Question about Smith Corona Wordsmith 200 Typewriter
Print Wheel Drive Gear is out of Position
How do I get to the correct position? Many thanks?
  • 482 Answers
Power up the machine, the "V" groove of the hammer should be center aligned with the "." petal If not 1 remove the ribbon bracket 2 loosen screw of the daisy wheel (element) motor it has locktite on it , slide the motor up or down in its slot until the hammer and petal are aligned. If you cannot correct it this waydue to a lack of travel it becomes a more complicated job may need a typewriter repair man.
Posted on Aug 05, 2007
SOURCE:
2003 Silverado 4WD. Service 4WD dash light comes on after engaging 4WD and acts up by engaging itself randomly for several days, then goes back to normal.
Check connection at the 4X4 control module , check power and grounds . Do you know how to do basic electrical testing ? Does your truck have manual or automatic trans mission ? Which transfer case does yours have ?
The NVG 263 transfer case features a three button shift control switch located on the instrument panel. When the ignition is in the RUN position, the transfer case shift control module (TCCM) starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position begins flashing to inform the driver that the TCCM has received the request for a new mode/gear position. The lamp continues to flash until all shifting criteria has been met and the new mode/gear position has been engaged. Once the new mode/gear position is fully active, the switch indicator for the new position remains ON constantly. In the event that the TCCM can not or will not complete the shift, the indicator returns to the previously selected position; this is a Transfer Case Shift Control Switch Indicator Flashes, then Returns to Previous Mode condition.
The NVG 263 transfer case provides the driver with 4 manual mode/gear positions:
• 2HI - 2 Wheel Drive high range
• 4HI - 4 Wheel Drive high range
• 4LO - 4 Wheel Drive low range
• Neutral
Have it check for DTC'S - diagnostic trouble codes ?
DTC B0790
DTC B2725
DTC C0306
DTC C0327
DTC C0359
DTC C0379
DTC C0550
Your best bet would be take it to a qualified repair SHOP
Dec 28, 2016 | Cars & Trucks
Was driving my 2004mountaineer tool light came on and jumped out gear now won't do nothin bug grind
There are several possibilities. If you have a 4x4, the unit could be between the 2 wheel drive and 4 wheel drive modes. There is also a 4 wheel drive low and 4 wheel drive high mode. On some models the selector switch is similar in appearance to the blower motor selector switch. Someone could reach for the blower speed and turn the 4 wheel switch instead.
Another possibility can be a burned out led indicator switch on models which use electric shift solenoids to position the drivetrain between 2 and 4 wheel drive. The voltage gets messed up because of the burned out bulb and the shift plunger does not go into the correct position.
Have your error message read by a scanner.
May 23, 2015 | 2004 Mercury Mountaineer
I have an 2004 chevy blazer 4x4 and the four wheel drive does not engage on the fly and it also will not engage when in neutral. Four wheel low will work but when you press 4 wheel hi it blinks twice and...
Which of these does your vehicle have ?
The NVG 233 transfer case features a 3 button shift control switch, located on the instrument panel.
The NVG 236 transfer case features a 4 button shift control switch located on the instrument panel.
Do you know what DTC'S - diagnostic trouble codes are ? Both of these 4X4 systems can set DTC'S , Having a professional or factory scanner is what is needed to check for these codes . Not a OBD 2 code reader or autozone , advance etc... The four button system can set a bunch of them .
DTC B2725
DTC C0300
DTC C0305
DTC C0308
DTC C0309
DTC C0310
DTC C0315
DTC C0323
DTC C0324
DTC C0327
DTC C0362
DTC C0367
DTC C0374
DTC C0376
DTC C0387
DTC C0550
DTC C0611
The NVG 233 transfer case features a 3 button shift control switch, located on the instrument panel. When the ignition is in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch, to determine if a new mode/gear position has been selected. At a single press of the transfer case shift control switch, the lamp of the new position begins flashing to inform the driver that the transfer case shift control module has received the request for a new mode/gear position. The lamp continues to flash until all shifting criteria has been met and the new mode/gear position has been reached, or has engaged. Once the new mode/gear position is fully active, the switch indicator lamp for the new position remains ON constantly.
The NVG 233 transfer case provides the driver with 3 manual mode/gear positions:
Any of these mode/gear positions may be selected while driving the vehicle. However, the transfer case will not allow a shift into, or out of, 4LO unless the following criteria has been met:
• The engine is running.
• The automatic transmission is in Neutral, or the clutch pedal is applied on manual transmissions.
• The vehicle speed is below 5 km/h (3 mph).
