Question about Garden
Where is the fill for hydraulic fluid on a case LX112
Need to check and fill hydraulic fluid.
2 Suggested Answers
charlesbe45730
  • 1917 Answers
SOURCE: how do you fill the hydraulic fluid for the craftsman kohler magnum 19.5 lawn trctor
its hydrostatic fluid not hydalic fuid dont put hydralic fluid in it the fill is on the back of tractor on the transmission there is a dip stick do not overfill or you will blow seals
Posted on Dec 15, 2014
Changed hydraulic filters now hydraulics don't work?
Sometimes with hydraulics you need to "burp" any air from the system, though they tend to be so-called self bleeding. Try filling the filter with fluid and check that the pump has fluid in it to get it pumping. If the fluid was drained from the pump and it has air in it, it won't do anything. Get some fluid in it and it may start pumping.
Apr 04, 2017 | Garden
How do you fill the hydraulic fluid for the craftsman kohler magnum 19.5 lawn trctor
Dec 15, 2014 | Craftsman Garden
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic MerconĀ® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Is hydraulic fluid really used for both the transmission and hydraulics in the international 460 also where do you fill it?
caseih hytran fluid is used for hydraulics and transmission fill through plate on top of deck next to shifter check plug is located on left side of transmission housing next to clutch linkage rod probably square headed pipe plug
Jan 15, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
How to adjust clutch for 1998 saturn sc2
HYDRAULIC SYSTEM BLEEDING The clutch hydraulic assembly has been filled with fluid and bled of air at the factory. Do not attempt to bleed the hydraulic system. While the unit does not require periodic checking, it must be serviced, when necessary, as a complete assembly. The system is full when the reservoir is half full. Only DOT 3 brake fluid should be added to the system. If the fluid level drops, inspect the system, including the slave cylinder, for leakage. A slight wetting of the slave cylinder surface is normal. Fill the clutch master cylinder reservoir with brake fluid. Be careful not to spill brake fluid on the painted surface of the vehicle.
Aug 11, 2010 | Saturn SC2 Cars & Trucks
I have a case 4210 farm tractor and need to know what the best type of hydraulic fluid to use would be ??????
Older case machines used a fluid identified as TCH (Torque Converter Hydraulic) for both the transmission and the hydraulic system. It's not readily available so has been replaced by default by separate products. Hydraulic fluid for the cylinder system, and transmission fluid for the torque converter. I'm currently using NAPA TDH with no problems.
Sep 07, 2009 | The Times Case Corporation Tractors...
Hydraulic Fluid Level (Checking and Filling)
hello darrell. yes you just unscrew the plug and fill it full.
Apr 15, 2009 | Toys
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
