Question about Amana Dryers
Dryer is not drying does not dry
We have replaced heating element, thermostat, and thermal fuse.
  • Amana Master
  • 8,220 Answers
Might be a crappy timer in it depending on the model. I found a few with this problem and did a video on an Estate model. Here is how to check:
My youtube channel has all the links you need to fix your dryer.
-Paw Paw
Posted on Apr 20, 2013
  • 1314 Answers
SOURCE: Dryer Heating But Not Drying!!!
if its not heating at all the thermal is the most likely culprit and it was the little plastic piece you seen now if you have a meter set it to continuity and pull one of the wires off the thermal limiter and check it if it reads open its bad same with the heating element let me know now if the heater and thermal limiter are good pull the blower motor vent and check it for blockage
Posted on Jan 17, 2008
Illeagle
  • 525 Answers
SOURCE: Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
jsrock516
  • 5911 Answers
SOURCE: dryer heating element cycles on and off every minute or two
It is normal for the dryer heating circuits to cycle on and off. The heating element is not supposed to stay on continuously. What usually causes excessive dry times, and rapid cycling of the heating element is poor ventilation. The following link explains:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention to the paragraph that discusses proper ventilation and how to determine whether or not you have a clog. You could STILL have a malfunctioning hi-limit thermostat or operating thermostat, but I suggest you double the simple things first. It doesn't make since to replace parts if it may be a simple matter of general upkeep. Cleaning the lint trap in not enough to keep the dryer ducting clean. If you've never had your ducting inspected or cleaned, now may be a good time.
Perform the simple test of disconnecting the dryer vent hose and try drying a load. If the dryer performs better, you may have a clog in the vent line where it leaves the dryer to where it exits your home. If the drying results are still the same, inspect the internal air blower to make sure it is not clogged.
NOTE: It is also recommended that you use semi-rigid metal ducting. It is crush resistant, resists kinking & heat, and offers protection against rodent infestation.
I hope this advice leads you in the right direction. Let me know what you discover. If it is not a matter of ventilation, then read the steps on how to determine the whether or not the heating circuits are operating correctly. Let me know if you require additional assistance.
Posted on Nov 29, 2008
duby1990
  • 367 Answers
SOURCE: Whirlpool dryer LEQ8000JQ3 does not heat when drying
You can check which one you need to replace by using an ohm meater. You usually dont have to replace both.
Posted on Dec 11, 2008
shinn8
  • 85 Answers
SOURCE: my kenmore 70 series dryer
Are you getting any heat at all? Did you change the thermal cut-off which is mounted near the top of the heater box? This is the only other piece in the heating circuit. If you changed it already you could have problem in the timer or in motor. There is a switch in the motor that controls heat also.
Posted on May 27, 2009
No Heat- have replaced thermal cut off, thermal fuse and the heating element with no success. Any idea what else I should check?
  • Thermal Fuse,Timer, Temperature Sensor, Coils, Gas Control Valve, Radiant Flame Sensor, Igniter, Cycling Thermostat, High Limit Thermostat, Heating Element!
  • The things listed above can all cause no heat in drying if they are not working, or working correctly!
Mar 02, 2016 | Kenmore Dryers
It's not heating and we've replaced to different heating elements
the dry is not heating up. we replace the heating element and thermostat and thermal fuse., It sill doesn't heat up
Nov 10, 2011 | Amana ALE866SB Electric Dryer
It takes the dryer 2 hours to dry the clothes. I always make sure lint filter is cleaned after each cycle.
Hello there and thanks for choosing fixya
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Feb 03, 2011 | Dryers
GE Front loader doesn't dry clothes completely.
Hello there:
f yourdryer won't heat up, it's possible that it is not being supplied withthe proper voltage. Here are three ways to make sure power is gettingto your dryer: First, make sure your dryer is plugged in. Next, checkthe circuit breaker panel to make sure all the circuit breakers are inthe correct positions. Finally, check to make sure no fuses in yourfuse panel are blown. Any of these could explain why power is notgetting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 23, 2010 | GE DCVH515EF Electric Dryer
My tumble dryers not drying my clothes, i've had it coming up 6 years
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Jan 22, 2010 | Whirlpool LER5636P Electric Dryer
The dryer is not drying. The drying temperature
Hello there:
Proper Voltage
Jan 19, 2010 | Kenmore 500 6952 Dryer
DRyer is turning just not drying clothes Maytag
Hello there:
Proper Voltage
Jan 19, 2010 | Dryers
Heavy duty kenmore dryer model # 76680100 not heating up to dry cloths
Hello there:
please try this
Proper Voltage
Heating part of Indesit ISA60v tumble drying has stopped working. Can you give me info as to where to look im a Electical-tech cheers chris
Hello there chris
Proper Voltage
81f68d1.jpg Heating Element
97ed1ca.jpg Thermal Fuse
0a798b8.jpg Thermostat
7e97613.jpg Timer motor
Jan 13, 2010 | Dryers
My kenmore 70 series dryer is not heating up. At first it just took longer and longer to dry, but now it isn't drying at all. This happened after the dryer was moved in order for the washing machine to be...
Not funny at all, I suspect. It sounds like the problem originated due to a faulty high limit thermostat or a partially burnt heating element. I would replace the thermal fuse and the high limit thermostat. These two components can be purchased as a set. Also check the heating element. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad component. The thermal fuse is normally attached to or near the exhaust duct and the high limit thermostat is attached to the internal ductwork. The thermal fuse can be tested in the same manner. I will attach a photo of a high limit thermostat and thermal fuse for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 01, 2009 | Kenmore Dryers
Dryers Logo
54 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
