Question about Sony Klv-32t550a Bravia Multi-system Lcd 32"
I have a sony bravia lcd tv model 32klv t550a and it is having a problem when i turn on the tv set the red and green blinking and there is no sound and picture,
  • 197 Answers
SOURCE: sony bravia 46 lcd The picture dims and
set has a light sensor. go in menu and turn light sensor off
Posted on Jul 02, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
welcomejee
  • 10594 Answers
SOURCE: No picture or sound. Red light
Just a correction, it is not necessary that 4 times red light blinking always shows inverter board problem.
It depends on chassis/ model number of Sony bravia tv to what is error code of 4 blinks as it would be mentioned service manual.
I'm Sony tech and can help you, let me know model number written at back of tv to provide you exact info about 4 times red light blinking.
Thanks.
Posted on Aug 18, 2010
caroldon
  • 17130 Answers
SOURCE: i have a sony Bravia
Dont think that it is a case of resettting but a possible failure in the main board.The power supply works but is in the protect mode and so it switches offf. the faultt can vary with a faulty capacitorr to a shorted drvier.
It is important to open and look for the voltage short in the circuit by using a good multimeter and opening out the shorted circuit to confirm. Use a continuity test to check for short in large value capacitor/ display drivers/transformers.
If you notice bad solder joints do a touch up solderring job with care not to tamper or bridge circuits.
Credit if this helps.
Posted on Aug 21, 2010
SOURCE: i have sound but no picture on sony bravia lcd tv
change gl mainboard
Posted on Dec 01, 2010
I have a Sony Bravia LCD TV Model: #KDL-46W5100 SN:8020524. When I turn on the TV all it has a great picture & sound. After apx. one minute it will lose the sound and then it will turn itself off. Then...
G'day Lee, sounds like you may have a 'dry joint' meaning the solder has come adrift, to open the back up will need special tools to fix it. Hope you can get it fixed. Cheers Greg.
Mar 04, 2015 | Sony BRAVIA KDL-46W5100 46" 1080p LCD TV -...
Sony Bravia 52EX701 picture went out. Now bottom
Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the unit and be able to use a soldering iron. If this isn't you then take it to a repair shop.
Sony is, by and large, a reliable brand. The problem is that Sony like most other manufacturers has to buy capacitors from 3rd party suppliers who bid on price. Unfortunately the cost cutting has affected parts quality.
Sep 16, 2014 | Televison & Video
Sony bravia 40 inch red blinking light when turned on green light shows but go,s back two blinking red what should i do
you might try washing it.
submerge the tv in the bath tub, use lukewarm water only.
then turn it on.
problem solved.
Sep 13, 2014 | Sony Bravia KDL-40EX700 40" LCD HDTV -...
My 40 inch S400A Series Full HD BRAVIA LCD TV does not turn on. When i plug it in, the green light (next to the Red power light) blinks. If i try to power on via remote, the red power light turns on and...
this again sounds like the power supply,.if you hear a click when you push the power button, this means your main board is reading good so replace the power supply,.
Apr 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Bravia, Model: KDL40BX450. It's red 'stand-by' light has suddenly gone off and I cannot turn on the TV. What's going on?
I have a sony Bravia 40" LED TV. KDL40BX450.When I turn my set on it has no sound. And the standby light blinks three times and pauses. I have unplugged it. and even reset it to the factory settings. And as long as the set is on the sound works.but once I turn it off. and turn it back on later.it does the same thing again.no sound. what could be wrong .And is there anything I can do to maybe fix it.
Dec 12, 2012 | Sony BRAVIA KDL40BX450 40 Inch 1080p LCD...
Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Mar 14, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Klv-32t550a Bravia Multi-system Lcd 32" Logo
57 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
