot A95 Digital Camera
Picture gone very bright
The picture on my Technika tv has gone very bright and will not adjust, does this mean I will need a new one?
May 16, 2012 | Televison & Video
The picture frame still scrolls pictures but the pictures are very dark and unable to be seen well. Is the frame ruined?
Hi, Don't put screen in direct sun light or bright light. Bright lights will destroy LCD screen. The LCD screen has some adjustments on back. You might be able to readjust picture brightness.
Good luck.
Jun 10, 2011 | SmartParts (1DPFSP01) Digital Picture...
The overall picture is not bright like it use to be. like about half the brightness. picture is fine just not bright
suggest replacing the lamp. when the lamps are reaching the end of their life the tv will take a long time to show a picture and you may see a drop in brightness. part number 915P061010 i would really suggest getting a mitsubishi original lamp there are alot of generics out there and they are junk. good luck
Jan 06, 2011 | Mitsubishi WD-65733 65" HDTV
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Picture (video) jumps from bright to dim
I figured it out myself. R243 was intermittently open. Replaced it, and now we can watch the Super Bowl.
Dec 19, 2008 | Toshiba 50H72 50" Rear Projection...
Glaring nothing but bright can't see the picture
Try to adjust LCD Brightness.
Press Menu.
Go to LCD Brightness.
Dec 09, 2008 | Samsung Digimax D53 Digital Camera
Help with settings - blurry SD picture
contrast full, brightness, tint, color, in the middle, then adjust sharpness for what suits your eyes, you may turn brightness and color below middle.
Mar 17, 2008 | Sony BRAVIA KDL-40V3000 Television
The picture is to bright
if you are a tech open the tv and turn down the brightness from off the flyback screen adjustment if that does not work then the flyback will have to be replaced.it is defected.good luck
Apr 19, 2007 | Emerson EWF2703 27" TV
Tv has bright green color
you are having a problem in your video circuit and your tunner section if the green is smooth also have the deflection ic checked.but this set needs to be taken to a qualified tech repairs could cost about $1oo.00 good luck.
Nov 16, 2006 | Samsung TXK2554 25" TV
Mitsubishi VS-50705 50" Rear Projection Television Logo
22 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
