Question about HP OfficeJet 7410 All-In-One InkJet Printer
Fax problem Scanner error comes up when trying to fax something, says to turn off power then on. This does not work.
  • kevinskin Mar 15, 2009
    I tried what you said but there was another error message that said, Attach control panel overlay firmly check for stuck buttons. Turn power off and on again.
    Also when I try to scan something the error mesage pops up "No scan options. You need into install or run HP software for this feature.
    Please, let me know if there is anything else I can do.
  • 45 Answers
First try to make a copy and check if you get the same error message..
if you get the same error message..try these steps..
1)connect the printer directly to the wall outlet..and try to make a copy..if you get the same error message..then go the next step
2)unplug the power chord from the back of the printer..press and hold OK and CANCEL buttons together..
3)while pressing these two buttons plug in the power chord to the back of the printer..after you plug in the power chord do not release the buttons untill the screen goes blank..
4)once the screen is blank release the buttons and turn ON the printer..
5)wait for the printer to complete the initialization..
6)then try to make a copy and check if it is copying successfully..
if not machine should be replaced because scanner bulb is not getting enough power or scanner bulb is gone bad..
please try these steps and let me if the solution has worked
Posted on Mar 13, 2009
2 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: scanner won't work, printer and fax work
reinstall the print management software. May need to remove the printer, and re add under control panel. Got backup?
Posted on Feb 10, 2008
ERROR E733-0000
E733-0000
Error code : Printer communication error Communication error between the Engine Controller PCB and the Main Controller PCB occurred.
Try turning off the device, unplug power cable and turn on to flush the memory. Change the power cable as well. If this doesn't resolve the issue, probably something is loose in the board. Contact your support.
Nov 20, 2013 | Canon Imageclass D1350 Multifunction Fax...
Canon MX892 - when I scan, an error code 2156 comes up saying scanner is turned off or usb cable unplugged
Hi.
Try to check up first scanner power cable and network wireless router.
If it are running running good. your scanner have defective parts. like
IC chipset.
Second option : try to general cleaning your Canon PIXMA MX892 Network-Ready Wireless All-In-One Printer. using vacuum.
Hope can help you.
Sep 15, 2012 | Canon PIXMA MX892 Network-Ready Wireless...
I have an hp officejet pro 8500 fax, scanner, copier and printer. I keep getting an error message 350 when I have repeatedly tried to send a fax. What do I do and what does error 350 mean? Thanks in...
error 350 means a disconnection, from your machine to that of the remote fax machine. Disconnection can either come from a power shortage, defective or not so good telephone lines, a call-waiting mode on the telephone, a defective fax machine or manual interruption.
Sep 12, 2010 | Computers & Internet
Scanner Error 6 Turn off than on, Tried that a couple of times and still displays the message in the window, cannot fax or copy but we can receive faxes.
Sorry but I have a bad news. Scanner error xx means that the scanner lamp is not able to move and if it does it cannot go all the way by either something blocking it or a gear worn. In some cases it does like a humming or clicking noise. The printer need service, probably a new scanner. You can try an NV RAM: Turn it off and press the ''enter'' and the '' * '' (where the numbers are) while holding down both keys turn it on and keep holding them until you get the message permanent storage init and then release wait to see if it get back to ready. The repair might be too complicated and expensive (over $250) I suggest to get a new one. HP can provide a deal to recycle the unit and give you a credit, maybe not a lot but its something.
Aug 26, 2010 | HP LaserJet 2840 Printer
I have an hp digital copier, stand alone, not connected to any computer. When I turn the power on the warm up message lasts for a long time. It then tells me there is a scanner failure and will not print....
Hello.
Give this a try (from HP Support):
The Scanner System Failure error occurs if the scanner bulb is not being heated up to the correct temperature or there is some other issue with the scanner hardware. Verify that the scanner bulb is lit.
Power cycle the all-in-one product and see if the error comes back. Perform the steps given below to power cycle your all-in-one product.
1. Shut the computer system off, then disconnect the all-in-one product from the power source. Leave the all-in-one product disconnected from the power source for at least one full minute.
2. Reconnect the power, then restart the computer system.
If it does, take it off of any power strip and plug it directly into a wall power outlet. The power strip may not be supplying enough power to the product. Cold ambient room temperatures may also cause this
error. Try moving the unit to a warmer room and see if the error reoccurs. The unit will need to be serviced if the bulb does not come on.
Perform a semi-full reset by following the steps given below:
Caution: A semi-full reset will reset or clear the following information:
* Return the user settings to the factory defaults
* Delete language and country settings on some models
* Fax logs
* Fax headers
* Fax speed dial information
Hope this helps.
Feb 07, 2010 | HP 610 Color Copier
Tried to print something from the glass, got error message
this is usually the case when certain settings that are required by the registry are not in place, The solution could be as simple as unistall the scanner driver restart the system and reinstall the scanner driver.
If this doent work get back old registry values by going to start-Programs-accessories-system tools -system restore and restore the settings to the time when youre sure the scanner worked .
Jul 09, 2009 | HP LaserJet 3330 All-In-One Printer
What is Error 2200 when I try to fax something?
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO.
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off the AIO and remove the power supply from the back of the unit.
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Jun 29, 2009 | Lexmark X7170 All-In-One InkJet Printer
7210 can't fax or scan
Soft/firmware issues. Try updating.
Jul 29, 2017 | HP Officejet 7210 All-In-One InkJet...
Brother MFC 4450
The majority of Brother machines will usually not recieve when they have a scanner error. So your lucky.
Under the top cover where the original goes you will see a glass strip (this scans your original). It should light up when the machine is powered on. If not this item has most likely failed. I have seen it before where rust around the contacts have caused it to not work and after cleaned the contacts it did work but usually it just fails.
Another way to checkif the machine will let you is to do a copy. If it comes out black it means the scanner has failed. It should be a relatively cheap repair if it has.
Jan 30, 2008 | Brother IntelliFax-2820 Laser Fax
Scanner locked
okay, im assuming the brother all in one in the picture is what you're on about...right?!? anywayz :) basically i think it is because you have got "faxes saved in the memory" it sounds weird but the scanner locked is coming up because the scanner is not going back to its home position. if there are faxes in its memory, it means that the memory has not been cleared. to check press menu/set 9,0,1 - if the screen says "No data" means that the memory has been cleared and i don't know what to do!! if it says "Enter fax.no" means that there are faxes in the memory, in this case, the fax must be cleared of memory, (if you need the faxes, you must save them before proceeding) turning it off clears memory apparently but im assuming you've tried that countless times.Turn off the machine's power switch and then on again. If the error message continues, leave the machine for several minutes and try it again. the MFC-7820 can store memory for up to 4 days, so watch out if you have a 7820. apparently this will resolve the issue and the message should go away, hence the scanner returning to its home position!! hope this helps
user guide : http://www.topedge.ro/info/USER-GUIDE/BROTHER/MFC-7820N.pdf
11-3 is the scanner locked section
11-5 is the fax removal section
Dec 05, 2007 | Brother MFC 7420 All-In-One Laser Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
104 people viewed this question
Seeker5211
Seeker5211
