Question about Exhaust for Mercedes-Benz Mercedes Benz S55 Amg
2002 s55 amg doesnt have full power and back fires occaisionally. one catilyc converter get very hot fast.
Also have light tap sounds like motor area but only have 70,000 miles. could it be noise from the converter
  • Mercedes-Benz Master
  • 16,195 Answers
The reason that the catylitic converter is hot is because of a rich condition in the engine, one cylinder is not firing. This is most likely the cause of the back fire that you are having. It may be related to the tapping sound if it is a valve that is bend or broken.
Posted on May 06, 2013
Replaced shifter in 2002 s55 amg and now car wont start?
Check all wires around your replacement piece to insure that nothing came loose or is grounding out, it may have also overloaded a fuse if one wire is touching another, so maybe check fuses if nothing else.
Jan 14, 2015 | Cars & Trucks
2002 2.0l suzuki aerio starts but will not idle
Cold or hot engine,or both????????????????????
wow , an actual motor size posted, , shocking .....
congrats.
the real question is :
1: ever give it a full tuneup.
2: and can you keep it running with a fast right foot.
3: and if #2 is true does it have full power?????????
4: check engine light glows running? scan it? yet?
wild guessing. is bad but here are 2 just to show it can be many things.
a pack rat build a nest in air cleaner box>? look?
battery not at 12.6vdc rested, and you start car and batter voltage not
13.3v to 15v but is 11v and falling like rock? (Charge system death)(?
all 4 things i notice hands on in 1min.
the fast foot trick adds extra air, that may be the ISC is stuck closed.
idle stalls are: many. over 50. but in macro form just 4.
  • lost 12vdc to EFI .
  • bad compression? can happen hot.
  • bad spark. test spark carefully.
  • bad fueling.
but i need 1,2,3,4 answers first.
Jul 05, 2014 | 2002 Suzuki Aerio
I have taken away the cats on my SL 55 AMG 2002 mod. How to get rid of the yellows engine light on dash. It keeps coming back after reeset.
Put the catalytic converters back on. The engine computer needs to see the O2 sensors working to keep the light off.
Sep 26, 2012 | Mercedes-Benz SL55 Amg Cars & Trucks
Mercedez Benz 2003 s55 amg lost power in left headlight
Dissconnect the battery for 30 minutes to do what is called a hard reset if that doesn't work you need to take it to the dealer or a shop that has a diagnosis computer . It sounds like the Head light control moduel needs reprogramming .
Aug 05, 2012 | Mercedes-Benz Cars & Trucks
Have a 2002 s55 and the washer bottleis
you can either pull it out and replace it or if you know were the leak is you can go to any parts store and get a plastic tank apoxy and repair it this only takes about two minutes to aply and if you let it set for a few hours you can use the squirts that day
Jan 14, 2010 | 2005 Mercedes-Benz Mercedes Benz S55 Amg
Its has a warning that says in red that says ABC in red.
your car has active shock absorber control, this is a waring light telling you that there may be a problem in the system pump or the fluid level is low, refer to the owners manual for more info.
Sep 03, 2009 | 2005 Mercedes-Benz Mercedes Benz S55 Amg
Perfect tire pressure
The proper pressure is marked on the tire sidewall and on the sticker on the drivers door or door latch pillar.
Jul 20, 2009 | 2005 Mercedes-Benz Mercedes Benz S55 Amg
Pro & con
Upside Sleek and dignified design inside and out, pleasing blend of ride and handling, powerful V8 engines, sophisticated safety features, all-wheel drive available on both sedans and wagons. Downside More expensive than competitors, confusing control layout, electronically controlled brakes lack progressive feel. What's New for 2007 Most of the changes to the 2007 Mercedes-Benz E-Class relate to engine upgrades. Mercedes' AMG division has renamed last year's E55 AMG as the E63 AMG in light of its more powerful 507-hp V8 engine.
May 14, 2008 | 2007 Mercedes-Benz E63 AMG Sedan
Vehicle Parts & Accessories Logo
83 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
Timllfixit
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
