Question about HP xw4600 Workstation - 1 x Intel Core 2 Duo E6850 3GHz - 4GB DDR2 SDRAM - 1 x 160GB - DVD-Writer PC Desktop
"smart card authentication smart card reader not present " my hp xw4600 workstation shows me that msg it freezes the boot I did reset the on board battery but nothing changed , I have no smar
I really appreciate the answer and thanks in advance
  • Anonymous Oct 10, 2017
    old post
    Sultan Muhammad wants more answers to this question ?
    My guess is this
    first of all it has the smart Cover LOCK option in BIOS, for sure
    but is wired wrong, or the sparts missing to same.
    the cure is TURN IT OFF IN BIOS.http://h10032.www1.hp.com/ctg/Manual/c01...
    per the manual ,
    that fancy feature is to block usage of the PC if some bad guy opens the side of PC
    breaching said lock
    it's a feature of business system HPE
    not cheap home pc.
  • HP Master
  • 1,478 Answers
that means your BIOS has this feature/option, mine does not.
and when you see that error it tells you , your BIOS has the lock feature, and in your BIOS you can turn it off. FOR SURE.
the free service manual covers this. lost that?
RTM read the manual, it's free 100% to read.
http://h10032.www1.hp.com/ctg/Manual/c01694939.pdf
Posted on Oct 16, 2017
  • HP Master
  • 7,627 Answers
Have you done ANY Updates, Upgrades? Have you tried a System Restore to a date before this issue?
Posted on Apr 19, 2013
    max this has no relation ship to any OS.
    it's pure BIOS code and lock option.
    he said will not boot.
    it would do that with LINUX on board. a fact.
    this lock is an optional feature, on all these busines HPE Desktops.
    its a normal feature, read the service manaul. it tells you how to use it.
    for sure.
5 Suggested Answers
  • 81 Answers
SOURCE: i try to reset my bios from motherboard after
the system unit is it laptop or Desktop? if it desktop open it and remove the cmos battery, and turn-on the pc and turn-off it again. then the system unit would reset. if u have any problem you let me know.
Posted on Sep 22, 2009
SOURCE: My HP XW4600 does not power up to boot though the
First, be sure the monitor is connected, and powered. Sounds stupid, but I have had the problem.
Next, When you start it, do you hear one beep while the boot process is going on?. If no, the problem sounds like the motherboard. Are you comfortable taking the side off? We will be looking for any lit leds.
This being my first time, I am not sure of the protocol, But, give me
a little slack. I wil look in my service files for information on that
model.
Nothing to do with your problem, but you need to increase the memory to at at least 2Gb if you are running XP.
Let know what more info you can give me. Any thing abnormal helps.
Larry Howard
lt_howard@yahoo.com
Posted on Dec 03, 2010
SOURCE: i have hp workstation xw4100 changed battery then
If as I suspect you changed the CMOS battery, then you will have to set up the system BIOS again to the "Default" configuration. You will have to initialize the Hard Drive, DVD, RAM, Boot Up sequence, all again. Do this and all should be OK. You access the CMOS usually by pressing DEL, or F10, at boot time. Check your manual for exact key.
Posted on Jan 30, 2010
puertobori
  • 7733 Answers
SOURCE: HP xw4600 Workstation Beeps loud immediately
Seems your MOBO is bad.When MOBO are damage the symptoms you describe is the cuase your PC dont boot.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Jul 07, 2011
My hp xw4600 workstation beeps red light blinks on off
read the code the blink codes tell the story,
red lights where,
1: power button LED green? (can be red) and beeps
2: Monitor LED lamps?
3: caps lock on keyboard blink.
4: is the COIN cell dead? 2.9v to 3.3vdc good, lower volts is bad , as most are this old !!!
http://www.pcdied.com/intel-magic/xw4600.html
the service manual covers all this! ever heard of HP and there REAL pages,,???
why not read that?
(do the fans all spin, if not PSU is dead.
PSU fan is first. does it.
