Question about Philips 32PT6441/37 32" TV
When i turned on my philips 32inch crt tv, it will on with normal grains then it will goes to red and white colours also chanels are not changing.
Colors are coming in red and white on complete screen. The channels also not working, but when i am switching on then its coming in normal mode only, and i am not having its remote also.
techman
  • 3130 Answers
SOURCE: Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Posted on Mar 27, 2007
  • 1694 Answers
SOURCE: Philips 29PT9418/69G
A qualified tech will need to practice visual acuity technique! Look at power supply circuit for signs of stress,dis-coloration and/or bad connects.Check for bad 47mf/25v cap in area of stress.Replace BC-327-25 xistor w/BC-328 and replace BC-337-25 w/BC-338,if present in your set's chassis style.
Posted on Sep 25, 2007
SOURCE: Philips TV set PC7225-PC121
This suggestion pointed me in the right direction. I have a 10 year old Philips 27 inch and wanted to add the cable channels. It was a used tv and first I checked cable and it said no, I changed no to yes, and then went to the autoprogram, and all the channels for cable were set. Thanks very much.
Posted on Sep 30, 2007
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Posted on Nov 09, 2007
SOURCE: Philips tv turns on by itself and is stuck in demo mode
Change the eeprom
Posted on Mar 17, 2008
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
Connect Philips DVD to Sansung TV
the red and black are the same as the red and white, these are the audio left and right channels. the yellow plug is the video plug. the next thing you have to check is wheather your tv has video 1 and 2 channels
May 09, 2009 | Samsung Televison & Video
For a RCA TV Model GMR2758P
You have to have a remote control to set the chanel to 00. You cannot do this with the chanel buttons on the front of the tv.
Dec 26, 2008 | Televison & Video
Philips 50P8341 50 in. Rear Projection Television
normally when something like this happens, we could right away propose what can be done, in your case, since youve already changed a lot of parts on that tv, you can at anytime fix it. the tv alone is not fixed yet as of the moment but to some it up, experts have already given you some ideas on how to fix the tv. cheers. hope youll fix that tv in no time.
Mar 12, 2008 | Philips 50P8341 50" Rear Projection...
TV channels
If cable is hooked through cable box with a coaxial cable, then turn tv to ch 3 or ch 4 as appropriate.
If cable is hooked through any other type of cord (red/green/blue or red/white/yellow) use the AV+ or Source button to change your source to Av1, AV2, HDMI, or however you have the cable box hooked to TV (I am assuming your TV is a Philips).
Feb 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Audio out problem (magnavox MWD200G)
yellow to yellow that is video and that is ok.
red and white are the audio chanels left and rigt try to change it and your soun will be ok
Feb 07, 2008 | Philips Magnavox MWD200G DVD Player
TV will not turn on
check the resistors and capacitors in vertical section of the television..or change the vertical ic.
Dec 29, 2007 | Televison & Video
Philips 32PT6441/37 32" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