Finding out what if any codes are stored should be your first step .
Feb 22, 2018 | 2001 Chevrolet Blazer
Xerox 8400 error 07.010.43:52882
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward to the print position, due to problems.
Do the printhead lock arms rotate correctly.
Has ink spilled ink around the printhead that prevents the printhead from moving to its center position? You should be able to manually push the printhead right to left.
Does the X-axis motor drive the printhead to it’s center position (so it can tilt forward)?
1. Check the process gearbox for obstructions
or damaged.
2. Ensure the gears are correctly aligned and
homed.
3. Verify the process shaft and drive module
shaft are at their home positions.
Has ink spilled on the head tilt gear on its drive train (near left side of the printhead).
Aug 30, 2009 | Xerox Phaser 8400 Laser Printer
Printer error 07,010.43:722 on phaser 8560 xerox printer
Hi eduardo580:
This your problem.
1 1.
Reboot the printer.
2. Did this correct the problem? Complete. Go to Step 2.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair/replace
the lock arms.
3 1. Has ink spilled ink around the printhead that
Clean the printhead area. Go to Step 4.
4 1. Does the X-axis motor drive the printhead to
Go to step 5. Troubleshoot the X-axis drive.
5 1. Check the process gearbox for obstructions or damaged.
2. Ensure the gears are correctly aligned and homed.
3. Verify the process shaft and drive module shaft are at their home positions.
4. Did this correct the problem? Complete. Go to Step 6.
6 1. Has ink spilled on the head tilt gear on its
Clean the gears. Go to Step 7.
7 1. Use service diagnostics to run the Head Maintenance Wiper Clutch test.
2. Did the test fail?
Replace the wiper drive clutch. Go to Step 8.
8 1. Ensure the wiper is properly aligned.
2. Use service diagnostics to run the Wiper Drive Test.
3. Did the test fail?
Replace the exit module assembly. Go to Step 9.
9 1. Use service diagnostics to run the Load Maintenance Clutch test.
Inspect the maintenance drive system,
replace any defective parts. Go to step 10.
10 1. Verify the headtilt gear will engage. You can
manually set the headtilt gear.
2. Is the gear engaged properly?
Go to Step 11. Set the headtilt gear.
11 1. Use service diagnostics to run the Tilt Axis Drive test.
Replace the process gearbox.
Go to Step12.
12 1. Use service diagnostics to run the Process Motor test.
2. Did the test fail? Replace the process motor.
Hope this helps
Jul 25, 2009 | Xerox Phaser 8500/DN Printer
How to shift into 4wd
Ford has 2 types of 4x4 system engagement. One is a knob on the dash that you just turn to 4wheel drive high or low. The other system is the 4x4 transfer case shift on the transmission tunnel (hump) between the driver and passenger seats. To shift into 4 wheel drive high while driving, just let off the gas and shift transfer case into 4H position, and continue driving. To shift into 4 wheel drive Low, stop the vehicle completely, put transmission in neutral, shift transfer case into 4Low position, put trans. in gear, and start driving. I am assuming before doing the above, you have locked in ( turned the front hubs to 4 wheel drive position.) Any further questions, let me know.
May 16, 2009 | 2003 Ford F150 Regular Cab
Error code 07,010.43:59833. Service said I have to replace print head for 900$!
Hi jo47628:
Here is your problem:
1. Reboot the printer.
the lock arms.
Clean the
printhead area.
Go to Step 4.
the X-axis
drive.
or damaged.
homed.
Clean the
gears.
Go to Step 7.
test.
Replace the
wiper drive
clutch.
Go to Step 8.
Drive
Test.
Replace the exit
module
assembly.
Go to Step 9.
Maintenance Clutch
test.
Inspect the
maintenance
drive system,
replace any
defective parts.
1.
gear.
Drive
test.
Replace the
process
gearbox.
Go to Step12.
Motor
test.
Hope this helps
Apr 22, 2009 | Xerox Phaser 8550DP Printer
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Print Wheel Drive Gear is out of Positoin
Normaly this would not be a user adjustment, possibly the grub screw hold the wheel hub to the motor has come loose, very small allen key needed, you make be able to shift it back to right place. Usualy this is done with special alignment jig
Aug 02, 2007 | Smith Corona Wordsmith 200 Typewriter
Types wrong Characters
Does it always type the same wrong letter ie a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
Jul 04, 2007 | Smith Corona Wordsmith 200 Typewriter
Smith Corona Wordsmith 200 Typewriter Logo
165 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
Jim Keysor
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