CPU fan , huge fan on heatsink must spin.
the stock GPU card has no fan (ASUSc card but mine does. at ATI card.as fan right on the express 16 card.
does the DVD drive eject work.
if any of the above fail the PSU is bad.
but we strip off all loads from the MOBO
to prove its not some part shorted. first.
the front LED on this PC has flash codes
mine flashes in sleep mode, or w10 power off.
w10 never turns power fully off, it uses hibernate to turn off, (unless i cure that, ask)
the factory manual starting on page 111 cover this.
fully.
i own this beast so .....
code 2 red is overheated.clean the PC and all fans.
code 3 red, processor errors CPU.
code 4 PSU dead or shorts on load buses of same.
we call them power rails, we bench test the PSU
or read page 111 , how.
code 5 = GPU RAM failure, this PC has on board, GPU chip only X16 slot card, replace it. or the DDR2 rams are bad.
code 6 = GPU card bad.
code 7= BIOS ROM, put in a new coin cell first.!!!
Code 8= BIOS, always do nee COIN cell first.
code 9 = cant boot hdd, hdd bad or software gone, or corrputed, PC can now boot to a linux live CD or USB stick proving now PC is ok,
only hdd and OS suspected now. code 9
coin.
http://www.pcdied.com/intel-magic/slots.jpg
page 111 is here, 24/7 !
http://h50146.www5.hp.com/lib/doc/manual/workstation/hp_workstation/WS_UG_xw4600_STRG_453080-001_screen.pdf
Sep 01, 2017 | HP Computers & Internet
Hp xw4600 work satation "Smart card reader not present" at boot
Although it is from another model...
See HP Compaq dc5700 Business PC Computer Setup F10 Utility
Reset the settings of the BIOS but make sure you know the parameters you need.
Sep 22, 2016 | HP xw Computers & Internet
I've got a dc7800 Small Form Factor system. After less than a second, a blue window"smart card authentication" and below that, "smart card reader not present".
"System Options Not Set" normally means that the battery that maintains those options has gone dead. That's usually a 2025 coin cell on the motherboard.
I would replace that first thing, then set the BIOS options. Usually, there's another message that comes up, "Press F1 to continue, F10 for setup". F1 will let you system boot, most likely, but doesn't set the options. F10 (or whatever it says) will get you to where you can set the options.
Nov 09, 2015 | Computers & Internet
It's probably connected on one of internal USB branches. Try to plug it in another, if not work... there must be a device hardware error.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Feb 08, 2014 | HP Compaq DC5700 Microtower PC
SMART CARD AUTHENTICATION no smart card reader found
I'm only guessing here, but did you set it up for Smart Card Authentication? If so I guess if the card reader hardware fails then so does Authentication unless replaced. Anyway I'm keen to hear the perfect solution for your Laptop problem.
May 01, 2013 | HP Compaq nc6000 Notebook
I'v an hp xw 4600 workstation PC , I connected an extra hard disk via sata cable on the M.b. directly .. after i rebooted and removed my hard everything started going wrong , first a msg said 16
Whoa! Wait a minute................
Let me see if I have this straight................
You plugged an additional SATA harddrive into the motherboard.
(Via a SATA data cable)
THEN you removed the original harddrive?
Post back in a Comment to clarify
Regards,
joecoolvette
Apr 19, 2013 | HP xw4600 Workstation - 1 x Intel Core 2...
What type cable do I need to connect the monitor to a hp xw4600 computer?
An out of the box HP xw4600 has a NVIDIA Quadro FX1700 video card which uses a DVI cable. You have to make sure your monitor supports DVI. A WHITE connector is for DVI while a BLUE connector is for VGA. Some monitors have both while many older models only support VGA.
Oct 29, 2010 | HP xw4600 Workstation Linux Installer...
Hello, my hp compaq nc6220 gives insert smart card into reader
Pl switch the machine off and put 2-3 pounds of pressure with your palm on the keyboard closer to the spacebar.. this will fix it..
it is caused by the weakening of the adhesive of the wires below the keyboard.
Long term option - get the keyboard opened by the an professional and cleaned properly..and fixed back neatly...
Apr 20, 2009 | HP Compaq nc6000 Notebook
HP xw4600 Workstation - 1 x Intel Core 2 Duo E6850 3GHz - 4GB DDR2 SDRAM - 1 x 160GB - DVD-Writer  PC Desktop Logo
751 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
