Question about Amana NGD7200TW Gas Dryer
There is a code that flashes on the screen of the dryer that is not listed in the manual. It looks like two c's facing each other.
The dryer completes the cycle, but now the clothes are still damp. The signal code as mentioned before with two C's facing each other begin flashing
  • Amana Master
  • 8,220 Answers
Perhaps something as simple as cleaning the sensor strips inside the dryer so that moisture can be detected better by the control would help. That is what I would try. The sensors are metal strips below the filter inside the dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 21, 2013
On/off light flashing with 1st and 2nd light flashing as well. dryer will not work
These blinking lights refer to a trouble code that is usually listed in the users manual for most common problems. If it's not listed then it will only be available in a service manual.
Jun 21, 2015 | Dryers
My Maytag Neptune dryer is still flashing the E5 code
I looked up and there is no E5 error code listed in the tech sheet.
Check it and confirm us.
Oct 13, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
My dryer is still flashing the E5 code after I changed the themister
Oct 13, 2011 | Maytag Neptune MDE4000 Electric Dryer
Maytag neptune dryer has e5 error code
I looked up your model and there is no E5 error code listed in the tech sheet.
Download a copy of your tech sheet here.
files.me.com/appliancejunk/e8bg66
When I search the maytag data base this is the service manual it list for your model number.
http://appliancedigest.com/index.php?/files/file/81-16023110-maytag-sloped-front-dryer-repair-service-manual/
If the dryer is running but not heating then the relay on the control, ignitor or thermistor are the most likely causes.
Aug 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
E-27 blinking
The E27 code isn't often listed in Bosch manuals but relates to the washer door lock.
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You may need to replace the door lock assembly on the washer.
Jul 20, 2011 | Bosch WFVC6450UC Front Load Stacked Washer...
Kenmore elite model #110-67042601 is flashing a AF code
The AF error code for Kenmore Elite Oasis dryers with model numbers 11067032601, 11067042601, W10035200, 11067032600, and 11067042600 indicates that the dryer is experiencing an airflow problem. The Kenmore Elite Oasis owner's manual recommends four troubleshooting solutions to an airflow problem: clean the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Read more: Error Codes on Kenmore Dryers ' eHow.com http://www.ehow.com/list_7192588_error-codes-kenmore-dryers.html#ixzz1MuOgWsZC it is found also on this link above by clicking the link if you have any further questions please message me back and your dryer should be dlinted at least once per year to avoid dryer breakdown you can also see how to dlint your dryer by clicking this tip that I wrote http://www.fixya.com/support/r8732702-prolong_life_dryer I await your reply if you have any further questions Thanks Rick
May 20, 2011 | Kenmore 72982 Gas Dryer
What does error code f 02 mean?
Noted this is a Red Maytag Gas Commercial Dryer.
Using this parts link:
http://www.kitchenaid.ca/assets/pdfs/literature/Repair%20Part%20List%20-%20W10222090.pdf
And this Owners manual Link:
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10057350A.pdf
I do not have the service manual for this dryer and I have yet to locate it via any source. The dryer appears to be made by KitchenAid. Even checking the KitchenAid service manuals has yet to be successful.
Inside the dryer there is a tech data sheet enevelope that will either be on the left side / inside the top console or taped to the left side of the dryer cabinet on the inside left as your facing the dryer. The F02 code should be listed on one of the 4 data sheets in that Technial Data Sheets packet. The sheet your looking for will have this number printed on it:
W10057359 Tech Sheet
I wish I could be more helpful but this one has me baffled as to why I can not locate a service manual.
Now.. having said that... are there any symptoms that you noticed before the dryer displayed the F 02 code. Like clothers were taking longer than usual to dry? Odd burner operation?
Anything out of the ordinary?
Kelly
Apr 05, 2011 | Maytag Dryers
I recently moved and now my dryer is flashing PF
According to Whirlpool, all you need to do for “PF” (power failure),
is check the following:
Was the drying cycle interrupted by a power failure?
Press and hold START to restart the dryer.
To view the owner's manual for your dryer click on this link & choose the model # that you have from the list.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WED8300&siteCd=WHRCOM&userType=Consumer
May 27, 2010 | Whirlpool WED8300S Dryer
Amana NGD7200TW Gas Dryer Logo
125 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
