Question about Polaris 2005 Classic 500
Motor runs fine but noheadlight or tachometer.
1995 classic runs well just no headlifht or elect. dashpower
  • 3 Answers
Does your tail light work? If not, you may need to replace your voltage regulator/rectifier.
Posted on Oct 07, 2013
Hi, I have a Sebo premier and the brush wont work or the green light come on. Can anyone tell me if you should get 240v on the connector from the main vacuum body to the brush head? I have tested this and...
I understand 240v to be 240 volts. of electricity- no vacuum should have 240v. that amount is used on elect. stoves, air conditions,welding machines and large electic appliances. Check the belt drive and the manual for the green light operation- I still don't understand the 240v deal.
Jan 06, 2014 | Sebo Felix Classic Bagged Upright Vacuum
1999cevysilverado noheadlights
does the high beam even work? if not does it show that the high beam is on the dash? if that shows no sighs of working either it could be a headlight switch happend to me before
Aug 31, 2012 | Chevrolet 2500 Cars & Trucks
After replacing distributor, cap, and rotor on 1995 chevy caprice classic (5.7ltr) engine turns over but won't catch. Possible solution?
if it was running fine before you changed the cap and rotor just make sure you put the spark plug wires back in the same spot you might have got them mixed up
May 11, 2012 | 1995 Chevrolet Caprice Classic
My 1995 4runner jitters when accelerating.Mostly in 2nd and 3rd gear. If I accelerate fast, you don't feel it. A friend told me it is misfiring. Sometimes when driving, the tachometer will drop to zero...
mmm k it could be a few things...
1) it could be the timing one thing off alignment and you could be destroying your engine
2) the distributor could be misaligned
3) you spark plug wires may not have full contact or be the wrong size or type (or both :( )
4) you may need a new pcv valve
5) you could have paid for work that wasn't finished right
now the 3000 rpms at 75 mph is normal that is the overdrive on the transmission and that seems to be running fine... if you have time take pictures of as much of the engine as you can and send them to nscwd@hotmail.com... i might be able to help better with those
Nov 04, 2011 | 1995 Toyota 4Runner
I have 1995 camry220sei auto and the battery runs down every night car elect cannot solve problem
First of all see the battery condition. then check some of the electric item switch ON.It may be your cassette player,fan,heater system,center lock motor,A/C clutch, remote control system...etc.
Feb 08, 2011 | 1995 Toyota Camry
The fan is turning very very slowly, hardly moving. everything else is fine. I think It may be the capcitor. Jack
The capacitor kick starts the motor. If you had spin the blade and it still slows down you need to replace the elect motor. The motor will be hot to the touch after it has been running like that for just a few minutes. Usually if its the capacitor it will not start. Look for overheated wires and turn off and unplug the unit. You can get the elect motor on line or at any elect motor repair shop. They usually run 60 to 90 dollars. If you go to a rebuild shop they will match up your unit if you bring it with you on line you will need to know the rpms usually 1070 (within 100 rpms is fine) and if it is CW or CCW this is clockwise or counter clockwise. There is a silver sticker on the motor that has all of this info plus will tell them the overal size. You may have to cut the external shafts with a hacksaw to make it fit plus remove the fans. These can be a real pain. good luck
Aug 09, 2010 | Fedders A6X05F2D Air Conditioner
Lost the speedometer, tachometer, odometer, and cig lighter. Light for security system on but bike runs fine. Have a 06 Ultra classic
your security system is compromised you need to go to the dealer to get it fixed the bike will probally quit after about a hundred miles give or take
Jul 19, 2009 | 2005 Harley Davidson FLHTCUI Electra Glide...
Car: Nissan Maxima SE 1997 tachometer broken
the dash voltage egulator probably went bad. First,check the battery & make sure you have 12 volts,not running. Check it again running & you should see about 14.5 volts. If that's good,I'd replace the guage assembly.
Jun 28, 2009 | 1995 Nissan Maxima
Polaris 2005 Classic 500 Logo
298 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
