Question about Invacare Health & Beauty
Power wheelchair won't turn right, back tire squeals
Back left wheel squeals in protest when i try to turn right. Chair struggles to move in any direction except a left turn.
  • MobilityRepairSpecialist
    This sounds like a classic bearing problem. When there is no load on the wheels, they will turn fine, when you add weight to the chair by sitting in it, this is when the problem comes back. Get with your local Tech and have them replace the castor/fork bearings. I always carry a set of these on my truck because it is a common problem.
    Sergeant:
  • 317 Answers
Have you completely disengaged the wheel locks? Check for worn wheel bearings.
Posted on May 15, 2013
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Posted on Mar 13, 2009
dromtonpa
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
dromtonpa
  • 40 Answers
SOURCE: Jazzy 1113 Power wheelchair. Batteries are fully
Yes, the main controller module can be very expensive to replace. I would take it to a reputable dealer if the battery replacement does not help.
Posted on Apr 05, 2009
  • 32 Answers
SOURCE: replaced batteries and lights on
sounds like problem with controller and or joystick, need to have someone check with programer.
Posted on Jul 13, 2009
  • 177 Answers
SOURCE: I have a Hoveround MVP 4 power wheelchair. I purc...
Hi. your problem could be a couple of faults. Have you checked that both tyres have the same pressure in them? Problem could also be a faulty motor or brake unit. When these motors have done a few years work they build up carbon and copper dust from the brushes and the commutator. the motors can be tested for this if you find a clever serviceman. The motors should also be tested to see if they are both drawing the same current ( amps ) when in use. In answer to your last question, the answer is probably no. Good luck. Neil.
Posted on May 28, 2010
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Jun 20, 2014 | Pride Jazzy Select 6 Indoor Power...
What does my tss300 power indicater keep flashing left to right but won't move. batteries are fully charged and reset is set?
The chair is more than likely in free wheel. There are two levers under front of the seat (yellow). Pulling them forward should place the chair in freewheel and pushing the levers back should place the chair in drive. Once in drive mode, turn power on to reset joystick.
Apr 27, 2014 | Pride Mobility Pride TSS300 Power Chair -...
My vision sport power chair won't move. the
says here thats a right motor fault, check the right motor connections and cableing
Sep 02, 2013 | Health & Beauty
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
Sep 28, 2012 | Pride Mobility Products Pride Jazzy 600
How to move dead electric wheel chair
There are two levers, one for each motor, you have two. Depending on model either right under your knees (M51) usually, or under the rear, near the back casters. Typically black rubber on a metal rod. Move both in opposite directions, either both out, both in, or some types, both up, or both down. Sometimes they need wiggling, turn the chair OFF then try moving it in each position, (both in or both out). Google the manufacturer, your case invacare, they have detailed instructions there.
Jul 08, 2012 | Invacare Pronto M51 Power Wheelchair
My laft wheel hancs up. mostly when turning left and feels like the brake is sticking. It will hang up bad enpugh that the chair will not move and the safety lights are blinking when I try to move. After I...
Sounds like you need to replace the left electric brake. The brake is on the opposite end of the motor-gear assembly from the motor. Remove the screws holding the brake on to the gear assembly, unplug it and replace with new brake.
Dec 19, 2009 | Invacare Pronto M51 Power Wheelchair
How to push the jazzy wheel chair when power fails''
There are two levers located on the base of the chair on the left and right sides. Depending on the model, they will be located on top of the base on the front section of the chair base, or on the rear or on the lower sides. Most rotate 90 degrees to disengage the gears so you can manually push the chair. Others are moved up and down, or in and out. Return them to the locked position when done.
Jul 01, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Health & Beauty Logo
273 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
